Bringing it back from the brink of death
Discussion in '1st Gen Builds (2000-2006)' started by Primakluk, Oct 6, 2024.
  1. Oct 6, 2024 at 1:42 PM
    Primakluk
    Primakluk [OP] New Member
    2006 DC SR5 4x4
    Thanks to everyone on this forum I made a 10 hour drive home with my new first Gen safely without completely breaking down.
    I just bought a 2006 tundra double cab with 342k miles on the body and 148k on the motor.
    The Arizona sun has not been nice to it, but the frame is immaculate and there are not active leaks or mechanical issues… so I thought. I got it for cheap so I have a budget to refresh some stuff.
    First things first, the ac stopped working twice which prompted me to find two issues that would have left me somewhat stranded.
    The serpentine belt was rubbing through the lower radiator hose.
    And that made me think of those poor suckers with the camshafts sensor wires rubbed through. So I pulled over and found I was just starting to show wire on my own. So I’ll be re-routing that wire. I’m putting together my list of repairs, including OEM LBJ’s. I’ll keep pictures coming as I do the repairs planned.
  2. Oct 6, 2024 at 2:01 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Not too shabby from that pic - congrats!
  3. Oct 6, 2024 at 2:25 PM
    Welcome and congrats!
  4. Oct 6, 2024 at 2:28 PM
    Congrats, should a said something, I would have bought you lunch
    Mater likes this.
  5. Oct 6, 2024 at 2:45 PM
    Primakluk
    2006 DC SR5 4x4
    I was in a hurry to get back, felt like I had a ticking time bomb. lol. I have family down there so I visit a few times a year. I’ll be bringing it back down for trips, I’ll let you know!
  6. Oct 6, 2024 at 2:48 PM
    Try and plan one at the end of April and enjoy some sites…..
    https://www.tundras.com/threads/tundras-to-sedona-2025.148431/
  7. Oct 6, 2024 at 7:43 PM
    Primakluk
    2006 DC SR5 4x4
    Well upper ball joint and upper control arm bushings need to be done at a minimum. A lot of play.
    plans for this week are:
    Bilstein 5100 with 2885 coils.
    1” diff drop
    Oem recall LBJ kit
    Serpentine belt
    Add a leaf
    Upper ball joint and bearings
    Possibly UPC or just the bushings haven’t decided.
    Rear drums and shoes
    Rack and pinion is on the docket, but it isn’t officially leaking, just wet boots.
    Anything else I should look into at the same time?
  8. Oct 11, 2024 at 7:00 AM
    Primakluk
    2006 DC SR5 4x4
    While waiting for the rest of my suspension parts I got the rear brakes done. The shoes were metal on metal with broken pieces floating around. New shoes, drums and cylinders. Next up full front end rebuild.
    Tundra family likes this.
  9. Oct 13, 2024 at 12:26 PM
    Primakluk
    2006 DC SR5 4x4
    Anyone know that this wire is and if it’s routed right? After actually getting in there it’s not the crank sensor wire like I originally thought.
  10. Oct 17, 2024 at 7:32 PM
    Primakluk
    2006 DC SR5 4x4
    All I have left is the rack and pinion replacement. One of the studs is stripped so I’m removing that tonight and hoping to find one tomorrow.
    Front suspension, bearings, lower ball joint (OEM), JBA UCA, Napa CV axles, new inner and out seals, and new brakes.
    I had OEM cv’s that I will rebuild with the Porsche boots and have on hand for when the Napa ones fail.
    Soon I’m on to electrical issues with the dome lights and cargo lights randomly turning on. PO pulled the dome fuse and I didn’t realize it until I took it in for emissions.
  11. Oct 23, 2024 at 2:00 PM
    Primakluk
    2006 DC SR5 4x4
    Well I got it rolling again Sunday. Found a cheap topper and got an alignment as well.
    Rear brakes are not adjusting with the ebrake so I’ll be tearing those back apart and replacing some hardware and a new brake cable. (Adjustment starting with the bell crank)
    I greased my drive line and suspension parts, and I noticed a good improvement. Still have a chirp in reverse and noticed the carrier bearing is probably original. Got that and the rear lift left to do.
    Todays plan is flipping the radiator hose (yes it upside down and rubbed on the pulley/belt) flushing the fluid and putting the pink stuff in. I will try to get the bumper mounts bent back as well.
    The Black Mamba, 68 RS/SS and Weagle like this.
  12. Oct 31, 2024 at 6:08 PM
    Primakluk
    2006 DC SR5 4x4
    Well finished the Add a Leaf and rear 5100 damper today along with a new carrier bearing. I shimmed the carrier bearing down 3/8” and it seems to look pretty good on the angle. Safe to say the carrier bearing was donzo.
    Added the leaf and didn’t remove the bottom leaf and I got about 2.25” in rear lift. I assume some of it will settle.
    68 RS/SS and Dustbox like this.
  13. Dec 1, 2024 at 9:10 PM
    Primakluk
    2006 DC SR5 4x4
    So update on fixes:
    I have replaced the power steering hoses, they were the culprit for my slow leak.
    I replaced my radio with a crutchfield special. My adapter board (crux) ended up being defective and got a new unit and it works flawlessly now.
    Put in a cheap back up camera as well. I’ll probably replace it with something nicer down the road.
    I did put the usb input below the climate controls, slick Amazon purchase I found on these forums.
    I found a missing transmission pan bolt and replaced it and torqued them all down (4.4 Nm) some were hand loose.
    Replaced all my o2 sensors (I had a code). Going to try to do a drive cycle tomorrow and see if the codes are gone.
    I also put unit strut inside the bed with blind hole rivet nuts and attached some gun racks to hold my skis.
    I’ll post photos tomorrow.
    KNABORES, Weagle, jcrob33 and 2 others like this.
  14. Aug 3, 2025 at 6:12 PM
    Primakluk
    2006 DC SR5 4x4
    Little update:
    I had a misfire a few months back that manifested as poor shifting in the trans, did a fluid flush, didn't fix it. Pulled the codes (no cel) and sure enough a misfire. Needed to replace all the coils with Denso anyways.
    I recently re upholstered the driver seat. I may not have done this the fastest way but I'm hoping it will last a long time.
    Got the seat cushion and seat material from Amazon. I can post the link if anyone wants it. Definitely get a hog ring plier kit.
    Next on the list is the passenger side and finding a radiator fan shroud.
    The Black Mamba and KNABORES like this.
  15. Aug 10, 2025 at 9:27 AM
    Primakluk
    2006 DC SR5 4x4
    Ok, did the radiator and shroud yesterday. No leaks while driving it, but this morning found a small puddle after a 2 min drive. The hoses all look dry and its dripping off the cross member under the oil pan.
    other news the crank position sensor code came up a week ago.... wondering if they are related. Maybe some coolant is dripping on the sensor down the front of the block. I'll be digging into it later today and post some pictures.
    KNABORES likes this.
