2018 Tundra Headlight Malfunction
Discussion in '2.5 Gen Tundras (2014-2021)' started by Dcoutu1994, Oct 3, 2024.
  1. Oct 3, 2024 at 7:17 PM
    Dcoutu1994
    Dcoutu1994 [OP] New Member
    Derek
    Hello all, was just wondering if anyone has run into the same problem as me with their OEM LED headlights. I went to turn them on the other day and both low beams decided to randomly stop working. And if I leave the switch on, the headlight malfunction warning comes on telling me to see the dealer.
    Daytime running lights, high beams and signals all still work. I checked the fuses and they're still good. What do you guys think the chances are of both low beams burning out at the same time? I'm hoping not because I really don't want to have to replace the headlight Assemblies. My truck has 212000km for reference so the lights do have alot of hours on them.
    Thanks for any input
  2. Oct 3, 2024 at 7:38 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Do you have any modifications relating to your headlight switch? Light bar, etc?
    RobertD likes this.
  3. Oct 4, 2024 at 7:35 AM
    Dcoutu1994
    Derek
    I have some aftermarket lights but those are wired to their own switches and have used them for 2 years without issue. I don't have anything tapped into my headlights
    BlueRibbon4x4[QUOTED] likes this.
  4. Oct 4, 2024 at 7:37 AM
    Ghost Rider
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    Just thinking out loud, did you also check the wiring? I wonder if rodent/salt corrosion would cause it to short out?
