Going Long Travel Front and Rear
Discussion in 'Long Travel Suspension' started by heckler66, Jul 4, 2023.
  1. Sep 26, 2024 at 9:35 PM
    #151
    heckler66
    heckler66 [OP] New Member
    2012 Tundra CM 4x4
    Icon Billet Upper CA King 2.5 Fr / Rr Deaver U748 Victory 4x4 bumper RCI Skid plates Baja Designs lights
    California… I actually need to smog my truck so I can register it next month
  2. Sep 30, 2024 at 9:26 PM
    #152
    heckler66
    2012 Tundra CM 4x4
    Here is my version of beside supports. 1” 4130 tube and 1/8” plate. I used some 1/8” rubber material in between the fiberglass just because. Bolted to the frame with the factory drilled holes.
    rockmup, BiggHertz, snivilous and 3 others like this.
  3. Oct 1, 2024 at 5:14 AM
    #153
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Soon you’ll be out https://youtube.com/shorts/m14UpfiMRZk?si=fIURP7BU3XuhgYOl
  4. Oct 1, 2024 at 7:25 AM
    #154
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Highly recommend that you build a coil tower brace….
  5. Oct 1, 2024 at 8:22 AM
    #155
    heckler66
    2012 Tundra CM 4x4
    I really do want to built an engine brace but I need to at least buy the Camburg Bypass mount because I would probably add on from the top of that mount. I guess I could just buy the mount with no bypasses for now to get things rolling.
    reywcms likes this.
  6. Oct 1, 2024 at 8:40 AM
    #156
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Yep exactly add the bypass mount then throw in the shock later
  7. Oct 1, 2024 at 9:19 AM
    #157
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Oh and do motor mounts. Way easier to install before the frame gets all out of whack.
    joonbug, Vizsla and reywcms like this.
  8. Oct 1, 2024 at 11:56 AM
    #158
    Vizsla
    Vizsla pretend2send
    If I built another LT Tundra it wouldn’t have a secondary bypass. Would use that space for a proper bump and run an IBP coilover.
    :notsure:
    BiggHertz[QUOTED] and joonbug like this.
  9. Oct 1, 2024 at 12:42 PM
    #159
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    ^^^ This is the way
    Vizsla[QUOTED] likes this.
  10. Oct 1, 2024 at 12:44 PM
    #160
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Also, do my eyes spy your new headers ;)
  11. Oct 1, 2024 at 1:20 PM
    #161
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I wouldn’t waste my time with a stock coil bucket LT kit. Still would have a bypass etc with a true J arm or LSK race kit
    heckler66[OP] likes this.
  12. Feb 16, 2025 at 5:09 PM
    #162
    PhoenixSR5
    PhoenixSR5 New Member
    Brandon
    Gilbert, Az
    2016 Tundra SR5 work in progress
    Front: Dirt King Long Travel Kit, DK spec King Coilovers, BMC and Pinch weld mod. Rear King 2.5 RR shocks, Deaver K37s, SDHQ Shackles. Fuel Hype 18x8.5 w/ Dirty Seven Maxxis RAZR MT
    I know I may be reviving an older thread. The info here has been excellent.
    I'm starting the LT process on the truck. For the front I'm looking at the Dirt King kit and was originally going to go with their King coilovers specifically for their kit. Then I read this thread lol. I noticed a couple of you mentioned going with an IBP coilover. I just started digging into them and saw some options through Accutune. I'm looking at the King 2.5 IBP 8" with the adjuster. I may be wrong but it seems every LT manufacturer spec'd coilover is 8". Is this the correct travel coilover and are there any downsides to running this option as opposed to the ones spec'd for Dirt King?
    cavalry bear likes this.
  13. Feb 20, 2025 at 6:59 PM
    #163
    heckler66
    2012 Tundra CM 4x4
    Sorry for the dying thread. I had my first child last year and then decided to break both my legs in a dirt bike accident in January so progress on the truck has been dwindling. I personally have no experience with the IBP. If I were to speculate, I would still prefer to have a standard 2.5 coilover with a 3.0 bypass for ease of tuning the bypass external adjustments. I believe the IBP is only compression adjustment throughout the entire shock stroke (without shock disassembly). The dual shock setup is probably a lot more expensive though. Hopefully someone with some IBP experience can chime in here. Also on a side note, if going with LT I would have the ultimate plan to be doing the rear as well. Let me know if you want random pictures to help your build because seeing everyone else's chassis photos helped me build mine.
  14. Feb 21, 2025 at 7:36 AM
    #164
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    2011 super white Tundra double cab
    King 2.5 coilovers, King 3.0 rear bypasses, Camburg uniball UCAs, RCI skid plates, Camburg front bumper, warn zeon 10s platinum winch, monster hook reaper shackles, Rigid Industries lights, SDHQ sliders, SDHQ A-pillar brackets, SPOD, 17" Method standard wheels, 315/70/17 Cooper STT tires, Morimoto XB LED headlights, Boon dock steel rear bumper, Durobumps front bumpstops, Deaver U748 with MCM shackles
    Sorry to hear, that’s gotta be tough raising a little one with broken legs.
    This might be a little crazy but Any chance you used to live in San Juan Batista and lived with a guy named Dan Conner? Looking through your thread you truck looks just like the one I would see parked out front when I would pick him up to go ride lol
  15. Feb 21, 2025 at 8:41 AM
    #165
    heckler66
    2012 Tundra CM 4x4
    Yea that's me! I remember you showed up at my old apartment. I have definitely stalked your build thread before.
    TG705 likes this.
  16. Feb 21, 2025 at 11:43 AM
    #166
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    Haha small world! Dan was just telling me about your accident when we rode a few weeks ago, then when I saw your post I figured it had to be you. Sucks man hope you heal quick. Truck is looking sweet btw!
    heckler66[QUOTED][OP] likes this.
  17. Jun 15, 2025 at 7:08 AM
    #167
    martiartisan
    martiartisan New Member
    North Texas
    2020 Tundra DC, 2006 Tundra Crew Cab
    Adv fiberglass, king suspension, cbi armor, RLD Cap
    Are you still liking this intake setup? I am looking for a better solution now that I have the fiberglass installed.
  18. Jul 15, 2025 at 6:42 PM
    #168
    heckler66
    2012 Tundra CM 4x4
    Well it finally happened and it's time for upgraded cam tabs. Do I machine billet ones of just get the DK or TC ones?
    reywcms likes this.
  19. Jul 15, 2025 at 6:46 PM
    #169
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    bang it back. throw a bead behind it and torque those cam bolts as tight as you can. CAM tabs aren't designed to support any more load than when it comes time to adjustments, resistance to movement comes from the clamping force of the bolt itself...
  20. Jul 15, 2025 at 6:50 PM
    #170
    heckler66
    2012 Tundra CM 4x4
    probably the best idea as of now. Might CAD them up for the future but im mostly annoyed because I just got the alignment done a couple weeks ago.
    BiggHertz[QUOTED] likes this.
  21. Jul 15, 2025 at 7:00 PM
    #171
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
  22. Jul 15, 2025 at 7:05 PM
    #172
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I would bang them back and weld on a tiny block of metal behind it. I did the TC cam tabs and I honestly don’t think the result would be any different.
  23. Jul 15, 2025 at 7:18 PM
    #173
    heckler66
    2012 Tundra CM 4x4
    looks like the back half of the cam bolt with the pressed cam slipped like 135 degrees. prolly just tac it back, weld the tabs and call it a day
    reywcms likes this.
  24. Jul 15, 2025 at 7:21 PM
    #174
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Bang back or grind off, weld on a chunk of steel, align it, tack weld cam tabs.
    BiggHertz and heckler66[OP] like this.
  25. Jul 16, 2025 at 3:14 PM
    #175
    heckler66
    2012 Tundra CM 4x4
    I ended up just making new billet alignment tabs to weld on. 4mm thick base and 6mm thick tabs.
    Ryuu, steezy, reywcms and 4 others like this.
  26. Jul 31, 2025 at 3:49 AM
    #176
    steezy
    steezy New Member
    2021 Tundra TRD Pro
    I’d probably steer clear of SS Built.
    It’s a shame because the bumpers are beautiful, but I bought my front and rear in December of last year and have received every excuse under the sun for why I still don’t have them.
    Someone not named Steve REALLY needs to develop a tube style bumper for these trucks…:monocle:
    Addictive desert design used to have one but they scrapped it for some reason.
    Peeeheeuuu likes this.
  27. Aug 5, 2025 at 10:59 AM
    #177
    Peeeheeuuu
    Peeeheeuuu New Member
    Peter
    Elk Grove, CA
    08 Tundra CM 4x4. 21 Sequoia SR5 4wd
    your not lying, i paid for my front and rear bumpers in full and waited a whole year with every excuse in the world and then ghosted me. thank god i had charged it and had to do a charge back.
  28. Aug 5, 2025 at 12:35 PM
    #178
    Ryuu
    Ryuu Hwat!?
    Oz
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    4lo-fab makes tube bumpers too. Pretty sure there was another option but I can’t recall the name of the company.
    steezy[QUOTED] likes this.
  29. Aug 5, 2025 at 12:49 PM
    #179
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Doom MFG is an option Jose formally at SS is doing bumpers etc. If anyone needs more info ping me directly. Or we have @snivilous also as a bumper production now since we have scans of chassis
  30. Aug 5, 2025 at 2:04 PM
    #180
    snivilous
    SW UT
    I was just thinking this yesterday, though more specifically for the 07-13 trucks since their bumper selection sucks ass last I checked
