  1. Oct 10, 2024 at 7:47 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    But they protect your boat! That's the ONLY time I use them!
  2. Oct 10, 2024 at 8:10 AM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Haha I know. They do have their purpose, but fugly as all hell.
  3. Oct 10, 2024 at 8:21 AM
    HulkSmurf14
    2014 Tundra Limited
    It adds to the shame when you're loaded up rolling with them and they scrape on the pavement when you're rolling slow at gas stations...haha
    BreyTundy likes this.
  4. Oct 10, 2024 at 8:27 AM
    Snert
    Snert New Member
    2021 SR5
    Started the arduous process of rust removal/restoration/undercoating. Trucks only a '21 but living in the salt belt there's already a decent bit of rust forming. Debated on paying someone to do it but shops around me charge $1000+. Ended up getting some wire wheels from HF, some Rust Kutter on Amazon, Rustoleum Rust Reformer spray paint, chassis spray paint, a spray gun with the hoses, Cosmoline and Wool Wax. Got the underside degreased with Purple Power, wire wheeled and a round of Rust Kutter so far. Going to do a second round on some of the worse spots, then prime and paint followed by Wool Wax in the body cavities and rockers, Cosmoline for the frame and high spray areas. Pulled the front fender liners and the tail lights to get at everything. It's not hard work but it's definitely time consuming/tedious. Hoping after doing everything super well this year I'll be able to just do touch ups on the Wool Wax and Cosmoline for years to come.
  5. Oct 10, 2024 at 9:19 AM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    2021 TRD PRO CrewMax
    WeatherTech Floorliners Toyota Running Boards Reflex Liner Truxedo X15 Pro cover.
    I hit the bottom of the truck with FluidFilm every year. It is very similar to WoolWax. This has served me very well.
    I have a 2021 and I live in Michigan so salt is a real factor.
    FluidFilm will stop the rust that you have and if you stay on top of re-spraying every year it will never progress beyond what you have.
    I really like the way FluidFilm and WoolWax creeps into all the nooks and crannies.
  6. Oct 10, 2024 at 9:41 AM
    singletrack_dad
    singletrack_dad New Member
    Ty
    2014 TRD OR CM
  7. Oct 10, 2024 at 9:45 AM
    Tundar the Barbarian
    Tundar the Barbarian New Member
    2020 MGM TRD OffRoad
    Speakers, amp, subs, floorboard lights...and the little step thing under the bumper
    Just did Best Mod Ever...whoo, that's satisfying!!! I wish it would free up money for truck stuff or old car stuff, but pretty much committed to house stuff for a while...
  8. Oct 10, 2024 at 9:50 AM
    Snert
    Snert New Member
    2021 SR5
    Yeah after going down the rabbit hole of rust removing/undercoating I settled on a two pronged approach of Wool Wax for creeping into nooks and crannies and Cosmoline for the frame. My only wish is that I had access to a lift lol.
    Wallygator and Henry1jg like this.
  9. Oct 10, 2024 at 10:15 AM
    windblown101
    windblown101 New Member
    2019 CrewMax Limited
    New shoes today! I went with Mickey Thompson Baja Boss A/T 285/70R17 Load Range: SL - These replaced the aging BF Goodrich KO2's in the same size which still had enough tread to be legal but were getting hard and sketchy in the wet. Got a pretty nice deal from a local tire shop who ordered them for me. Total damage was $1212.21 for the tires mounted & balanced, an alignment & state inspection.
    Initial impression are positive. Good ride & not loud for a fairly aggressive tread pattern.
  10. Oct 10, 2024 at 6:48 PM
    vmkeith
    vmkeith Slow is smooth, smooth is fast
    Vince
    Clark County, Wa
    2014 Super White Tundra SR5 CrewMax 4x4
    Rhino Lining bedliner 275/70/18 Pirelli Scorpion A/T tires Lund 5" Cab Length Oval Curved Tube Steps RealTruck Elevate FS Bed Rack Rhino-Rack Carriers RealTruck TruXedo Pro X15 Tonneau Cover Diode Dynamics SS3 LED Fog Light Kit Auxito LED Headlight Bulbs Rydonair 7" antenna
    I'm aware of this and was worried about how the Auxito LED bulbs would perform. After last night, I'm not concerned in the least bit. Last night I had a friend at work drive by a handful of times to see if he'd be blinded. Properly adjusted and targeted, there were no problems. With headlight restoration and the Auxito LED bulbs, the clarity and field of vision is awesome. Couldn't be happier with the results.
  11. Oct 10, 2024 at 7:01 PM
    HulkSmurf14
    2014 Tundra Limited
    Tech has changed/adjusted accordingly...great update for night driving!
  12. Oct 10, 2024 at 7:13 PM
    Vizsla
    Vizsla 2 = 2.5
    @BiggHertz
    Your gonna get the same advice I was given but didn’t listen to…:rofl:
    Just buy the replacement compressors, high temp Loctite 272 is no joke. It is rebuilt and works fine, but it involved a 12 ton press, tig welder, many screw extractors died, and too much time. I am convinced ARB has no quality control or they employ blind people. The tolerances stack up bad, not much chance they will last long term.
    Used to be around $140 not long ago… ARB-CKM01SP
    https://www.polyperformance.com/arb-air-compressor-replacement-parts
  13. Oct 10, 2024 at 7:18 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    So you’re saying I should move forward with my plan of dual wielding Viair 400p’s under my hood?
    HulkSmurf14 and Vizsla[QUOTED] like this.
  14. Oct 10, 2024 at 7:20 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    ah, the easy way out. Lol
    i was gonna buy 1 new one, throw it under the seat on a DDI plate, and invest the rest in a powertank setup
  15. Oct 10, 2024 at 7:24 PM
    Vizsla
    Vizsla 2 = 2.5
    They are in my shopping cart, that was plan B. Under hood is kinda sketchy, too hot with the truck running.
  16. Oct 10, 2024 at 7:26 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Apparently I never told you who my employer is… I see all the shopping carts :spy:
  17. Oct 10, 2024 at 7:31 PM
    Vizsla
    Vizsla 2 = 2.5
    Sounds solid. I actually got sick of airing up the always empty Powertank crew, not to mention that one guys wackadoodle set-up that is always empty.
    RainMan_PNW and TRDFerguson like this.
  18. Oct 10, 2024 at 7:37 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Our fearless leader? Lol
    TRDFerguson likes this.
  19. Oct 10, 2024 at 7:38 PM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Vizsla and TRDFerguson[QUOTED] like this.
  20. Oct 10, 2024 at 7:46 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Mater[QUOTED] and Vizsla like this.
  21. Oct 10, 2024 at 8:08 PM
    Vizsla
    Vizsla 2 = 2.5
    :notsure:
    Not sure if helpful, iirc Preece Precision makes the Powertanks and they sell their own at a lower price point.
    BiggHertz[QUOTED] likes this.
  22. Oct 10, 2024 at 8:36 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I put auxito leds in my wife’s 2016 accord maybe a year ago. Super impressed with the outcome. The car already had led strips and led fog lights so it matched everything out. The headlight housings have a projector type setup. I’ve been in front of it while driving and it’s definitely not blinding. Looks stock IMO.
    vmkeith[QUOTED] and HulkSmurf14 like this.
  23. Oct 10, 2024 at 8:40 PM
    JrJrOffroad
    JrJrOffroad Somewhere in the west
    Anthony
    Monument, CO // Cave Creek, AZ
    Me and the mad scientist that is my fab guy prepped the truck for my Moab trip this weekend. Was hoping to have more done before this trip but thats okay- excited to hit some actual trails finally with high clearance bumpers. Top of the world here we come :)
    Was hoping to have way more done to the truck before this trip but alas- lots didn't happen in time. Oh well!
  24. Oct 11, 2024 at 3:58 AM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    SWEET!!! THANK YOU SO MUCH!!! I habe a membership to Costco too so getting oil won't be a problem.
  25. Oct 11, 2024 at 4:00 AM
    Corndog123
    Sam
    Tennessee
    You don't say? At the dealer? Something is cheap at the dealer? Do tell. I'm not sure what I paid for the Wix element at Oreillys, I wanna say like 9 bucks or something.
  26. Oct 11, 2024 at 4:02 AM
    Corndog123
    Sam
    Tennessee
    NICE! Mine are starting to get hazy. Thinking of MAYBE doing the refurbishing but I don't know how much patience I have to sand it all out.
  27. Oct 11, 2024 at 4:02 AM
    Corndog123
    Sam
    Tennessee
    But what if I like blinding other drivers? Jk
    French Avocado likes this.
  28. Oct 11, 2024 at 4:05 AM
    Corndog123
    Sam
    Tennessee
    Nice! I've been thinking about getting a locker. I have one at the gym but it doesn't really do much for me when offroading.
    Do you like your ARB or would you do something different if given the chance to do it again?
  29. Oct 11, 2024 at 4:07 AM
    Corndog123
    Sam
    Tennessee
    I like that rear bumper. Been thinking of getting one like that myself. Still have the OE bumper. Doesn't really go with my ARB front bumper and the whole poor man's MRAP look I'm going for.....
    CaptRussia253[QUOTED] likes this.
  30. Oct 11, 2024 at 5:42 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    :bananadance:Paid off!:dancingbacon:
