2018 Tundra SR5 Transfer case output shaft seal (front drive shaft).
Discussion in '2.5 Gen Tundras (2014-2021)' started by TTL, Oct 4, 2024.
  1. Oct 4, 2024 at 11:25 AM
    TTL
    TTL [OP] New Member
    2018 Transfer case- I noticed front output seal (to front drive shaft) is leaking. I went to the Toyota dealer for part but they were not sure about the part. I did find the part number between 2007 - 2013 Tundra but that part does not fit to 2018 Tundra.
    Anyone done this before , part number ? what else needs to change , torque spec for the output flange nut.
    I will appreciate any help and guidance to do this job.
  2. Oct 4, 2024 at 11:39 AM
    timsp8
    NY
  3. Oct 4, 2024 at 12:06 PM
    TTL
    TTL [OP] New Member
    Thanks Tim, Also trying to figure out if this wok require transfer case removal or can be perform detaching the drive shaft and replace the seal. I believe the part number is 90311-A0025 but there is no associate diagram so hard to say where it goes.
