  1. Oct 9, 2024 at 4:04 AM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    Filled it with gas, went fourwheeling. Filled it with gas again.
    The other day, I changed the oil, element and air filter. ONLY about 100 bucks.....good Lord stuff got expensive. And I did it myself to save money........
    ATV25 and Damie Street like this.
  2. Oct 9, 2024 at 4:10 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Buy OEM filters in bulk. You can find them cheap in 5- or 10-packs on Amazon and eBay.
    For oil, nothing beats the quality of Kirkland for the price. When it’s on sale, you can get 10qt for $30-33.
    My oil changes have cost me less than $40 each. And check out this thread for how well that oil holds up in a 185k mile 3UR.
  3. Oct 9, 2024 at 4:21 AM
    Alot of fake filters on Amazon and ebay, even being in Toyota packaging. Filters are cheap at the dealer.
  4. Oct 9, 2024 at 4:41 AM
    250000yota
    250000yota New Member
    Russ
    Berthoud, CO
    White 2015 SR5 Crewmax
    S&B intake, Dirty Deeds 8", Airlift airbags with Daystar contact cups, LED's everywhere including Diode Dynamics stealth front LED bar, Baja Design Squadron II's on CBI ditch light brackets, completed Diode Dynamics interior LED's. Full RCI skids with cat guards and sliders, Transfer flow 46 gallon tank. Radflo 2.5 IFP coilovers, Coachbuilder shackles, TRD rear sway bar. 295/70R18 Nitto RG's. Dobinson snorkel, softopper.
    Gotta love Amazon's control over that. I got bit by that years ago when I did knock sensors on my old truck. I bought and returned 3 times before I got a set of legit Aisin knock sensors and a pig tail for them.
    Corndog123 and French Avocado like this.
  5. Oct 9, 2024 at 5:10 AM
    Terndrerrr
    Music City
    6UR-FE
    I’ve bought them multiple times for myself and directed others to the same listings. Started with my 4Runner in 2017. Never once have I received anything but genuine OEM filters.
    People just need to actually check who they're buying from. And make sure they’re OEM.
  6. Oct 9, 2024 at 6:02 AM
    vmkeith
    vmkeith New Member
    Vince
    Clark County, Wa
    2014 Super White Tundra SR5 CrewMax 4x4
    Rhino Lining bedliner Rydonair 7" antenna 275/70/18 Pirelli Scorpion A/T tires Lund 5" Cab Length Oval Curved Tube Steps RealTruck Elevate FS Bed Rack Rhino-Rack Carriers RealTruck TruXedo Pro X15 Tonneau Cover Diode Dynamics SS3 LED Fog Light Kit Auxito LED Headlight Bulbs
    Did a headlight restoration, installed some Auxito LED headlight bulbs, and swapped out the old OEM Fog Lights with the Diode Dynamics SS3 LED Fog Light Kit, Amber Sport style. Comes with a wire harness for plug and play. Took all of 1 hour to install and adjust. Haven't done any night time driving yet, but will see how much improvement there is. Kind of skeptical about the LED headlight bulbs and have a pair of SilverStars to install if I don't like them.
  7. Oct 9, 2024 at 8:18 AM
    seydou
    seydou Distinguished Member
    Generally speaking, LED bulbs require a different lamp/reflector design to work properly and not blind other drivers
  8. Oct 9, 2024 at 10:34 AM
    Vizsla
    Vizsla 2 = 2.5
    ARB compressor rebuild. Last trip to elevation was enough for 1/2 of it, still ran but no air from that side. Much as I do not care for all things ARB, the built in redundancy is really nice to have.
  9. Oct 9, 2024 at 10:50 AM
    tjacob95
    tjacob95 New Member
    2014 toyota tundra limited
    What size tires are you running?
  10. Oct 9, 2024 at 11:21 AM
    DrRansom
    DrRansom New Member
    Utah
    Silver Sky 2021 SR5 Tundra 4WD
    275/60/r20. Nitto Grapplers, E rated. I found them used on Facebook marketplace along with the 20" wheels. I lost a couple MPG, but I also don't drive a lot. I'll probably replace the tires with something that can handle rain and snow better, but I do like the aggressive look of the current ones.
    Before
    After
  11. Oct 9, 2024 at 12:58 PM
    GLaDOS
    GLaDOS Engineer
    Central Oregon
    2014 Tundra SR5 Double Cab
    After I installed the auto headlamp dimmer switch, I realized I didn’t have the wiring harness to make it work with the sensor. So I made a custom wiring harness, installed it and everything just worked!
  12. Oct 9, 2024 at 5:10 PM
    Sleeper16plat
    Sleeper16plat New Member
    Near Vancouver
    2016 Silver Platinum
    TRD Rear Sway Bar Bilstein 6112/5160 Pop Lock, Kenwood MX 1057 XR, Pioneer amp/speakers/subs, Tech12Volt dual sub box
    looks much better!!
    DrRansom[QUOTED] and BR73 like this.
  13. Oct 9, 2024 at 5:18 PM
    Bayou Spartan
    Bayou Spartan New Member
    Black 2019 TRD PRo
    None
    GCS TRANS COOLER
  14. Oct 9, 2024 at 5:23 PM
    Terndrerrr
    Music City
    6UR-FE
    Added 1” Bora spacers in preparation for a new suspension setup that will require new UCAs. I had no idea that adding merely a 1” spacer would make my tires rub hard front and back of the wheel well. I guess I was just barely clearing all the way around before the spacers.
    Removed my mud flaps. Still have bad rubbing up front. Guess I’ll need the bumper shim.
    Or a new high clearance bumper. :notsure:
    RobertD and Mater like this.
  15. Oct 9, 2024 at 5:45 PM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    If you’re taking votes the high clearance bumper gets mine
  16. Oct 9, 2024 at 6:28 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    I'd like to buy one of these from you if you have any extras.
    RobertD likes this.
  17. Oct 9, 2024 at 6:45 PM
    RobertD
    Robert
    DFW, Texas
    I vote bumper as well. Or you could do the Viper Cut mod. I think that would provide the clearance you need. @TRDFerguson may have better input into if it will provide clearance though. I'm just guessing.
  18. Oct 9, 2024 at 6:56 PM
    Terndrerrr
    Music City
    6UR-FE
    Yeah, mine too. Does anyone have the “other” @STravis front bumper? The one that requires no cutting. Guess I’ll search my watched threads for the 2.5gen bumper thread…
    CaptRussia253, Mater and RobertD like this.
  19. Oct 9, 2024 at 6:59 PM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    I think it’s early on in Travis’ build thread
  20. Oct 9, 2024 at 7:33 PM
    STravis
    STravis SOB Fabrication Vendor
    Travis
    Ruidoso, NM
    17 TRD Pro CM, 08 Supercharged Single Cab
    Here are some photos of our standard replacement bumper.
    PXL_20230329_210114593.jpg PXL_20221121_230753284.PORTRAIT.jpg PXL_20220914_194427791.PORTRAIT.jpg PXL_20220826_175940953.PORTRAIT.jpg PXL_20220819_155310869.PORTRAIT.jpg
    Tundra805, RainMan_PNW, Jego and 16 others like this.
  21. Oct 9, 2024 at 7:34 PM
    STravis
    Travis
    Ruidoso, NM
    @CaptRussia253 has one of our bumpers as well. He may have some insight for you.
  22. Oct 9, 2024 at 7:44 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Oh mine next!
    Vizsla[QUOTED] and HulkSmurf14 like this.
  23. Oct 9, 2024 at 8:05 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Yup got the OG bumper and still love it. It’s nice not having to cut anything to install it. I also think @STravis new high clearance front is freakin awesome! I wouldn’t hesitate to order either front. Also, add his high clearance rear to your list. The only thing I regret is ordering the rear without the tire carrier. So stupid :(
  24. Oct 9, 2024 at 8:20 PM
    RobertD
    Robert
    DFW, Texas
    What's the small light next to your fog? Is it set up like a ditch light just lower?
  25. Oct 9, 2024 at 8:33 PM
    CaptRussia253
    Ruslan
    Yes pretty much. @STravis added a second hole in the bumper to allow for a Baja design s1 light. Unfortunately I’m poor and ordered some cheapo lights off Amazon :rofl:
  26. Oct 10, 2024 at 4:49 AM
    Terndrerrr
    Music City
    6UR-FE
    I see you, too, are mudflap-less
  27. Oct 10, 2024 at 6:23 AM
    CaptRussia253
    Ruslan
    :rofl::rofl::rofl:
    Can't use the fronts with the 37s haha and the rears had to go with the new high clearance bumper. I am trying to integrate a larger mud flap in the rear for the winter and figure out how to install it on the bumper support reinforcement bracket.
  28. Oct 10, 2024 at 6:46 AM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    If you want to make your truck hideous to look at there's rock tamers :anonymous:
    https://www.amazon.com/Rock-Tamers-Mudflap-System-Stainless/dp/B006M9VIRM?th=1
  29. Oct 10, 2024 at 7:06 AM
    CaptRussia253
    Ruslan
  30. Oct 10, 2024 at 7:12 AM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Oh yeah those are sick! The rock tamers were a total joke, those things make my eyes bleed lol
