  1. Oct 5, 2024 at 3:28 AM
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    Any chopping needed?
  2. Oct 5, 2024 at 5:17 AM
    Ted4311
    Ted4311 Don't Sweat The Small Stuff
    SOMD
    14 Tundra MGM TRD-OFFROAD 4X4
    A LOT... NEVER ENDS
    I had molded the front wheel well plastics for my 295/70s. Only thing now is CMC which I knew it was a 50-50 shot of needing to going to 35x12.5
    Tripleconpanna and AthenaOffroad like this.
  3. Oct 5, 2024 at 6:14 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Not today, but yesterday. 5k oil change and first front diff fluid change. There was a decent amount of build up on the drain plug but overall the fluid wasn’t horrible. I plan to start on a 30k interval for the diffs. Then gave it good ole washing.
  4. Oct 5, 2024 at 10:36 AM
    Ted4311
    SOMD
    A LOT... NEVER ENDS
    Went to town and cut the body mount for clearance. My buddy said he will make a custom plate and weld it when I get around to it. I see why they say keep some tools away from engineers :rofl:
    Tripleconpanna and BR73 like this.
  5. Oct 5, 2024 at 12:17 PM
    Xcumminsguy
    Xcumminsguy New Member
    2021 Tundra TRD Pro Crew Max
    Stock, with a few cosmetic mods.
    When I bought my ‘21 in Nov of last year the dealership did a piss poor job of detailing the paint. Tons of water spots, even on the vertical surfaces, and you know its bad when they are so obvious on white paint. Used Chemical Guys Clear Cut Compound and wheeled the entire truck, still have to do the roof though. Hood had to be done three times. After that I gave it a coat of their Hydro Slick Hyper Wax. I use the Hyper Wax on my Hellcat, but that car is a garage queen, so I’ll really get to see how this stuff holds up.
    Edited to add, just finished the roof and that compound did a fine job removing water spots from the sunroof as well.
  6. Oct 5, 2024 at 1:01 PM
    jackienguyener
    jackienguyener OKToyota
    Jackie
    2016 Tundra 1794
    +10 HP
    75443-42140 off-road badge from JDM RAV4
  7. Oct 5, 2024 at 1:32 PM
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    Working on calipers, coilovers, and UCA install today. Had to stop for lunch and to wring the sweat out of my clothes...
  8. Oct 5, 2024 at 2:05 PM
    Pac12AfterDark
    Pac12AfterDark New Member
    Got pretty far out there this weekend
  9. Oct 5, 2024 at 4:40 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Would love to hear feedback on that setup. I’m getting the same UCAs and am undecided on the Dirt King/Elkas or Bilstein 8112-8100.
    Pac12AfterDark likes this.
  10. Oct 5, 2024 at 5:01 PM
    Totmacher
    Daniel
    West TN
    Some
    My 5 mile test drive on pavement with no alignment done yet rode nice.
    At full lock one of my tierod boots just barely grazes edge of coilover. Alignment should solve that i think. Going to put some more miles and see if they settle before aligning though.
    It's smooth soft movement compared to 5100s and stock uca I had before.
    ZPhilip[QUOTED] likes this.
  11. Oct 5, 2024 at 5:24 PM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Received and tossed some Diode Dynamics SS3 Sport Fog Lights. Terrible angle of the front of the truck, but it shows progress.
  12. Oct 5, 2024 at 5:34 PM
    Voda48
    Voda48 New Member
    Wisconsin
    2016 Platinum
    Received my upgraded Lexus fill and drain plugs for the front diff so I attempted to change my fluids... But the fill was stripped and I wasn't able to get it off. Looks like I'll need to get it to a shop to see if they can weld a nut on there.
    Truck was up on ramps so I took the opportunity to spray the frame with Amsoil Heavy Duty Metal Protector. Ready for winter now.
  13. Oct 5, 2024 at 6:14 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    just ordered some for the old man’s 4runner. Should do well
    https://youtu.be/uQfTdf6-AAM?si=SoPzgcUE2TxeKXb5
  14. Oct 5, 2024 at 6:14 PM
    250000yota
    250000yota New Member
    Russ
    Berthoud, CO
    White 2015 SR5 Crewmax
    S&B intake, Dirty Deeds 8", Airlift airbags with Daystar contact cups, LED's everywhere including Diode Dynamics stealth front LED bar, Baja Design Squadron II's on CBI ditch light brackets, completed Diode Dynamics interior LED's. Full RCI skids with cat guards and sliders, Transfer flow 46 gallon tank. Radflo 2.5 IFP coilovers, Coachbuilder shackles, TRD rear sway bar. 295/70R18 Nitto RG's. Dobinson snorkel, softopper.
    Well, that’s a rando coincidence lol. I’ve been sitting on a set for about a month, I decided to finally put them in today because I was slow at work!
    I had to try and deal with the “loose bouncy fog light” crap, turns out the passenger side is broken. I think my creative electrical tape and zip tie job will do till a bumper becomes a possibility.
  15. Oct 5, 2024 at 6:23 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    2020 SR5 Barcelona Red Tundra
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    Try an ease out
  16. Oct 5, 2024 at 6:33 PM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    There are very few things in this world that electrical tape and zip ties can’t fix!
  17. Oct 5, 2024 at 7:04 PM
    250000yota
    Russ
    Berthoud, CO
    Before you go to the shop, try giving the plugs a good whack with a hammer, directly on the plug as straight as you can. I used to do it before every diff service as a tech. I never had a problem after I started doing that. The shock helps break them free.
  18. Oct 5, 2024 at 7:20 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Hammer n chisel
    BR73, WFD473 and Tundrastruck91 like this.
  19. Oct 5, 2024 at 7:20 PM
    mfelton18
    mfelton18 I'M THE PROBLEM
    South Central Texas
    2014 Magnetic grey SR5 4x4 crewmax
    Eibach Stage 2, RCI armor, Method 705
    Love the RCI bumper.
    BreyTundy[QUOTED] likes this.
  20. Oct 5, 2024 at 8:17 PM
    250000yota
    Russ
    Berthoud, CO
    No need for a chisel. I’ve been doing it without them for years. A good straight on hit from a hammer is more than enough.
    smokint, Xcumminsguy and WFD473 like this.
  21. Oct 6, 2024 at 4:59 AM
    Voda48
    Voda48 New Member
    Wisconsin
    2016 Platinum
    I'll give that a try, thanks!
  22. Oct 6, 2024 at 5:50 AM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    Installed Rago dash mount with ICS under dash base plate.
  23. Oct 6, 2024 at 7:59 AM
    smokint
    smokint New Member
    Whack the crap out of it with a hammer first
  24. Oct 6, 2024 at 9:04 AM
    TacomaTRD4x402
    Southern California
    Love my Rago dash mount. I didn't know there was an under dash mount support. I'm using just regular fender washers but I may get this ICS base plate now :thumbsup:
    Also notice you have a cover going around the edge of your Rago. Where did you get that?
    AggiePhil likes this.
  25. Oct 6, 2024 at 9:18 AM
    huntsonora
    huntsonora New Member
    2006 Toyota Tundra DC
  26. Oct 6, 2024 at 9:24 AM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
  27. Oct 6, 2024 at 9:26 AM
    TacomaTRD4x402
    Southern California
  28. Oct 6, 2024 at 9:57 AM
    Tboh1870
    Tboh1870 New Member
    Herman
    Just starting reno
    Coachbuilder 2" shackles finally on ... those dam bushings
    Pre / post pics ... Fb marketplace $50 hood bulge grill rattlecanned w dip & clear coat $50
    I'm soooo dam thrifty
    Oh yea ...Avs deflector too
  29. Oct 6, 2024 at 3:43 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    What do those CB shackles measure from bolt center to bolt center? And is that what you are measuring or is it the full length of the shackle ? I have some on my 2020 SR5 that were on it when I bought the truck in May.How much lift do the 2" shackles provide?
    Trying to educate myself and going to replace the 5100's with 5160's on the rear.
  30. Oct 6, 2024 at 4:07 PM
    ZPhilip
    Philip
    West Chester, PA
    CB+2 nets 1.25” lift.
