5 lug to 6 lug conversion...is it possible?
Discussion in 'Wheels & Tires' started by Monchit888, Oct 1, 2024.
  1. Oct 1, 2024 at 1:48 PM
    Monchit888
    Monchit888 [OP] New Member
    Raymund
    07 tundra
    I recently inherited my late brother's 07 tundra and currently trying to get it back in shape. I was just wondering if there's ny easy way to convert the 5 lug 5x150 bolt pattern to the 6 lug 6x139...has anybody out there done it and how?
    MarkM0369 likes this.
  2. Oct 1, 2024 at 1:54 PM
    Ericsopa
    Ericsopa Old man and the sea
    Damn near anything is possible. But few possible things are worth the effort.
    Mdl likes this.
  3. Oct 1, 2024 at 1:54 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
  4. Oct 1, 2024 at 1:59 PM
    b6graham
    b6graham New Member
    2020 Voodoo 1794 RW Wheels 315/70
  5. Oct 1, 2024 at 2:51 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Nothing wrong with 2” spacers if maintained and running a good spacer
    JrJrOffroad and Mdl like this.
  6. Oct 1, 2024 at 3:25 PM
    b6graham
    b6graham New Member
    more along the lines of offset and clearance issues with what is assumed to be a (mostly) stock truck
    you're a special (and badass) case
    reywcms[QUOTED] and Mdl like this.
  7. Oct 2, 2024 at 9:07 AM
    Monchit888
    Raymund
    07 tundra
    Aaaah...spacers. Has anybody tried changing the front hub and rear axle shaft to 6lug? Will 1st gen parts fit? Maybe 3rd gen? Or something "better", maybe, but still Toyota? ...just trying to look at all the options out there, thanks
  8. Oct 2, 2024 at 9:15 AM
    You never said why you’re doing this. Guessing you already have a set of wheels?
