90k service = $2678.65
Discussion in '2.5 Gen Tundras (2014-2021)' started by Bammer, Oct 9, 2024.
  1. Oct 9, 2024 at 3:47 AM
    Bammer
    Bammer [OP] I'm disinclined to acquiesce your request.
    Monroe, CT
    SOOOOO, long story, that will end up being too long, Had big plans to do most if not all myself. Having my father (85 yo) and FIL (92 yo) in Florida and both smack dab in line ,Tampa & Daytona, I thought it best to just have a local garage do what needed doing,so I can go at moments notice. Toyota friendly place with Tech stream and knowledgeable mechanics on transmission drain & fill. so here is what I got for my money, genuine Toyota parts used, except oil.
    Front pads & rotors and new pins
    Rear pads & rotors
    Front diff oil change - 2 new plugs and washers
    T- case oil changed - Ravenol 75w ,supplied by me
    Rear diff oil change - 2 new plugs and washers
    Power steering flush and fill
    Transmission drain & fill
    Flame on ! :bananadead:
    I'm a satisfied customer and have found a trusted mechanic. :D
  2. Oct 9, 2024 at 3:59 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    Half the brakes, the other half the service?
  3. Oct 9, 2024 at 4:02 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    In my experience Toyota brake pads have fitting problem. Front pad I had to file slightly. Rear ones I could not install whatsoever. Bought Bosch pads, they fit just right. Next time front pads will be Bosch as well.
    Use Ravenol for the diffs as well.
    You can actually do everything yourself. Nothing you listed requires any significant amount of wrenching.
  4. Oct 9, 2024 at 6:20 AM
    gnatehack
    gnatehack New Member
    Middle of Minnesota
    13 SR5 5.7 4x4 Bench
    Up to date maintenance
    If you are satisfied and ready to help your people, that is all that really matters.
  5. Oct 9, 2024 at 6:31 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Never heard of having to file your brake pads… :anonymous:
    Oey12, Joe333x and Tunrod like this.
  6. Oct 9, 2024 at 6:33 AM
    smokint
    smokint New Member
    2017 1794 2002 Tacoma
    Worth every penny. Spend your time with the relatives.
    I took my ‘07 Tundra to the dealer for all service, got to 120K never had a prob, and traded it for a new one
    Now I have more time, and am doing the service myself…but it takes time and tools
    It’s a great feeling having all that done, knowing your pride and joy is in good health
    :thumbsup:
  7. Oct 9, 2024 at 6:39 AM
    OK, $2K+ for brakes and fluids is robbery. Even worse when you supplied some of the fluids. That being said, labor is high these days, is what it is. Convenience can be expensive.
  8. Oct 9, 2024 at 7:04 AM
    Tyman
    Tyman Isaiah 41:10
    Tyler
    Indiana
    2020 Tundra Sport 4wd MGM
    Was that your first set of pads and rotors?
  9. Oct 9, 2024 at 7:17 AM
    smokint
    smokint New Member
    It is high…my dealer labor is $150/hr
    Was quoted $800 for front brakes (rotors/pads) from dealership
    Can buy these parts online for $300…so about 3 hrs labor —> ~ $800
    Still, time is $$$ , and even a private shop is expensive
    Black Wolf and PermaFrostTRD like this.
  10. Oct 9, 2024 at 7:25 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    That price is absolutely insane, must've had a 200% going out of business deal. Good luck to your family!
  11. Oct 9, 2024 at 7:47 AM
    Bammer
    Monroe, CT
    Actually no,
    fronts were done at the dealer , rotors turned and new pads @50k
    rear, new pads and rotors @ 60k
    My wife says I drive too fast, which I must now agree with.:rolleyes:
    Tyman[QUOTED] likes this.
  12. Oct 9, 2024 at 7:48 AM
    Bammer
    Monroe, CT
    Rotors were 2 something, I'll have to look at the bill again.
  13. Oct 9, 2024 at 7:49 AM
    Bammer
    Monroe, CT
    2 quarts of Ravenol is all .
  14. Oct 9, 2024 at 9:02 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Not bad, I was quoted 1000 just for a trans service at my local steeler. I just did it myself with a pump and a collection bucket.
    WILLINH, Bammer[OP] and smokint like this.
  15. Oct 9, 2024 at 11:25 AM
    AZBoatHauler
    So.Arizona
    :eek:
    Black Wolf likes this.
  16. Oct 9, 2024 at 11:25 AM
    AZBoatHauler
    So.Arizona
    For almost $3k they could have at least done the spark plugs and flushed the coolant.
  17. Oct 9, 2024 at 11:34 AM
    Rotated the tires. Oil change. Maybe a new windshield……
    Azblue and Black Wolf like this.
  18. Oct 9, 2024 at 1:33 PM
    excelw
    excelw AfRo Samurai
    WW
    AB, Canada
    2019 Toyota Tundra TRD Pro (Midnight Black)
    leather wrap steering wheel, front window tint, ceramic coating, AMP research power steps, Toyo open country at3 35”x11.5x18, Volk Racing te37xt 18 9.5 0 offset, Rays formula II lug nuts Warn fender flares, Coachbuilder +3, bilstein 8112 front and 8100 double bypass rear, Kenwood excelon 996xr stereo +7” speakers Westcott designs front lift, RAS rear leafs, yota leds, NSV Lightbar
  19. Oct 9, 2024 at 1:45 PM
    KroppDuster
    Here. There. Everywhere.
    Bilstein 5100s
    I'm guessing it was a full fluid exchange/flush vs just a drain & fill? If it was just a D&F, that's lunacy.
  20. Oct 9, 2024 at 2:06 PM
    Rodtheviking
    Vancouver, WA
    Sequoia
    Yes, full service.
  21. Oct 9, 2024 at 3:29 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    Toyota Dealer in Manchester NH is $200 per hour. That was 1 1/2 years ago.
  22. Oct 9, 2024 at 3:43 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Filing down the edges because it’s a tight fit in the caliper bracket. Or wire brush out rust buildup if you live up north.
  23. Oct 9, 2024 at 3:53 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Wiring brushing I can understand, but fitment shouldn’t require you to actually take a file to the edges… unless if you just don’t compress the pistons all the way, I don’t see why even brake dust buildup can cause it.
  24. Oct 9, 2024 at 4:02 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Have you replaced your pads yet?
  25. Oct 9, 2024 at 4:48 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Happy ending included?
    AZBoatHauler and Azblue like this.
  26. Oct 9, 2024 at 5:03 PM
    Azblue
    The Dirty T ( ^_^)_且
    That's the exact opposite for me. Doesn't matter which of our vehicles I'm working on, Toyota pads always fit perfect. However, whenever I have tried aftermarket, they always fight me.
    Damn, last time I had the local stealership do mine it was around $240, including the 4 qts of WS.
    pvn.beluga likes this.
  27. Oct 9, 2024 at 5:44 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Yep. Done multiple vehicles numerous times and never once had I had to bring out a file to get it to fit correctly.
    I don’t believe a multi billion dollar corporation would not go above and beyond in their R&D to ensure that OE parts would not fit perfectly.
    It’s clearly user error in which you cannot fit your pads. Brake dust shouldn’t be a reason where your pads wouldn’t fit and if you’ve got a ton of rust around your calipers when you change out your pads, I believe the problem lies far beyond your pads not fitting correctly if in fact that it’s the correct part number for your vehicle.
    Ceezurin likes this.
  28. Oct 9, 2024 at 5:53 PM
    trucksareforgirls2
    trucksareforgirls2 New Member
    Northeast USA
    2020 Voodoo Blue TRD Off-Road
    I would avoid that stealership, they are SUPER sleazy!!
    WILLINH[QUOTED] likes this.
  29. Oct 9, 2024 at 6:35 PM
    389 24/7
    389 24/7 125k on the gen3
    Oregona
    2022 TRD OR
    Nada
    Over the past few months I did all the same service myself plus serpentine belts on my gen 3 tundra around 100k mileage
    At 110k miles now
    Parts cost was $900
    Labor was zero
    $2600!
    That's 5% of the cost of a new tundra
    Man, inflation sucks balls
  30. Oct 9, 2024 at 6:42 PM
    smokint
    smokint New Member
    This is the way for sure
    and they overcharged the OP
    But his rig is tuned up now
    I know where he’s coming from , cuz I’ve been bent over many times, no Vaseline , but just didn’t have time or expertise to do it
    Hopefully those guys are competent and did a good job
    I hope he gets a lot more quality time with his dad and father in law
    I miss my dad every day
    Bammer[OP] and Roborob70 like this.
