Cargo Light Install
Discussion in 'Electrical' started by iamjaredspires, Sep 30, 2024.
  1. Sep 30, 2024 at 9:42 AM
    iamjaredspires
    iamjaredspires [OP] New Member
    So my brand new 24 Limited didn't come with cargo lights, so I decided to add my own. I tapped into the tailgate light with two 40W lights, and finding out that it's now overpowering the circuit, and causing them to flicker after being on for about 3-5 minutes. I know I should probably use a relay, but just trying to figure out what fuse these lights should be on, and how I can possibly not completely re-run all of my wiring. Thoughts?
  2. Sep 30, 2024 at 11:52 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Welcome to the forum.
    You say 'cargo' lights, but I'd guess you are referring to bed lights.
    You should be using some kind of LED strips or lights.
    They draw a low current and can be tapped into the cab cargo light circuit without a relay.
    I used these..
    Amazon.com: Ampper White LED Rock Light for Bed Track, 60 LEDs Cargo Pickup Truck Bed Lighting Kit W/Switch Fuse for Truck Bed, Foot Wells, Under Car, Rail Light and More (20 Pcs) : Automotive
    @mattgecko has some nice bed light kits available.
    I guess they would work in your Gen 3..
    MATT GECKO LEDS
    You can find wiring diagrams here.
    Ultimate TUNDRA Wiring Diagrams Collection | Toyota Tundra Forum (tundras.com)
  3. Sep 30, 2024 at 12:26 PM
    iamjaredspires
    Thanks for the info! I chose not to go with strips because I wanted a more OEM look. I've also already cut into the bed and installed the lights, so just looking for a solution for my current setup.
