Blown rear diff
Discussion in '1st Gen Tundras (2000-2006)' started by jake22si, Oct 1, 2024.
  1. Oct 1, 2024 at 9:54 AM
    jake22si
    jake22si [OP] New Member
    kevin
    2000 tundra 4.7
    Son towed my truck back with the gears looking like this.
    Jack McCarthy likes this.
  2. Oct 1, 2024 at 9:56 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Dang that sucks. You going to get a junkyard diff now or what?
  3. Oct 1, 2024 at 9:56 AM
    jake22si
    kevin
    2000 tundra 4.7
    Can i roll my truck around if I bolt the axles back in without the third in the axle? Will I destroy my bearings, or seals?
  4. Oct 1, 2024 at 9:57 AM
    jake22si
    kevin
    2000 tundra 4.7
    Just started the “looking into it” process
    May go east coast diffs and throw a locker in it.
  5. Oct 1, 2024 at 10:11 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    If you have bigger tires on your truck than stock, you may want to regear while you're at it. Just keep in mind if you are 4wd, you'd also have to regear the front diff
    whodatschrome likes this.
  6. Oct 1, 2024 at 10:24 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Wow, how?
  7. Oct 1, 2024 at 10:28 AM
    X2
  8. Oct 1, 2024 at 10:40 AM
    BluegrapeVr6
    BluegrapeVr6 New Member
    J
    Im going to go with wheel hop , being stuck, and lots o right foot.
    whodatschrome and jake22si[OP] like this.
  9. Oct 1, 2024 at 11:38 AM
    jake22si
    kevin
    2000 tundra 4.7
    Most likely all 3
    whodatschrome and FrenchToasty like this.
  10. Oct 1, 2024 at 12:51 PM
    jake22si
    kevin
    2000 tundra 4.7
    I put it all back together for now so I can move it around
  11. Oct 1, 2024 at 2:01 PM
    Bmktw2
    Bmktw2 Yard Dog
    Nic
    AC 2001 5spd 4x4 V6
    I have a 3.90
    jake22si[OP] likes this.
  12. Oct 1, 2024 at 2:21 PM
    jake22si
    kevin
    2000 tundra 4.7
    how much
  13. Oct 3, 2024 at 3:11 PM
    Bmktw2
    Bmktw2 Yard Dog
    Nic
    AC 2001 5spd 4x4 V6
    Where r u?
  14. Oct 3, 2024 at 3:45 PM
    jake22si
    kevin
    2000 tundra 4.7
    seacoast area nh
  15. Oct 3, 2024 at 3:48 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    FWIW, someone's had those gears out before you. Factory installation uses a gasket, yours has FIPG.
  16. Oct 3, 2024 at 3:57 PM
    jake22si
    kevin
    2000 tundra 4.7
    I did that when i replaced my rotted axle housing
    w666[QUOTED] likes this.
  17. Oct 3, 2024 at 4:02 PM
    w666
    Maryland
    I did a quick search at car-part.com using a Portsmouth NH Zip Code and you may be able to turn up a used carrier within ~ 100 miles or so. I found mine on FB Marketplace (3.90 gears) for ~ $400 (seemed high at the time, but now maybe not so much). You can use any 2000 - 2006 carrier with the right gears (yes, the is a difference between 3.90 and 3.91) but 2005 - 2006 use a larger flange that will need to be changed. Bon chance!
    Edit: Here are the two variations - The 3.909 (rounds to 3.91) has an 11 tooth pinion and a 43 tooth ring, while the 3.90 has a 10 tooth pinion and a 39 tooth ring. You don't say if you're 4WD or 2WD. For 4WD the 3.91 should match up to the front diff. If 2WD now is an easy time to choose whatever ratio you want.
    jake22si[QUOTED][OP] likes this.
  18. Oct 4, 2024 at 8:40 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    The spider gears are know to fail on our 8.4 3rd member. Once they start stripping out, it will cause collateral damage to the R&P gears. Performing a one wheel burnout puts quite a bit of load on spider gears. Spider gears in general weren’t designed for that kind of long term abuse.
    My local U Pull It yard sells 3rd members for around $75 (i can’t remember exactly).
    I didn’t catch if the OP’s truck is 2wd or 4wd, but i’d swap in a Sequoia 4.10 3rd member in a heartbeat…unless the tires are oversized at all, then i’d go with a 4.30 or 4.56.
  19. Oct 4, 2024 at 8:51 PM
    output_image1703632553310.jpg4.88………
  20. Oct 5, 2024 at 5:45 AM
    jake22si
    kevin
    2000 tundra 4.7
    I got 265's on it. 4wd currently 3.91 gearing. I can get a complete third from east coast gear supply for around $840. I found a local parts truck for $700, might get that if a few other parts are good on it.
    HBTundra likes this.
  21. Oct 5, 2024 at 9:40 AM
    whodatschrome
    lots of dents
    That's definitely more than the $26 i paid for mine at my local Pick n Pull yard last year.
  22. Oct 5, 2024 at 9:52 AM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    I think I paid $350 for a whole rear axle assembly. Theres gotta be a better deal out there.
    whodatschrome[QUOTED] likes this.
  23. Oct 5, 2024 at 10:38 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    ^ this.
    Get both 1st gen sequoia diffs and you'll have 4.10's, you just might need to swap the rear pinion flanges.
  24. Oct 5, 2024 at 11:47 AM
    jake22si
    kevin
    2000 tundra 4.7
    I guess prices are a little different in the northeast?
  25. Oct 5, 2024 at 3:13 PM
    whodatschrome
    lots of dents
    If i looked around here in the Pac NW, i'm betting i could find those same high prices, but i look for lower prices...such at a U Pull it wrecking yard where you pull your own parts.
  26. Oct 5, 2024 at 3:17 PM
    whodatschrome
    lots of dents
    I walked buy a Sequoia last month at a yard. I was temped to pull the from and rear 3rds out of it. I don't have a use for them, but i was thinking about reselling them at a later point. I guess i'm just not an opportunist? And FYI, I didn't have to swap the rear pinion on my Sequoia 3rd member into my 4wd tundra.
  27. Oct 5, 2024 at 3:44 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Nice. Yeah, it's a 'might' as there are 2 or 3 different flanges iirc.
  28. Oct 5, 2024 at 4:51 PM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    4WD can also pull the slip yoke, driveshaft flange yoke, and u-joint and order the correct pattern driveshaft flange yoke, that's what I ended up doing.
    I couldn't find a part number for 2WD flange yokes, but they probably exist for some other Toyota application. 2WD/4WD flange yokes are different since 4WD uses 1510 series u-joints and 2WD uses 1310 series. Bearing caps and distance between snap rings are different between the two joints, so 4WD flange yokes aren't compatible on 2WD.
    37315-0K010 - 4WD 66x66mm flange yoke
    37315-35070 - 4WD 60x60mm flange yoke
    (I was lazy with the caliper when taking measurements, wasn't trying to get them precise in the pictures)
    shifty` and whodatschrome like this.
