  1. Sep 28, 2024 at 6:57 AM
    #7351
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Diff service
    tundznoff, mayan and Tundrastruck91 like this.
  2. Sep 28, 2024 at 7:30 AM
    #7352
    az 3rdGen
    az 3rdGen New Member
    Arizona
    2022 Black Tundra SR5
    You got any pictures of that center console mount? I don't think I've seen any like that.. I've seen the overhead and the driver side trim mount above the other buttons.
  3. Sep 28, 2024 at 9:07 AM
    #7353
    6rian
    6rian New Member
    Don't have a great photo but just snapped this to get a driver view.
    =JSG=, az 3rdGen[QUOTED] and matth66 like this.
  4. Sep 28, 2024 at 10:31 AM
    #7354
    GAMark
    GAMark New Member
    Can you tell me where you got the piece that is in your cup holder?
  5. Sep 28, 2024 at 12:28 PM
    #7355
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    https://cupgrip.com/
    edit...great product and no affiliation. Rarely even use but have moreso for passengers and tbh makes the holders 'look' better.
    GAMark[QUOTED] likes this.
  6. Sep 28, 2024 at 12:43 PM
    #7356
    75tranzam
    75tranzam New Member
    Midlothian, Va
    2024 Midnight Black 1794 Limited Edition #751
    The Cupgrip is awesome for big tumblers like Stanley or Yeti.
  7. Sep 28, 2024 at 12:46 PM
    #7357
    GAMark
    GAMark New Member
    Ordered, thank you.
    Tundrastruck91 likes this.
  8. Sep 28, 2024 at 12:48 PM
    #7358
    GAMark
    GAMark New Member
    What is the metal?
  9. Sep 28, 2024 at 7:56 PM
    #7359
    eddiefromcali
    Eddie
    100% Stock
    Machining debris. Nothing out of the ordinary, imo
  10. Sep 28, 2024 at 8:02 PM
    #7360
    6rian
    6rian New Member
    Yup, normal for break in and nothing worrysome. Here's what came out of my rear diff at 4,300 miles. Shavings are fine. Chunks are bad.
    eddiefromcali and H20-bar like this.
  11. Sep 28, 2024 at 10:05 PM
    #7361
    ramnj
    ramnj New Member
    NJ
    ‘24 Platinum
    Bought this Platinum. Traded my 4Runner. I really like this truck. I’m not going to mod this truck but really have to fill these wheel wells and will be looking at you’ll trucks for ideas.
  12. Sep 28, 2024 at 10:26 PM
    #7362
    Kerktam
    Kerktam Lexus truck wanted
    middle of nowhere, up north
    2023 limited TRD OR, 2024 silverado 5.3
    35 tires, 2 inch level kit
    installed Rockville subwoofer under rear seat. its okey, will install different one, its barely noticeable
    SoCal_Erik likes this.
  13. Sep 29, 2024 at 2:59 AM
    #7363
    Woodrow bangs
    Woodrow bangs New Member
    Baltimore
    2023 MBM Platinum
    I briefly thought about it but the labor needed didn’t really make enough sense. I still have too much storage area and won’t miss losing behind seat. Plus this has little modification impact in case it’s ever sold. Just drive 500 miles and I really do like it. And I’m a guy who had a “system” in all my other vehicles. The factory sub is still on and working. It’s like having an extra tweeter lol
  14. Sep 29, 2024 at 3:03 AM
    #7364
    Woodrow bangs
    Baltimore
    2023 MBM Platinum
    Is “Rockville” Temu’s “Rockford”?
    Kerktam[QUOTED] likes this.
  15. Sep 29, 2024 at 4:25 AM
    #7365
    jaxadam
    jaxadam New Member
    What did you use?
  16. Sep 29, 2024 at 12:31 PM
    #7366
    christopherdada2
    christopherdada2 New Member
    2024 white Tundra Limited Trd Off Road
    Hi, where can I buy this bracket for the rear dash camera? Thanks.
    machd08 likes this.
  17. Sep 29, 2024 at 2:27 PM
    #7367
    eddiefromcali
    Eddie
    100% Stock
    Rockville is trash, sorry man. Was it the cheapest one out there?
  18. Sep 29, 2024 at 3:13 PM
    #7368
    ramnj
    ramnj New Member
    NJ
    ‘24 Platinum
    You’re better off using some type of glue or 3M tape. That’s what I did when I had my 4Runner and gonna do when I install my rear camera on my Tundra.
    I tried the bracket method and was a waste on money IMO.
  19. Sep 29, 2024 at 6:18 PM
    #7369
    ColumbiaGorge
    ColumbiaGorge New Member
    Joe
    Columbia Gorge
    24 Limited
    Added Pro flares and Predator steps. Wheels and tires on order should be here this week. I went with Method 305 17s in machine to kind of match the paint.
  20. Sep 29, 2024 at 7:44 PM
    #7370
    SilveradoSwap
    SilveradoSwap New Member
    2024 1794 Edition Tundra
    I couldn't disagree with this more than I do. That mount is super solid if installed correctly. Way cleaner of an install than glue or tape, only place would be onto the headliner, not a chance.
  21. Sep 29, 2024 at 10:55 PM
    #7371
    eddiefromcali
    Eddie
    100% Stock
    Must've failed on the install. I've had mine for about 2 years now. 110° summers and tape I used has held fine, no issues whatsoever.
  22. Sep 29, 2024 at 10:55 PM
    #7372
    eddiefromcali
    Eddie
    100% Stock
  23. Sep 30, 2024 at 9:02 AM
    #7373
    mikev25
    mikev25 New Member
    Kansas
    2022 MGM SR5
    TRD lift, wheels, tires, AlphaRex headlights
    Do you have a link for this?
  24. Sep 30, 2024 at 11:07 AM
    #7374
    rosegrad
    rosegrad New Member
    Birmingham
    2024 Tundra Limited Hybrid Wind Chill Pearl
    Retrax MX Tonneau
    Which is the better design for the 3rd gen Tundra, the short or regular?
  25. Sep 30, 2024 at 12:38 PM
    #7375
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    Triple Grande, No Fat, No Foam.
    You own one and aren't sure?
    I assume you're referring to either cab size (Double/DC or Crew/CC) or box length? (5.5 or 6.5 or 8ft.)
    If so, the answer would be whichever of those suits your needs the best.
    If not one of those, more explanation needed.
    I'm thinking maybe you posted to the wrong thread?
    Kerktam likes this.
  26. Sep 30, 2024 at 2:30 PM
    #7376
    Ausfahrt
    Ausfahrt New Member
    Vermont
    2024 SR5 4X4
    I had my new truck undercoated with fluid film in preparation for our New England winter.
  27. Sep 30, 2024 at 3:10 PM
    #7377
    TheSophist87
    TheSophist87 New Member
    2024 Smoked Mesquite 1794 Edition
    Just installed a new tonneau last night. Next up will be AMP PowerSteps!
  28. Sep 30, 2024 at 5:57 PM
    #7378
    Talkin_Tundras
    Talkin_Tundras New Member
    ‘22 Tundra Limited
    Finally got my tires after installing a leveling kit a couple of weeks ago. Found a deal on some Cooper Discoverer 285/65/20’s. Got these for $350 each, $1500 otd at Discount Tire. Love the look of these. Pretty smooth as well. No rubbing at all
    Miker24, ramnj, bigblue14 and 8 others like this.
  29. Sep 30, 2024 at 6:13 PM
    #7379
    Zudrick
    Zudrick New Member
    2024 Tundra Lunar Rock Limited
    None….so far
    Put some black letters on the tailgate.
  30. Sep 30, 2024 at 7:16 PM
    #7380
    mfa1981
    mfa1981 New Member
    Marcel
    2024 Nightshade Limited
    weekend projects
    2nd wireless charged routed to the center console usb-c plug and oversized ajt cup holders
    461765138_10162939305359523_691937019954_b6826c106cc9f3323aed8f4c11a08d918c125bc1.jpg
    ajt cover and cnc shift knob
    461925690_10162939305389523_803663111413_22bd148cc103518fe5908057e08f23f2f77620d7.jpg
    toyota hard tri-fold
    461835193_10162939305439523_188511904493_ed11046a1b84f4d2003ec48e8e07e447376836cc.jpg
    Miker24, Ausfahrt, ramnj and 3 others like this.
