Power Running boards OEM wiring digram
Discussion in 'Electrical' started by sampsonjw, Apr 22, 2023.
  1. Apr 22, 2023 at 4:45 AM
    sampsonjw
    sampsonjw [OP] New Member
    Hello all…my name is Joe and new to the group. There are some great posts and people on this board! I just took delivery of a 2023 black 1794 hybrid 4x4. I originally ordered it with the ambient lighting and powered running boards and step. I waited 4 months for the dealer to find me what I was looking for but they kept stringing me along month over month. Last year I purchased the TRD 3” OEM lift kit in anticipation of getting the truck to get that purchase out of the way. Got a great deal $2600. Which I will install myself.
    This also required me to omit the AVS and leveling system. Long story short. I found one at a dealer in Georgia and had them deliver it to me here in Florida. However…no ambient lighting or power running boards. The dealer cut me a check for $3000 so that I could aftermarket the running boards.
    I purchased the GoRhino E1 boards with the bed liner texture for 2100 and I will install them myself.
    Finally to my question. Does anyone have the wiring diagram for the OEM powered running boards? I am hoping the factory harness is there and I can buy the switch and maybe cpu to integrate into existing circuitry. The Rhino has a harness and control I using magnetic switches on all the door frames but I’m looking for a cleaner install and to used OEM switch in dash. So that’s it. Sorry for the long winded introduction
  2. Jan 29, 2024 at 8:41 PM
    DynoDog
    DynoDog New Member
    Did you ever find the answer for this? Currently installing AMP Research boards and looking for wiring info.
  3. Jan 30, 2024 at 11:52 PM
    DynoDog
    DynoDog New Member
    It did come with insturction, but very general(weak) information. Especially on the wire storage and splicing. Thanks for the links.
  4. Oct 10, 2024 at 10:28 AM
    elysian1
    elysian1 New Member
    2024 Grey Tundra Limited TRD
    I believe someone has been working on an alternate solution for the Go Rhino E1 / Rough Country power steps so you dont have to use the magnets, but instead use wiring in the doors for open/close sensing. Does anyone know if anyone has successfully done this? I like the higher step deployment of the Go Rhino, but i really dont want the magnets.
