Stuck tailgate side latches
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Mikeypop, Oct 4, 2024.
  1. Oct 4, 2024 at 10:13 AM
    Mikeypop
    Mikeypop [OP] New Member
    2017 Tundra SR5
    I have a 2017 tundra. I bumped the tailgate when opened. The latches will not release when using the handle to open the tailgate. I have a hard tonneau cover with a twist handle release, not a pull cable. How can I release the side latch strikes from outside the bed ?
  2. Oct 4, 2024 at 10:22 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Is the twist handle for tonneau cover inside the bed? You can’t open it with the tailgate closed?
    I just looked at mine and only thing I can think of is removing access panel on inside of tailgate. Meaning you’re going to need to get inside of bed.
  3. Oct 4, 2024 at 10:42 AM
    Mikeypop
    2017 Tundra SR5
    Yupe. Twist handle is on the underside of the cover, inside the bed. Can't get too it. Looking for alternate way to open either the cover or how to manually release the side latches on the tailgate from the outside.
  4. Oct 4, 2024 at 11:42 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Don’t know if this helps but here’s what you’re dealing with.
  5. Oct 4, 2024 at 11:52 AM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Is the tailgate bent, dented?
    Does it feel like the rods are still connected to the handle?
    Try lifting the handle and pushing on the tailgate maybe prying up/down, side to side with something plastic
  6. Oct 4, 2024 at 1:34 PM
    Mikeypop
    2017 Tundra SR5
    Tried all of this. Tailgate is slightly misaligned due to direct impact on right side of the top of it while down. Right hinge pushed slightly forward
  7. Oct 4, 2024 at 2:57 PM
    Mikeypop
    2017 Tundra SR5
    Pried the sides of my 3-piece hard cover up & worked my way to the rear twist opener. All set.
    Bprose likes this.
