General Supercharger Thread
  1. Oct 9, 2024 at 10:07 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I have a '97 BMW with numerous vacuum lines hidden under the intake, it took a week of fiddling with a smoke machine to find all the leaks. It was under 80 bucks & worth every cent.
    It's on sale right now for 70.
    https://www.amazon.com/gp/product/B0C7MKZPK3?ie=UTF8
  2. Oct 9, 2024 at 10:17 AM
    Grenades4Bacon
    Grenades4Bacon New Member
    2019 Tundra
    i looked at that one - and, did buy a smoke leak detector… but, it really didn’t help. I found all the leaks so far with just the pressure test, my ear and soapy water.
    prior to that i was using brake cleaner & propane. But, my leaks have only been apparent with the pressure testing.
  3. Oct 9, 2024 at 10:56 AM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Just ordered to track down the elusive "small evap leak" on the JK I've been dealing with for years.
  4. Oct 9, 2024 at 11:57 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Well I've done 50 miles so far with the 95mm throttle body with zero issues. Neighborhood, stop lights, interstate, drive throughs, launch from a stop, etc. I still can't tell it's there besides the intake noise being slightly different.
    I'll get a few more miles and some longer trips on it, and then build out this second prototype. Right now I honestly wouldn't recommend it to anyone, there are zero downsides and zero upsides so far :D I'm hoping one of the guys making big power can get an apples to apples comparison of the second 95mm versus a stock unit, because it's either a total useless upgrade or my truck just doesn't make enough power to see any benefit from it--which also gives some idea of if a RCF TB or porting a TB is of any use, since this absolutely dwarfs those options.
  5. Oct 9, 2024 at 12:01 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Richard holdner and his blower data would say otherwise on having a larger TB/intake. Bigger is always better. We're ready for these when you're ready!!
  6. Oct 9, 2024 at 12:02 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    If you want I can run it 4.5 inch intake and maybe send it off to @armyoffoo to see what it can do. I believe porting the RCF can only go to 86mm safely.
    Oh yeah, @reywcms too withvthe 5 inch intake...
  7. Oct 9, 2024 at 12:07 PM
    snivilous
    SW UT
    I do wonder if the intake or the snout is the limiting factor, you have to figure I have a completely stock (besides the pulley) Magnuson 1900, I don't even have the extra holes drilled in the intake box. I think I'll end up porting the snout and making an intake box (few people have asked for that too) just to see if I notice any gains. But I think for your average person looking for a cost effective way to get more juice out of the blower, the TB isn't going to make a difference. It's one of those modifications that's pretty far down the priority list after a pulley, larger intake, etc.
    I'm still thinking I'll send it to you, with you already having a 95mm and making a ton of power that gives a lot of extra data points, plus we know you're open to tweaking things and blowing stuff up :p
    ZPhilip, Wynnded, e30cabrio and 2 others like this.
  8. Oct 9, 2024 at 12:10 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I wouldn't doubt that the box and snout are limiting factors. Make a new box let's do that lol
  9. Oct 9, 2024 at 12:12 PM
    snivilous
    SW UT
    Hell all I have is a catback exhaust too, so when it comes to flow improving mods I've done nothing but now have a huge throttle body and that's it hahaha
  10. Oct 9, 2024 at 12:41 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    LOL
  11. Oct 9, 2024 at 12:52 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    No noticeable drop in PSI/restriction?
  12. Oct 9, 2024 at 12:54 PM
    snivilous
    SW UT
    Nothing conclusive, I haven't seen the truck make the full 8psi, but that's not unusual. I would expect the psi would go up if there was less restriction since it's a change pre-blower?
  13. Oct 9, 2024 at 12:59 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    PSI up pre blower psi down post blower
    Silver17, e30cabrio and Saltyhero13 like this.
  14. Oct 9, 2024 at 1:16 PM
    kos221
    kos221 New Member
    2007 4X4 DC
    Are you saying that your 0-60 time is 8 seconds or higher?
  15. Oct 9, 2024 at 1:40 PM
    e30cabrio
    I had several more runs, got a new phone, this is all that transferred. I think my best was 8. It's a pushing the button & taking off thing.
    These were on a runway at a private airport.
    M3Tundra-JK likes this.
  16. Oct 9, 2024 at 4:28 PM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    I timed my truck 0-60 the other day and the results were very disappointing. Apparently being super heavy and at high elevation is bad for performance. :frusty:
    Wynnded, Mdl and snivilous[OP] like this.
  17. Oct 9, 2024 at 4:32 PM
    j_supra
    Manitoba, Canada
    2008 Tundra Limited
    20" Vision brawl, 33.5" Toyo at3s, Bilstein 5100s, LTH, custom exhaust, AEM filter, TRD intake pipe, Joying HU, hertz components and sub, Rokblokz XL, AVS visors
    What button you talking about? The reset button on dragy? You don't need to reset then launch, the dragy only starts once you start moving. Regardless of reset or not. Reset just clears the screen basically. At least thats how mines been working.
    Silver17 and Mdl like this.
  18. Oct 9, 2024 at 4:41 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Incoming traction...gotta put the power to the wheels.
  19. Oct 9, 2024 at 4:45 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I also think I need to ditch the 400 cell cat converters and go back to some new 200 cell. I was passing a car on the highway and thought I saw my psi gauge hit 16psi. It was in the red as I have it setup on my older AEM failsafe.
    Will have to keep an eye on it!
    I think I set it up at 14psi to how red led shows on the dial, will double check...
  20. Oct 9, 2024 at 4:49 PM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    I'm lucky that my go to exhaust guy takes the time and do it right with v-bands, so the new exhaust has v-bands throughout.
  21. Oct 9, 2024 at 4:52 PM
    e30cabrio
    Maybe that is my problem, didn't read the fucking manual. I have been pushing the button.
  22. Oct 9, 2024 at 5:01 PM
    Saltyhero13
    I might be mistaken but I thought the expectation is the inlet PSI drops when up sizing but only if the TB is the restriction; so if the rest of the intake is smaller than TB nothing will be gained. Not sure where PS was referencing Boost PSI in their experiments.
    reywcms[QUOTED] and Silver17 like this.
  23. Oct 9, 2024 at 5:07 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Here’s what you’re referencing. They’re referring to the inlet side as “negative psi” in regards to the restriction which is a goofy unit and would be better understood as Inches of Mercury vacuum. The more vacuum there is the more of a restriction it is in the intake side. Like Rey said, less restriction on the intake = more boost and less restriction on the exhaust = less boost.
    https://www.prospeedautosports.com/...ake-and-rcf-throttle-body-adapter-kit-testing
  24. Oct 9, 2024 at 5:15 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    This ^
    Saltyhero13, Silver17[QUOTED] and Mdl like this.
  25. Oct 9, 2024 at 5:22 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Nice pics!
    HulkSmurf14 likes this.
  26. Oct 9, 2024 at 5:36 PM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    yeah i think. im feeling that after the 3" exhaust. but it still hits almost 10 but doesnt quite feel like it like it did with 2 1/4
  27. Oct 9, 2024 at 5:53 PM
    Silver17
    Eastern PA
    You mean it had more power with 2 1/4”? I could see it dropping low end torque with 3” but picking power back up in mid to high end. Im sure it’s probably easier to notice the low end torque loss vs observing the high end power gain when driving on the street especially.
    Land Bruiser, HulkSmurf14 and Mdl like this.
  28. Oct 9, 2024 at 7:07 PM
    NatesNightMare
    Pinetop Az
    yeah i can feel it some at low but i honestly dont think its much but the rest doeent seem like before maybe because of all the noise now :rofl::rofl:
  29. Oct 9, 2024 at 7:09 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Should’ve gotten that spd system….
  30. Oct 9, 2024 at 7:12 PM
    snivilous
    SW UT
    I tap the shit out of the reset button before launching. Applying brakes and then throttle to load it up seems to move the truck enough to trigger the Draggy I've found, so tapping reset repeatedly to make sure it doesn't premature go until right before I let off the brake solves that.
