Preparedness for engine failure
Discussion in '3rd Gen Tundras (2022+)' started by Jibber82, Oct 7, 2024.
  1. Oct 7, 2024 at 10:10 AM
    Jibber82
    Jibber82 [OP] New Member
    Does anyone have a solution for a temporary alternative source of heat in the event of an engine falure that occurs during below freezing temps in an area outside of cell phone service? Knowing that my engine could go at any time, this senario worries me as I drive in remote-ish areas in the Northeast with long stretches outside of cell phone service. I want to be prepared for the engine going at the worst possible time.
  2. Oct 7, 2024 at 10:42 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Some of the new iPhones have an SOS feature that uses satellites in areas where there is no cell service. Maybe a propane heater could be used but the carbon monoxide would have to be dealt with. Sort of tough to deal with the heat without a source of energy or power. Perhaps some warm clothes and a emergency kit?
    AZBoatHauler likes this.
  3. Oct 7, 2024 at 10:46 AM
    AZBoatHauler
    So.Arizona
    The satellite connectivity on the new iPhones was enough for me to spend the cash. I’ve already used it a few times - amazing tech and even more amazing there isn’t any additional charge for it at this time.
    Assuming you don’t have a new fancy iPhone, I have a ham radio mounted in the truck and a repeater book app that lists the frequencies of the closest repeater tower. All data is stored on the device and it uses your GPS signal so it doesn’t need cell service to work.
  4. Oct 7, 2024 at 10:57 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    These burn hell hot: https://www.amazon.com/gp/product/B007HR0QFI I use 2 or 3 of them for sleeping in unheated bed+cap, in old 0F sleeping bag. Was a good sleep in a negative single digit.
  5. Oct 7, 2024 at 10:57 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
  6. Oct 7, 2024 at 10:58 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Garmin InReach works, too. About $15/month. Lasts week+ on one charge.
  7. Oct 7, 2024 at 11:05 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    If you are stuck for a longer time, or with too many people for your blankets/heating pads supply, you need to be able to make a fire...
    A few lighters in glove box at any time. A foldable handsaw, good hatchet (with wooden handle preferably) and some beefy knife. For knife I have a KA-BAR, which use for splitting the wood mostly. Lighting fluid or sold fuel tablets do help.
    https://www.amazon.com/gp/product/B08PW5GD4S
    https://www.amazon.com/Husqvarna-13-Wooden-Handle-Hatchet/dp/B07NPF9SDN
  8. Oct 7, 2024 at 12:49 PM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    Is this your first time dealing with freezing temps? You’re worried about an engine that may never fail. Keep blankets with you like you would with any vehicle.
    22whatwedo, Nm6300'asl and vtl like this.
  9. Oct 7, 2024 at 12:51 PM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    Double and triple likes
  10. Oct 7, 2024 at 12:53 PM
    daverxa
    daverxa New Member
    Dave
    2024 White Tundra Limited TRD Offroad & TRD Lift
    Leer 100xl, ggoffroad DRV camera relocation, Decked drawer system, BF Goodrich TKO3 275/65R20, Diode Dynamics Fog lights, Go Rhino Dominator D6 Running Boards,
  11. Oct 7, 2024 at 12:55 PM
    Savagesawyer
    Savagesawyer New Member
    Beaverton, OR
  12. Oct 7, 2024 at 1:01 PM
    MaineTundy
    MaineTundy 285/65/20 KO2- 34.6”. 35’s fit stock!
    2012 Rock Warrior / 2024 Limited CM 6.5, TRDOR
    Tow Hooks! 285/65/20 KO2 Yakima Rack Carlinkit Carista tweaks
    If there isn’t already a hole in your pan from bearing, just drop the plug and ignite. It will burn a long time and help WILL come.
    Welcome.
    TundraDan723 likes this.
  13. Oct 7, 2024 at 1:17 PM
    SrgJigPog
    SrgJigPog New Member
    '23 Tundra Limited Trd Off Road
    I have been using an Inreach device too now for a number of years in Labrador. Lots of remote km’s! I pay 45 a month in Canada. I just tried the IPhone satellite this week and it worked. Really convienent.
  14. Oct 7, 2024 at 1:26 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Yes. It will save lives. I was on the verge of pressing a SOS button on my InReach this August in northern Quebec =) But I made it on my own.
  15. Oct 7, 2024 at 1:27 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    That may end up as a reason of the engine blowing up.
    Savagesawyer[QUOTED] likes this.
  16. Oct 7, 2024 at 1:27 PM
    JRS
    JRS New Member
    2012 DCLB
    Worth noting that Garmin recently allowed linking watches as the inReach device to pair with your phone (I think), which allows you to bypass purchasing the separate communicator. Can't confirm because I don't do anything cool anymore and don't have the service.
  17. Oct 7, 2024 at 1:36 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    Awesome solutions above but easiest is to jump ship and purchase a certified 2.5 gen Tundra ... and I'm serious.
  18. Oct 7, 2024 at 2:44 PM
    Savagesawyer
    Beaverton, OR
    Wait? This isn’t concluded? Fine, Scotch works as well. None of that Canadian bs, however :fistbump:
    Retired...finally likes this.
  19. Oct 7, 2024 at 3:01 PM
    NotSpongeWorthy
    NotSpongeWorthy i member
    Ricky
    Valkenvania, PA
    2020 Tundra SR5 TRD Sport Crewmax
    Furry steering wheel cover
    Get yourself a freezer suit from refridgewear and keep it in the truck. Their -60 rated suit will keep you so warm that you’ll end up unzipping half of it.
    This is my experience at-least with using them in -10 degree meat storage buildings.
  20. Oct 7, 2024 at 3:05 PM
    mmasse
    mmasse Digital Forensics Cowboy
    Idaho
    2022 Magnetic Grey Tundra
    I hear that NASA might be selling some slightly used space suits for 22 million
  21. Oct 7, 2024 at 3:21 PM
    Retired...finally
    Boeing has an even better deal but don't expect to be rescued by SpaceX.
  22. Oct 7, 2024 at 4:05 PM
    Mr Badwrench
    Mr Badwrench New Member
    Might as well load up the wife or girlfriend too, or both.
  23. Oct 7, 2024 at 4:10 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    They'll finish his bourbon while he tries to turn the seized crankshaft over.
  24. Oct 7, 2024 at 4:13 PM
    Fxclm5
    Fxclm5 New Member
    Awesome solution Toyota, are the other 102k customers gonna hafta jump through your weird hoops of getting a rental?
    I'm still more butthurt and getting made fun of by everyone at work that my brand new Toyota (reliability King) has a 102k motor recall, so much for reliability after this run
  25. Oct 7, 2024 at 4:28 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    The recall documents provide the method for owners to get rentals and that would apply if these owners were not comfortable driving the truck before the recall. Check out the documents posted on the NHTSA site and all the details are there for the rental procedure. Take that to the dealer and show them how easy it is to get a rental.
    I am not too sure why this wouldn't be followed if the dealer or Customer Service knows about it.
    Up here we don't get rentals or loaners unless we fight for them and that usually means a Prius or Corolla.
