Coolant Flush Machine by QwikDraw Speed Draw
Discussion in '2.5 Gen Tundras (2014-2021)' started by Johnsonman, Oct 4, 2024.
  1. Oct 4, 2024 at 5:17 AM
    Johnsonman
    Johnsonman [OP] New Member
    Austin
    Sequoia
    Anyone here work where one of these is used? Or has anyone been a customer using one of these?
    How well (effective at removing all old coolant) do they work?
  2. Oct 4, 2024 at 7:03 AM
    Chip_Tundra
    Chip_Tundra New Member
    Drain the radiator, then drain the passenger side block drain. you can get out just about 3 gallons of coolant if the truck is raised on ramps.
  3. Oct 4, 2024 at 7:23 AM
    iforceAZ
    iforceAZ New Member
    Drain and fill
    WILLINH and coldcanuk like this.
  4. Oct 4, 2024 at 7:25 AM
    Johnsonman
    Austin
    Sequoia
  5. Oct 4, 2024 at 7:28 AM
    For 2900.00, have a shop do it
    WILLINH, Ericsopa, yakeng and 2 others like this.
  6. Oct 4, 2024 at 8:27 AM
    yakeng
    yakeng 3URFE Apologist
    Definitely overthinking this. Just drain and fill. If you are worried about getting it all out, just remember that “the solution to pollution is dilution”. IE, do it again after driving around after the first drain and fill.
  7. Oct 4, 2024 at 8:28 AM
    Johnsonman
    Austin
    Sequoia
    Of course - I was just asking if anyone has had a shop do it - what did they think of results.
    Shop nearby charges $125 including fluid.
  8. Oct 4, 2024 at 8:36 AM
    Chip_Tundra
    Drain and fill, drive it around, then drain and fill again (on a cool engine of course). I'm almost certain that after the 2nd drain and fill, your coolant will be 99% brand new.
  9. Oct 4, 2024 at 9:00 AM
    coldcanuk
    coldcanuk New Member
    2021 Tundra Platinum
    Agreed. I was thinking of doing this instead of dealing with the long extensions with a 10 mm to get at the two brass engine drains. I might just get 6 jugs of Toyota long life and do it a couple times.
    Care Care Nut: don't follow Toyota's coolant drain intervals, every 5 years. He has a video on 5.7 L showing up with head gasket fills. Easy and cheap to do yourself.
