Welding on tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by 19tundramax, Oct 9, 2024.
  1. Oct 9, 2024 at 12:09 PM
    19tundramax
    19tundramax [OP] New Member
    2019 tundra crewmax
    6" lift Coldair intake Catback exhaust
    Hi everyone I'm Jeff and am new to this forum I recently had my exhaust hanger welded as it was broken and when my truck came out of the shop the signals and hazard light stopped working. The shop did not disconnect the battery while welding on my truck but say it was not caused by the work they performed, they claim it is just a coincidence. Would like everyone's input on this matter.....thanks in advance
  2. Oct 9, 2024 at 12:51 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Debatable. It's generally good practice to unplug the battery when welding, with that said I've never done that and welded tons of things on vehicles and never had an issue, but I make sure to ground near where I'm welding with the thought process being the current won't flow through the rest of the vehicle.
    If it left their shop with the issue and went in fine, it's obviously something they did though. Hopefully it's as simple as a fuse is blown.
    centex and reywcms like this.
  3. Oct 9, 2024 at 12:54 PM
    19tundramax
    2019 tundra crewmax
    It turns out to be the combination meter and its a total of $1732.37 to fix and the shop keeps saying it's not them...
  4. Oct 9, 2024 at 12:56 PM
    snivilous
    SW UT
    Whether it's welding or something else they screwed with, who knows. They can claim it's a coincidence, but that'd be a hell of a coincidence that the electronics just happened to shit themselves the same time they touched it.
    BravoDeltaRomeo likes this.
  5. Oct 9, 2024 at 12:58 PM
    19tundramax
    2019 tundra crewmax
    That's what I said and they are not going to do anything for me....straight from the gm
  6. Oct 9, 2024 at 1:02 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    I'm not saying it is impossible, but I have to believe that something else went wrong and you don't need a new instrument cluster for turn signals and hazards not working...
  7. Oct 9, 2024 at 1:03 PM
    19tundramax
    2019 tundra crewmax
    I brought my truck right to Toyota and that is the diagnostic....
  8. Oct 9, 2024 at 1:04 PM
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    Any chance you can find wires near their welds that have insulation melted by weld spatter or heat?
    That would be the only way to get them to consider it.
    Shops get a lot of people trying to scam them with "it was fine before you touched it" type comments. They don't know who is true and they have to look out for their business.
  9. Oct 9, 2024 at 1:05 PM
    Totmacher
    Daniel
    West TN
    Some
    Doesn't necessarily mean they diagnosed it correctly. I have trust issues with dealers though. Check all your fuses yourself if you can.
  10. Oct 9, 2024 at 1:11 PM
    19tundramax
    2019 tundra crewmax
    I've checked everything from fuses to bulbs and resistors. It's the cluster when I signal it has the rapid flashing sound but doesn't light up on cluster and when I put hazards it clicks and doesn't light up as well so pretty certain it's the cluster plus that's the code that comes up when scanned as well
  11. Oct 9, 2024 at 4:27 PM
    NotSpongeWorthy
    NotSpongeWorthy i member
    Ricky
    Valkenvania, PA
    2020 Tundra SR5 TRD Sport Crewmax
    Furry steering wheel cover
    All power sources should be disconnected when welding on anything, so it’s nice that they admitted that they didn’t disconnect your battery. You can get rogue current at any time during welding, which is going to travel through your frame. Any electronic component that are energized can overdraw and potentially get fried.
    it could of been them, could of been coincidence. I would crack it open and see if any contacts are burnt. You could also take it to an electronics shop and have them look it over, they should be able to tell you exactly what happened.
