1st Gen camper shell buying info
Discussion in 'Tonneau Covers, Caps and Shells' started by shifty`, Mar 26, 2021.
  1. Sep 18, 2024 at 5:08 AM
    #1741
    There was no OEM Tundra camper shell. The front window isn’t missing, the shell has a boot to the back of the truck to allow pass through to the truck when the window is open. Not specific to Tundras, many shells used this option even without the roll down rear window. Agree with @shifty` , mystery is easily solved by the plate in the truck. Hopefully it’s a match for you!
    455h0le_dachshund likes this.
  2. Sep 18, 2024 at 5:27 AM
    #1742
    phudz
    phudz
    Michigan
    2004 DC V8 4WD
    Here's a free one posted up in one of the 1st gen FB groups. upload_2024-9-18_8-27-44.png
  3. Sep 18, 2024 at 5:36 AM
    #1743
    shifty` [OP] Goons of Hazzard
    I'm guessing they realized how much that rear wing window cost :rofl:
    (or found you can't get the part anymore)
  4. Sep 18, 2024 at 7:35 AM
    #1744
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    Nah, They’re all ghey.
  5. Sep 18, 2024 at 11:04 AM
    #1745
    Nicklovin
    Nicklovin Yap Yap
    Huntington Beach, CA
    00’ 4.7 AC 4x4 - GFC
    Hi-Rise Shell off a T100 in costa mesa, CA 459781055_1085552283130999_7565209672173_92a6368a5fd39bbe1866e006ff4003e7ff2ffe71.jpg
  6. Sep 21, 2024 at 7:23 PM
    #1746
    87warrior
    87warrior Whiskey Tango Foxtrot
    Kansas
    2004 DC 2uz 4x4
  7. Sep 21, 2024 at 8:28 PM
    #1747
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Has anyone else noticed a rearward drift over time? When i replaced the seals it seemed a little further back, and now...
    About that far every 5k miles. Do i need more clamps? Double sided foam tape instead of a double bubble seal? The back window is the only 'leak' i have. No regertz. But seems like this thing might try to jump ship if it could.
  8. Sep 21, 2024 at 8:34 PM
    #1748
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    All that wind resistance. That's crazy it moved that much.
  9. Sep 21, 2024 at 8:38 PM
    #1749
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    I need a plastic 'boat tail' about 6' long hanging off the back with a removable belly. Change my bullet shape to more of a cartoon raindrop.
  10. Sep 22, 2024 at 7:04 AM
    #1750
    I definitely have had a couple times where my clamps weren't as tight as they should've been and it slipped backwards. Style of clamp and how tight you clamp makes a difference. But I'm guessing so do the your seals on the underside where it makes contact with the rails.
    G_unit3000 likes this.
  11. Sep 22, 2024 at 9:14 AM
    #1751
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    Is there a known leak spot associated with the bed caps? Ever since getting my topper, the front passenger corner leaks. I replaced the foam tape with double-bubble style tape recently and it still leaks in the same spot.
    I suspect the gaps at the ends of the bed caps, but I'm not sure. And not sure why it doesn't also happen on the driver side.
  12. Sep 22, 2024 at 12:01 PM
    #1752
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Where the bedliner meets the side caps i added some extra foam i had laying around. My front window might leak a hair, but the only place i've seen water get inis through the rear window, need to replace that seal.
    MT-Tundra[QUOTED] likes this.
  13. Sep 22, 2024 at 7:59 PM
    #1753
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
  14. Sep 23, 2024 at 6:22 PM
    #1754
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Fml. Might've gotten a little rough manhandling my cap back into place. Popped a rivet.
    Ignore my ants. They're in charge of security.
  15. Oct 1, 2024 at 7:31 AM
    #1755
    Really nice looking ARE MPulse topper with big slider windows for an Access Cab in SE Tennessee. No clue what they actually want in $$ but this is one of ARE's better caps for our trucks. I still prefer the Leer 100R, but this or a SnugTop would be my 2nd choice in the fitment/brand category.
    HBTundra likes this.
  16. Oct 1, 2024 at 10:49 AM
    #1756
    This is the cap I have. I dig it.
  17. Oct 2, 2024 at 9:50 AM
    #1757
    Bowser55
    Bowser55 New Member
    2001 A/C
    Will a camper for a 2005 fit the 2001? Both are AC
  18. Oct 2, 2024 at 10:09 AM
    #1758
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Yup.
    KNABORES and Bowser55 like this.
  19. Oct 2, 2024 at 2:39 PM
    #1759
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L AC Limited 55k mi
    I could never figure mine out either, always leaked a little around front window on driver side, but couldn't tell where. Next time I put it on truck will be for camping/hunting so will need to figure that out.... Honestly I might just lay a bead of silicone everywhere on the topside of windows.
  20. Oct 2, 2024 at 2:53 PM
    #1760
    MT-Tundra
    Montana
    Far as I can tell, my leak is coming from the topper to truck bed seal, not the windows. I suspect the joint between the side rails and front rail of the bed, especially with the extra complication of the bed caps there. But I'm still not sure. We're back to hot, dry, smoky weather.
  21. Oct 2, 2024 at 2:56 PM
    #1761
    If your OEM bedliner (assuming intact)is over-rail as most are, there is a gap between the liner and the bedrail caps. When I installed my Bakflip, they give you a foam square to install in that little valley to shore things up. When the Bakflip is latched on, it compresses the foam to be flush with the bed cap and liner, helping to keep water out in that entry point. You may want to inspect, and consider the same may be happening with your cap.
  22. Oct 2, 2024 at 2:59 PM
    #1762
    MT-Tundra
    Montana
    No bedliner in my truck. If that's something that came standard, the PO must have removed it when he put in the bed rug.
  23. Oct 2, 2024 at 3:08 PM
    #1763
    Specifically the gap right here between the liner and bedrail cap. You can barely see it here, but that's effectively where it is on all 1st gens with the OEM liner intact. If you don't have the liner, it may still be that gap, the rail cap stands at least 3/8" proud of the bed.
    Dook55, HBTundra and Sirfive like this.
  24. Oct 2, 2024 at 4:27 PM
    #1764
    MT-Tundra
    Montana
    Yeah, definitely. That's the spot I'm suspicious of. Thanks.
  25. Oct 2, 2024 at 8:27 PM
    #1765
    Nicklovin
    Nicklovin Yap Yap
    Well guys, I finally found my camper shell. A very well priced GFC off a friend :D
  26. Oct 2, 2024 at 9:16 PM
    #1766
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Yea, split about an inch of the double bubble & passed my wires through one of the bubble. Its stuffed in short of the rear bubble across the front, so i have a solid seal all the way across. Minus the wire. Need to finish reseting mine, since i fixed the busted rivet.
    How hard is it to set up shitfaced?
  27. Oct 2, 2024 at 9:24 PM
    #1767
    Nicklovin
    Nicklovin Yap Yap
    Not sure, haven't had the opportunity to experience that yet
    It's pretty easy though. Twist two latches by hand loose, pop them inwards, then give the top a decent push and you're done :D
  28. Oct 2, 2024 at 9:30 PM
    #1768
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Does the ladder go to the ground or the tailgate?
  29. Oct 2, 2024 at 9:40 PM
    #1769
    Nicklovin
    Nicklovin Yap Yap
    Didn't come with one but it does go to the ground. Honestly if the tailgate is dropped I could easily hop into the camper. Also fairly easy to hop into the camper from the inside, 2 panels inside pull out so you can hop up
  30. Oct 2, 2024 at 9:42 PM
    #1770
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Like up through the floor? Dont bust the back window trying to hop up there.
