  1. Sep 29, 2024 at 6:26 PM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    I don’t think the headliner was ever under that molding.
    that front weather strip was garbage on mine also. I just went through a hurricane. It did not leak so I’m no concerned
  2. Sep 29, 2024 at 6:35 PM
    CCLA
    CCLA New Member
    Finally got around to installing some RC DRL pods using TRD PRO surrounds
  3. Sep 29, 2024 at 6:57 PM
    centex
    centex New Member
    Just dove season. Saw one bird. No worries. We came prepared.
    Wallygator, WFD473, Jaypown and 15 others like this.
  4. Sep 29, 2024 at 6:58 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Okay, that's a relief to hear. I did clip it back in with the 4 clips but it just looks different then when I removed it :confused: I guess as long as the clips are holding it up, it won't be an issue.
  5. Sep 29, 2024 at 7:07 PM
    Correct.
  6. Sep 29, 2024 at 7:14 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    when I installed my x3b about 3 weeks ago also noticed the headliner wasn't really under the weather stripping. same with the front rubber strip on the light, was off straight out of the box. whatever morimoto used didn't seem to adhere well, just put it back on with some super glue. been through some rains and 2 washes, so far no leaks.
  7. Sep 29, 2024 at 7:23 PM
    TacomaTRD4x402
    Southern California
    Awesome! Glad I'm not the only one. I also super glued it back on but it still seemed a little lose. Overall, I'm happy with the look of it. Looks way better.
    BR73 and ToyoMafia like this.
  8. Sep 29, 2024 at 8:24 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    Damn
    centex[QUOTED] likes this.
  9. Sep 30, 2024 at 4:12 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Nothing too wild, but I swapped in a DeatschWerks 340c fuel pump and replaced my PCV...
    bflooks, bulldog93, Vendeta2k and 2 others like this.
  10. Sep 30, 2024 at 5:27 AM
    1794TX
    Steven
    N.TX
    '20 1794
    My son went out with my grandson near Ray Roberts lake (North Texas) yesterday and also reported no birds. My uncle has a ranch north of Abilene, and it's plagued with them. But it's bow season now, so no dove hunting...
    smokint likes this.
  11. Sep 30, 2024 at 6:24 AM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
  12. Sep 30, 2024 at 6:28 AM
    101ABNAASLT
    101ABNAASLT New Member
    2021 Tundra Limited 4x4
    No, but now I know I can get the black trim from a 4Runner for my Tundra from Toyota parts online - rather than spray painting them like a lot of people do!
    Dave8699[QUOTED] likes this.
  13. Sep 30, 2024 at 6:46 AM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Couldn't agree more! I think even a SOB Rear Bumper and a true 35 would be a huge improvement
  14. Sep 30, 2024 at 7:20 AM
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    2020 Tundra Limited on 35's
    It was a good weekend to smoke some meat. Did this 10 lb. pork shoulder on Saturday.
  15. Sep 30, 2024 at 7:40 AM
    KroppDuster
    Here. There. Everywhere.
    Bilstein 5100s
    Did some maintenance plus an upgrade.
    Maintenance: Full driveline service to change fluids - front & rear diffs, transfer case, and drain & fill on the trans. Also did an oil change. Truck as 30k on it now and want to get in a good cycle of doing the full driveline every 30k. I also took off my catalytic converter shield. I realized that it's roasting my transmission and likely a contributing factor to high trans temps. Going to monitor trans temps with it off for a while to see how much of a difference it makes.
    Upgrade: I pulled the OEM yellow Bilsteins off and installed 5100s on all four corners. Set the fronts to the middle setting for ~1.5" of lift. I didn't want too much preload. So far, I'm extremely happy with the middle setting. Raised the front while maintaining a great ride. I might go to the top notch one day, but I know I'll need to slap in a 1" block in the back to keep it level if I go that high. My pre & post measurements are below for anyone who's curious. Obviously, the rear did not change since I only swapped the shocks. In my measurements, I did not see the traditional "Tundra lean" for the 2nd Gen that others report. My DS & PS measurements were the same. All measurements are from center of the hub to the bottom of the fender, as close as I could get it.
    Pre-Measurements:
    • Driver Front & Rear: 22" / 24"
    • Passenger Front & Rear: 22" / 24"
    Post-Measurements:
    • Driver Front & Rear: 23.5" / 24"
    • Passenger Front & Rear: 23.5" / 24"
    Before:
    After:
  16. Sep 30, 2024 at 7:45 AM
    centex
    centex New Member
    Looks tasty. Ours was a 16lb wagyu brisket.
  17. Sep 30, 2024 at 7:51 AM
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    That sounds sooo good. I need to up my brisket game, I've only done a few of those.
  18. Sep 30, 2024 at 11:06 AM
    coTony
    Tony
    Montrose, CO
    We have a 2021 4Runner which is what confused be besides not reading close enough. Love our 2021 ORP!
  19. Sep 30, 2024 at 11:16 AM
    Gainer
    Gainer New Member
    Columbus, OH
    2018 SR w/8' Bed
    Leveling kit, TRD wheels, remote start, Hellwig helper springs, TRD Rear sway bar. TRD Rear shocks, Dirty Deed 10" exhaust, S&B Cold Air intake
    Dropped it off this morning and had the coil overs installed today.
    I ordered them from Hotshot Offroad and they shipped them the same day! Wish I would have bought the spacers and rear shocks from them, but I already had them in the garage.
    The local shop only charged me a couple hours to do the install for the front. That was too good of a deal to pass up. I installed the rear shocks and 1" spacer a couple of weeks ago.
    That was a pretty straight forward install.
  20. Sep 30, 2024 at 11:31 AM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM Tundra & 25 TRD Pro Sequoia
    Did things outside, ran rocks over, punched hole in my man card
    Tundra-XP, WFD473, Tundra805 and 16 others like this.
  21. Sep 30, 2024 at 2:02 PM
    Bdiddy
    Bdiddy New Member
    FYI - I received this switch today and installed. It's straight from China (2 week delivery), but worked 100% correct. Word of advice, order the "white" color vs "blue" (at least if you have a 2021 Tundra (or a year in the same 2.5 Gen). I ordered blue and it's off colored compared to the other switches, which are definitely closer to white. Oh well, you can't tell in the day and it's not that bad at night lol.
  22. Sep 30, 2024 at 2:02 PM
    woods
    woods New Member
    2021 SR5 TRD Sport
    Got my wifes oil changed and state inspection today at the GMC dealer. Saw a nice 2nd gen, being traded for a very nice 2.5 gen. I thought to myself "what a smart guy" :amen:
  23. Sep 30, 2024 at 2:53 PM
    stevep0925
    stevep0925 New Member
    Trinity, AL
    19 Cav Blue Limited 4x4
    Upgraded to the bushwakka 180 awning with walls. Been raining past few days in Alabama so I haven't been able to put the walls up with it.
    Have a CVT 79" in tan with walls Imma put up on the for sale side soon..
    Wallygator, Tundra-XP, ATV25 and 7 others like this.
  24. Sep 30, 2024 at 5:23 PM
    Tan-dra
    Tan-dra MUD GANG 2006
    2020 Quicksand SR5
    Bilstein 5100, 35’s on 17” wheels
    Removed the vinyl wrap on my bumper. Back to chrome!
  25. Sep 30, 2024 at 5:25 PM
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    Why? It looked good.
  26. Sep 30, 2024 at 5:28 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    Looks good in Chrome
  27. Sep 30, 2024 at 5:34 PM
    Tan-dra
    2020 Quicksand SR5
    Up close it looked rough since it was my first try at vinyl wrapping. Also I’m going back and forth on the idea of selling this thing so I’m slowly going back to the stock look
  28. Sep 30, 2024 at 5:34 PM
    Tan-dra
    2020 Quicksand SR5
    Yeah I remember hating the chrome before but now I am liking it. I think I just get bored and need to change things to keep myself entertained
  29. Sep 30, 2024 at 5:44 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
  30. Oct 1, 2024 at 3:00 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    That's the reason for 80% of mods I'd guess. I'm guilty myself.
    bulldog93 and 250000yota like this.
