SRS light on continually
Discussion in 'General Tundra Discussion' started by dondino, Oct 7, 2024.
  1. Oct 7, 2024 at 7:36 AM
    dondino
    dondino [OP] New Member
    don
    2007 Tunda Crewmax
    Maybe it's just coincidence but a couple weeks ago I gave a guy a jump with my 07 CM and a few days later my SRS light came.on and stays on continually. The truck is at the shop getting an oil change right now, and they are going to hook up a reader to it to see what is causing the problem. I'm aware that there is an air bag in the steering wheel and that the passenger seat has some type of sensor under it to detect when someone is sitting in it. If it codes.out to either of these two faults, how easy is the fix and is there a way to bypass the whole system with some type of resistor as a fix? Frankly I could care less if the thing even works, but the great state of Pennsylvania will have other ideas come next inspection. Appreciate any help.
  2. Oct 7, 2024 at 7:52 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Do your steering wheel controls work? Could be as simple as the clock spring went bad, mine shit out a week ago.
    baraynavab likes this.
  3. Oct 7, 2024 at 10:41 AM
    dondino
    don
    2007 Tunda Crewmax
    Got a call from the garage. Error code indicates clock spring mechanism. I'll live with it.
    WILLINH likes this.
  4. Oct 7, 2024 at 10:52 AM
    snivilous
    SW UT
    Just food for thought, it's like a $30 (unless you get OEM) and 15 minute fix with basic tools. Two T30 torx screws, a 19mm nut for the steering wheel, then you just unplug and replug a handful of things.
  5. Oct 7, 2024 at 6:28 PM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    2007 Tundra CrewMax 4x4 5.7L V8
    Yeah its cheap.. i got my clock spring cheaper than what @snivilous mentioned.. iirc mine was $15 shipped... very high likelyhood it came from the same factory.. make sure you mark your steering to pinion alignment via a marker and then swap it out.. easy swap.. a few videos are also on youtube.
  6. Oct 9, 2024 at 1:31 AM
    dondino
    don
    2007 Tunda Crewmax
    Ok thanks I'll take a look and try it myself.
