Oil leak
Discussion in '2.5 Gen Tundras (2014-2021)' started by Boodles07, Sep 30, 2024.
  1. Sep 30, 2024 at 9:26 AM
    Boodles07
    Boodles07 [OP] New Member
    2017 DC OFF ROAD Quicksand
    IMG_1466.jpgHey guys, if you saw this oil in this location, where would you suspect it is coming from? Thanks in advance.
    It seems to be “leaking” or “seeping” and or burning oil because after one month of topping off oil, I have lost some oil again. It’s not a full quart but close. Still within range on dipstick but not maintaining full level.
  2. Sep 30, 2024 at 10:50 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Cam towers are known to leak. If those are not the culprit, then timing cover.
    Boodles07[OP] likes this.
  3. Sep 30, 2024 at 10:51 AM
    Boodles07
    Either one of these leaks present with issues that immediately need addressing?
  4. Sep 30, 2024 at 10:56 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Not really.
    I would keep an eye out for oil getting on the serpentine belt, as that will shorten the service life of the belt.
  5. Sep 30, 2024 at 11:54 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Yup - nothing like a slow oil leak to soften up hoses and belts (think AC hoses too). If there is an AC or power steering hose getting oil - clean it and put another slightly larger hose over it (secured) to protect it until a repair is possible.
  6. Sep 30, 2024 at 1:05 PM
    smokint
    smokint New Member
    2017 1794 2002 Tacoma
    That looks to be a bolt on the fluid coupling bracket, that the fan clutch mounts to. Here’s a pic of mine (no oil leak):
    Here’s another pic of that bolt on a repair job:
    Here’s the bracket( it’s connected to the timing belt cover )
    Here’s a video of a mechanic fixing a crankshaft oil seal leak (that could be your problem):
    https://m.youtube.com/watch?v=5JXsgXhYZPE
    That bolt would be #6 in this diagram, I think :
    That’s my best guess, but I’m not a mechanic! Good luck
  7. Sep 30, 2024 at 2:09 PM
    Mr Badwrench
    Mr Badwrench New Member
    I have the same thing OP does. I hope I can fix it before it gets cold. I'm fucking broke on top of this
    I am really impressed with Toyota's Yugoslavian quality as of late. I am also really sarcastic as of now.
  8. Sep 30, 2024 at 5:49 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Add me to the list. Mine is leaking in the same general area. I’m losing oil on the dipstick, up to 1.5 quarts over 5000 miles. But nothing is dripping on the ground.
  9. Sep 30, 2024 at 6:00 PM
    smokint
    smokint New Member
    How many miles on your rig, Phil?
  10. Sep 30, 2024 at 7:15 PM
    ZPhilip
    Philip
    West Chester, PA
    88k
  11. Sep 30, 2024 at 11:03 PM
    smokint
    smokint New Member
    Roger that
  12. Oct 1, 2024 at 4:14 AM
    smokint
    smokint New Member
    Might be worth pulling the fan/shroud to get a better look..not much room down there…you’ve got low miles, and might be worth 1-2$K fix if your gonna keep her…or just buy oil..,these kinda leaks don’t seem to be catastrophic
  13. Oct 2, 2024 at 4:49 AM
    Boodles07
    I am having my leak assessed by a reliable mechanic in November. Will report here. Thx for the replies. Any and all theories welcomed so I can tell them what I think it is before they even look at it.
    Mr Badwrench likes this.
  14. Oct 2, 2024 at 5:53 AM
    Gene_in_FL
    Gene_in_FL SUPER genius
    FLORIDA
    2016 SR5 DC 5.7 2021 SR5 DC 5.7
    That's especially funny to me cuz I'm a guy who almost bought a Yugo back in 1988. LOL
    The same company (Zastava) made great AK47's. Cars ... no so much. :rofl:
  15. Oct 19, 2024 at 8:48 AM
    Mr Badwrench
    Have you found the source of this leak OP? I've spent hours with a mechanic's mirror and flashlight from every angle imaginable trying to solve this. Short of removing parts, I have given up on mine for now.
  16. Oct 26, 2024 at 7:16 PM
    Boodles07
    Sorry, just seeing this. I have not had it looked at yet. It’s happening in November.
    Mr Badwrench[QUOTED] likes this.
  17. Oct 26, 2024 at 9:44 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Please do report back when you get it looked at.
    Boodles07[QUOTED][OP] likes this.
  18. Nov 17, 2024 at 9:59 AM
    Boodles07
    My truck is going into the shop tomorrow. Will report on findings.
  19. Nov 18, 2024 at 7:41 AM
    Boodles07
    So they just called from the shop. $115 to do the oil leak diagnosis and what they found was that the cam towers are leaking. He said it was so small that he would not recommend any action at this time. He said the cost of the repair and the labor would be prohibitive for such a small leak. He basically said keep an eye on it and if it gets worse to the point of actually dripping on the ground that we should then do something. I certainly don’t want to pollute oil. They would have to spend about 16 hours to repair the leak and the cost would be near or beyond $5000! F that!
  20. Nov 18, 2024 at 10:55 AM
    Boodles07
    I also told Toyota that they should be ashamed for not addressing this problem properly and that my next truck will not be a Toyota unless they fix my leak LOL.
  21. Nov 18, 2024 at 1:37 PM
    Mr Badwrench
    Thanks for responding @Boodles07 . I'm not exactly impressed either. Like you said though, for 5000, fuck that.
  22. Nov 18, 2024 at 5:07 PM
    Adamace1
    Adamace1 New Member
    2021 SR5 Tundra doubleCAB
    None....
    They are currently putting full long block motors in over 100k trucks. You think their worried about a little leak that doesn't drip on the ground on a 8 year old truck?
    Good luck with another truck. I only have a tundra because I'm tired of other brands reliability. Blown motors at 7 months. Failed transmission at 3 months. Windows falling out door at 3 weeks, ect. Ect.
  23. Nov 18, 2024 at 5:14 PM
    Mr Badwrench
    They should care. It's their reputation. lol :rofl: of course they don't. Tundra owners are not even a sliver on their pie chart.
  24. Nov 18, 2024 at 6:01 PM
    Boodles07
    The point is that it’s a known issue. They had years and years to fix a known issue and didn’t? That’s just weird and wrong. They should care and address the problem. I’ve had many cars with this many miles. My Honda Element never leaked oil and we had that puppy up to around 187,000 miles.
  25. Nov 19, 2024 at 7:51 AM
    yakeng
    yakeng 3URFE Apologist
    Sooooo, your next truck will be a Ridgeline?
    Investigation Launched over Reports of Failures in up to 1.4M Honda Cars
    Or maybe not? There is no perfect car/truck. I'd say the Tundra and it's seeping (that seems to have little to no impact on reliability) is pretty good. Don't lose to much sleep over this.
    ZappBrannigan likes this.
  26. Nov 19, 2024 at 11:59 AM
    Adamace1
    Adamace1 New Member
    None....
    Well the new engines i
    Onnew Tundras are bowing up.
    It's a tiny/ small leak for the few that have it. What do you want them to do? A 100year 1,000,000 miles warranty on all seals?
    AZBoatHauler likes this.
  27. Nov 19, 2024 at 12:23 PM
    AZBoatHauler
    So.Arizona
    They just built 300,000 trucks with debris in the block - your expectations may be high.
  28. Nov 19, 2024 at 1:26 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I like that shop / mechanic. Being honest that it isn’t a big deal and just to monitor it is honest advice. They could have taken you to the cleaners with a repair estimate and telling you that it had to be done or risk catastrophic engine failure…..
    That said, is losing almost a quart between oil changes not something to be worried about? Is it as easy as just monitoring and replacing lost oil in this case or is it just delaying a potentially massive repair?
  29. Nov 19, 2024 at 1:27 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Is it losing a quart because of the minor leak?
  30. Nov 19, 2024 at 1:40 PM
    shawn474
    MoCo, Maryland
    Not sure; it isn't my truck. That's where my question was leading......could that "small leak" cause a quart difference between oil changes??? @Boodles07.....
