Rear strut mount size
Discussion in '1st Gen Tundras (2000-2006)' started by jphillips1987, Sep 28, 2024.
  1. Sep 28, 2024 at 7:35 PM
    jphillips1987
    jphillips1987 [OP] New Member
    2000 Tundra
    Bone Stock
    So I bought some new Bilsteins 5100 for my 2000 tundra to replace to original blue and yellows Bilsteins. but when I went to install the rear ones the mount was to narrow to fit (see picture)
    Has anyone has a similar problem? its supposed to fit right in, now im wondering if I bought the wrong ones and which ones I need to buy.
    Screenshot 2024-09-28 at 6.19.31 PM.png Screenshot 2024-09-28 at 6.19.07 PM.png
  2. Sep 28, 2024 at 10:48 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    shifty` likes this.
  3. Sep 29, 2024 at 7:23 AM
    jphillips1987
    2000 Tundra
    Bone Stock
    I think you are right. I bought them off eBay advertised as fitting my tundra =( So I guess if any one buys stuff off eBay double check the parts fit because the sellers aren't
    w666 likes this.
  4. Sep 29, 2024 at 7:48 AM
    ATBAV8
    ATBAV8 Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
    There's also a good chance some items on eBay are counterfeit. Worth noting. Buy from a reputable source.
  5. Sep 29, 2024 at 8:27 AM
    Fortunately, if you bought it within the last 4-6 weeks (sometimes more), you can easily setup a return. Clearly it doesn't fit. eBay is sadly more favoring of their buyers than their sellers. And I'm saying that as a semi-regular seller on there. You're covered.
    Be sure to file the return "Not as described" so the seller gets dinged for the fact this WILL NOT fit a Tundra. It's for Seqoia, and when I plugged it in at the Shock Surplus site, it clearly shows it isn't a fit for Tundra.
