2018 drl's out
Discussion in '2.5 Gen Tundras (2014-2021)' started by boloson, Sep 28, 2024.
  1. Sep 28, 2024 at 11:06 AM
    boloson
    boloson [OP] New Member
    Hey guys
    Got the 2018 led headlight assembly on the group buy when roman was still around retro fitted onto my 2014 tundra. My drl's on the driver's side is out. Is there a way to fix this or is buying an entire headlight assembly the only option?
  2. Sep 28, 2024 at 11:45 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Unless you have a wiring issue, probably need to get a new assy
    1lowlife likes this.
  3. Sep 28, 2024 at 12:05 PM
    boloson
    As I figured. Thanks
    MadMaxCanon[QUOTED] likes this.
  4. Sep 28, 2024 at 12:30 PM
    Plug that light into the passenger side and see if it is still out.
  5. Sep 28, 2024 at 1:11 PM
    boloson
    Ok ill give that a shot. Figured it's the actual light itself since the passenger side works
    FlyingWolfe likes this.
  6. Sep 28, 2024 at 1:26 PM
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    2018 TRD Off-Road Inferno
    Was gonna say if you have a wiggie/voltage stick you can make sure the plugs have voltage in em but plugging into the passenger side works as well. :thumbsup:
    Hopefully a loose connection or something dumb and not the light itself. :spending:
  7. Sep 30, 2024 at 6:23 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Might be that crappy telephone wire Toyota uses. I it come apart on driver's side fog light.
