New Exhaust System
Discussion in 'Performance and Tuning' started by reywcms, Jan 27, 2024.
  1. Oct 1, 2024 at 5:02 PM
    #661
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Hehehehehehehehehehehehe….
    centex and reywcms[OP] like this.
  2. Oct 1, 2024 at 5:06 PM
    #662
    Chad D.
    Chad D. New Member
    Western Oregon
    Definitely wouldn’t want a 12.50 wide 35” tire under there. About an inch of room with my 285/75-18, and she juuusssssttt barely blows on the shoulder of the tread with the driver side dump.
    Sound is still new to me with only a couple minutes of run time. Smells weird as it’s burning the crap out, but that sound…. Mmmm hmmm. Daddy likey…
  3. Oct 1, 2024 at 5:11 PM
    #663
    WinterWarlock21
    WinterWarlock21 New Member
    South Jersey
    2016 Quicksand TRD Pro CrewMax
    https://gearproject.co/profile/SandShark21
    I have the same smell too (I have the downpipes also). It was pretty darn noticeable on day 1 but each day it's been getting alittle bit better.
    reywcms[OP] and Chad D.[QUOTED] like this.
  4. Oct 1, 2024 at 5:16 PM
    #664
    Chad D.
    Chad D. New Member
    Western Oregon
    image.jpg I live in western Oregon, so no salted roads. We do get rain about 14 months per year, but nothing corrosive to speak of.
    Stock exhaust was out in a matter of minutes, and this was in almost as quick. Reused my OEM flange bolts. They were in good shape and the new ones from SPD don’t appear to be the same thread. No sense in cutting the welded nuts off…
    Went together like butter. Had a buddy wiggle the front pipes while I shoved the muffler forward. Clamped it home.
    If my spare starts showing signs of heat damage, I’ll clip an inch off the tubing in front of the muffler to move it forward a hair for more tire clearance.
    reywcms[OP] likes this.
  5. Oct 1, 2024 at 5:27 PM
    #665
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    @reywcms would be happy to recommend some gold heat resistant foil to cover your spare with.
    RobertD and reywcms[OP] like this.
  6. Oct 1, 2024 at 5:32 PM
    #666
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I'm in the same boat. I need to get my cats installed and don't trust any shop around to do it right.
    Ryuu[QUOTED] likes this.
  7. Oct 1, 2024 at 5:34 PM
    #667
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Why so high at 85?
    centex[QUOTED] likes this.
  8. Oct 1, 2024 at 5:41 PM
    #668
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    gearing im guessing. sounds like hes running 5.29s
    texasrho83[QUOTED] and centex like this.
  9. Oct 1, 2024 at 5:47 PM
    #669
    reywcms
    reywcms [OP] New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Looks great! We need some sound clips
    NatesNightMare likes this.
  10. Oct 1, 2024 at 5:52 PM
    #670
    Chad D.
    Chad D. New Member
    Western Oregon
    Sounds like yours, I bet. Maybe a bit more on the “cute” side…
    reywcms[QUOTED][OP] likes this.
  11. Oct 1, 2024 at 6:34 PM
    #671
    centex
    centex New Member
    Bingo. 5.29’s and 34’s.
  12. Oct 1, 2024 at 6:44 PM
    #672
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Big difference with 37s as I'm hitting 2400 @ 85
  13. Oct 1, 2024 at 7:20 PM
    #673
    centex
    centex New Member
    I like the gearing for towing and the general added pep. Honestly wish I had gone deeper than 5.29’s but that’s a different thread.
  14. Oct 1, 2024 at 10:04 PM
    #674
    NatesNightMare
    Pinetop Az
    still crazy for 34s. 35 or lower id run 4.88s. 37s is where 5.29s should start
    texasrho83 likes this.
  15. Oct 1, 2024 at 10:27 PM
    #675
    Chad D.
    Chad D. New Member
    Western Oregon
    Blown motor, sure. N/A? Heelllll nahhhhh.
    N/A 5.29 with 34-35” tires is money. It’s literally 275 rpm higher at 65 than an all stock truck.
    But, that’s another topic.
    Just drove 30 minutes home with the new pipes. Intentionally left it in 6th gear with cruise for a couple little rolling hills that my TCC will unlock on every time. She held locked up. That’s about 1,900 rpm at that speed. I dare say I did not lose any low end torque. I’ll run it some more, but I believe there is a gain.
    centex, reywcms[OP] and Mdl like this.
  16. Oct 2, 2024 at 5:11 AM
    #676
    centex
    centex New Member
    I’ve had zero issues with using 6th gear at any speed. Runs just the same between factory exhaust and this one. Same mileage, same shifting, same towing, everything.
  17. Oct 2, 2024 at 8:54 AM
    #677
    Ryuu
    Ryuu Hwat!?
    Oz
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    Exhaust is on :yes:
    overthought things a bit and stressed myself lmao
    Said screw it and got it to a shop this morning, they fixed the lengths and angles of my mid pipes and bolted on the exhaust for me.
    Man you guys weren’t kidding when y'all said this system sounds good. I was a little worried it was going to be to much with my headers but honestly it’s a lot more tame then I expected which I really like.
  18. Oct 2, 2024 at 9:49 AM
    #678
    reywcms
    Rey
    North Plains,Oregon
    Looks great!
    Mdl, centex and Ryuu[QUOTED] like this.
  19. Oct 2, 2024 at 12:32 PM
    #679
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @Ryuu thanks for that back downpipe pic. I had mine blowing out towards the spare. At certain rpms it would reverberate under the bed. That's what I get for my poor man's copy of an exhaust...:D
    reywcms[OP] and Ryuu like this.
  20. Oct 2, 2024 at 1:10 PM
    #680
    PolishedTRD
    PolishedTRD Lorem ipsum dolor sit amet
    CO
    Supercharged 2011 DC
    Magnuson's Finest Whine
    Anyone have any idea where to purchase replacement gaskets? I have a gasket leak between one of the manifolds and downpipes (I'm running the full SPD system). I likely nicked it during installation. I took it out to find a similar one - it has an I.D. of roughly 2.5". NAPA didn't have any with a wide enough I.D. that wasn't too thick (0.5") or too thin (~0.0625"). All the other gaskets with the correct I.D. and thickness are the laminated, oval, two-bolt style.
    I've called and sent messages to SPD, over the past couple of weeks, but no reply.
    nobodyintexas likes this.
  21. Oct 2, 2024 at 2:22 PM
    #681
    Chad D.
    Chad D. New Member
    Western Oregon
    Weird. I called and spoke with Jeremy there twice.
  22. Oct 2, 2024 at 2:31 PM
    #682
    Silver17
    Eastern PA
    You could always buy some gasket material and cut your own. I’ve thought about doing it myself.
  23. Oct 2, 2024 at 3:43 PM
    #683
    Black Beauty 5.7
    Black Beauty 5.7 New Member
    Cannon
    2007 Black 5.7L Tundra SR5
    250,000 miles and always adding more :)
    Any idea if there will be an option for the 07-09s in the future?
    I want to start out with just the catback to see what it's all about and I'm trying to avoid the local muffler shops.
    Had a buddy of mine go to a couple different exhaust shops in my area for his truck and the welds were all astonishingly horrible... Every time he showed me when it was "fixed" I'd find a new leak lol
  24. Oct 2, 2024 at 4:02 PM
    #684
    reywcms
    Rey
    North Plains,Oregon
    Not sure if they’ll be making that an option. I’ll find out when I chat with them again. I know the gen 3 tundra is on the list and older Sequia so I don’t see why it wouldn’t be.
  25. Oct 2, 2024 at 4:05 PM
    #685
    reywcms
    Rey
    North Plains,Oregon
    DM’d you
    PolishedTRD[QUOTED] likes this.
  26. Oct 2, 2024 at 4:48 PM
    #686
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    The word "tame" and "headers" don't apply in my case lol....unless you and I have different ideas of tame
  27. Oct 2, 2024 at 4:55 PM
    #687
    NatesNightMare
    Pinetop Az
    everyone need to post some vidz
  28. Oct 2, 2024 at 5:22 PM
    #688
    reywcms
    Rey
    North Plains,Oregon
    You ain’t buyin it lol
  29. Oct 2, 2024 at 5:44 PM
    #689
    Ryuu
    Ryuu Hwat!?
    Oz
    SouthEast, TX
    a few
    yea not the best choice of words on my part lol. only reason I say it's tame is because I'm comparing it to what I had installed back in jan 2022. was also a 3 inch dual exhaust, x-piped and dumped but it had a pair of carven-r mufflers. that system made the truck legit scream like a banshee, was loud and obnoxious.
    those dang carven-r mufflers are legit just for looks, they don't muffle crap. I had it modified a bit last year, with another set of mufflers and some helmholtz resonators but after that wasn't happy with it anymore, just gave me a headache.
    ditched that around april this year for a $100 ebay dual 2.5 in to single 3" out exhaust, but that was only temporary while I looked at options. no pics of that since it looked dumb lol.
    Finally landed on the SPD and I think my exhaust journey has finally ended, now on to other mods.
  30. Oct 2, 2024 at 6:09 PM
    #690
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Ah, thanks for the clarification. Which muffler shop did you use?
