Is it backwards or did I buy junk ??
Discussion in '2nd Gen Tundras (2007-2013)' started by 10 Bears, Oct 2, 2024.
  1. Oct 2, 2024 at 3:31 PM
    10 Bears
    10 Bears [OP] New Member
    11 CREW 5.7
    None at the moment
    2011 Crewmax 5.7 239k
    I bought a replacement tailgate damper from Glamazon. The OEM unit was still mounted damper pointed downward so I installed the ChineseIMG_20241002_153631032_HDR.jpg unit exactly the same. It had absolutely no resistance so I flipped it ....same thing.
    Do these dampers have a break in process or did I just get a weak damper ??
    Note: the OEM has a arrow pointing "down" and that's how it was mounted. & How I mounted the new one. I wound up removing both. With intention of matching the OEM unit at O'Reilly's.
    Anyone replace their damper with a aftermarket unit with success ??
