Help with aesthetics/performance?
Discussion in '2nd Gen Tundras (2007-2013)' started by 07Yota_, Oct 4, 2024.
  1. Oct 4, 2024 at 12:17 PM
    07Yota_
    07Yota_ [OP] New Member
    2007 Silver Tundra SR5
    Happy Friday y’all,
    Looking for some ideas with mainly aesthetic upgrades for the second gen that would help me out a bit. Open to performance upgrades as well. Haven’t done much to her in a while. Any links to solid products or any inspiration would be appreciated Dropping a pic for y’all.
  2. Oct 5, 2024 at 5:43 PM
    LILTRD
    LILTRD New Member
    East Bay, California
    2013 Tundra RCSB
    Hidden Winch Lighting Suspension/Air bags Wheels/Tires Audio Center Console swap
    Paint matched or black fender flares...
  3. Oct 11, 2024 at 9:02 PM
    Bigblueintahoe
    Bigblueintahoe New Member
    Eric
    Glenbrook, NV
    2010 Tundra 4x4
    Maybe trd skid plate up front?
  4. Oct 21, 2024 at 2:01 PM
    MartinBlank
    MartinBlank New Member
    Bruce
    Loveland CO
    2008 Crew Cab Limited
    TRD Sway Bars, TRD CAI, Bilstein 5100's, LED's, plus LED rear Plate backup light, Aluminum oil filter housing, ECGS Needle Bearing upgrade.
    Overlandtaylor.com
    You can thank me later. Best upgrade I've done for normally aspirated. Of course if you want to go supercharged that changes things. The overland Taylor tune really pepped up my truck.
  5. Oct 21, 2024 at 2:03 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Debadge, remove running boards, boost it
    pvn.beluga and B.Ross like this.
  6. Oct 21, 2024 at 2:08 PM
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
    Headlights make a huge difference and freshen up the front end. The VLAND Sequoia headlights are awesome on these trucks. But I’m a little biased.
    Rodtheviking and B.Ross like this.
  7. Oct 21, 2024 at 3:39 PM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    That link isn't working. ??
  8. Oct 21, 2024 at 3:40 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    I got to go that way. Looks better than the fender lines, which seem lame.
    LILTRD[QUOTED] likes this.
  9. Oct 21, 2024 at 4:04 PM
    MartinBlank
    Bruce
    Loveland CO
    just type that into your browser
  10. Oct 21, 2024 at 4:45 PM
    BoysandHisToys
    Central Virginia
    Cruiserpilot likes this.
  11. Oct 21, 2024 at 6:30 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
  12. Oct 21, 2024 at 6:34 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    So no supercharger, just a full on proper tune? What do they do that's beyond normal tune?
    Well, I guess I'll find out. There is in fact a local shop, Yota Tune close to my hometown in Canada. I'll be dropping in for some info. Very cool. The US quote was about $550. My curiosity now what this guy will charge.
  13. Oct 21, 2024 at 7:21 PM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    Good recommendations.
    Some type of cat back exhaust system; SPD or DD. Tank swap; OEM 38g or 46 TransferFlo.
  14. Oct 22, 2024 at 7:16 AM
    MartinBlank
    Bruce
    Loveland CO
    Jon,
    They have different levels of tune. If you put it into sport mode it initiates the 1st level of tune, if you push the tow/haul button (if you have one) it moves to the 2nd level of tune. You have a choice of the levels of tune you want to start with. I can't remember now where I started, I think it was the 1st level, then Tow/haul increases that to an even more aggressive response. You can also start with a higher level of tune initially and then it just bumps to the next level from there. If you run higher octane fuel it really makes a difference. My truck is much more responsive with the tune. I haven't put it on a dyno, but there are graphs on the website. Those guys can tell you a lot more about it when you talk to them. I think it only took about 20-30 minutes to load the tune.
    I also have a Dirty Deeds exhaust which helps some as well (besides making it sound a lot better). Highly recommend that too.
    I hope it works out for you. I'm extremely pleased with mine. I already have a Tacoma that is supercharged so I didn't want to go through the hassle of installing one on the Tundra. Honestly, I don't need it.
    Lots of great ideas here that the guys have already posted. I changed my interior lights to LED's. Also this has been really nice to have: https://www.headlightrevolution.com/XTR-LP-Reverse-Light-System_2?quantity=1
    Bruce
  15. Oct 22, 2024 at 7:54 AM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Thanks, I do have Tow/Haul mode. Ironically I plan to keep exhaust as quiet as possible. I really like not hearing my truck when
    I'm listening to Elk bugle and talk. Just getting the 'cleanest' increase in performance is what I'm looking for. I appreciate your
    explanation above. It appears there is a dealer close to home, but they don't list who they are or where they are. But we do have
    one diesel tune place who I suspect is the dealer. I'll go talk, and learn from them and once I've got the baseline tuneup - plugs/filters
    to all the fluids I'll drop in and see what they say. The site mentions ECU updates from Toyota, not sure what that means.
    Are there dealer controlled updates to ECU and other computer components that we aren't aware of unless we have dealers
    do the work? Just asking, sounds paranoid but in my line of work it does bring the question.
  16. Oct 22, 2024 at 8:31 AM
    MartinBlank
    Bruce
    Loveland CO
    Mine was a canned tune. I don't think it's customizable. It's not like a Haltech, where you have complete control over your fuel maps and timing, etc. You can call overland and talk to them directly, they also have an email that you can use. I contacted them directly and their local guy called me back.
    Cruiserpilot[QUOTED] likes this.
  17. Oct 22, 2024 at 8:41 AM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    That actually makes me feel better. I don’t want some eager hot rodder thinking he can upstage the tune with some funky personal idea. I will be in touch.
  18. Oct 22, 2024 at 8:54 AM
    MartinBlank
    Bruce
    Loveland CO
    Hahaha.. yeah, that wouldn't be good. Let me know how it goes or if you have any questions, I'll do my best to help.
  19. Oct 22, 2024 at 4:55 PM
    BoysandHisToys
    Central Virginia
