Best repair manual?
Discussion in '3rd Gen Tundras (2022+)' started by YetiPilot, Feb 5, 2024.
  1. Feb 5, 2024 at 12:37 PM
    YetiPilot
    YetiPilot [OP] New Member
    2022 Blueprint Tundra Limited Off-Road Double Cab 6.5' 4X4
    My 2022 TRD Off-Road is ending its warranty here soon. Every recommendation I get from the dealer is hard to find a repair to on YouTube or in a forum as this generation is still new. Finding things like torque specs seem incredibly hard to find so far.
    What are the repair manual options out there? I’m struggling to find anything at all.
    Thanks for any input.
  2. Feb 5, 2024 at 2:37 PM
    jctmundra
    jctmundra New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
    @ryanwgregg
    Please confirm for TIS -
    $545ish for the MONGOOSE PLUS MFC3 (Amazon)
    $505 / year for standard subscription
    Does the MFC3 need to be purchased from Toyota for full functionality?
  3. Feb 5, 2024 at 2:49 PM
    KroppDuster
    Here. There. Everywhere.
    Bilstein 5100s
    Putting that on Ryan to answer is a tad unfair. He's just passing along info. Not acting as customer service for TIS. :)
    The TIS subscription is just access to the same PDFs that the techs have access to. These will give you step-by-step instructions on how to remove or install various components. The J2534 connector is only needed if you're going to use Techstream Lite. You should be able to use just about any J2534 connector, but Toyota only "recommends" the Mongoose because it's the only one they've tested and sell.
    Using Techstream is an not part of the $505/yr subscription. You want that, then you need to bump up to the $1360/yr subscription. See the screenshot (from the same site you already visited):
    ryanwgregg likes this.
  4. Feb 5, 2024 at 3:00 PM
    KroppDuster
    Bilstein 5100s
    On a side note...I did not realize (until @ryanwgregg mentioned TIS again) that they offer 48-hour access to Techstream for $70.
    If I can use Techstream to "sync" the radio ID of a used 14" headunit (if I decide to do that swap/upgrade), then I might snag a cheaper J2534 connector from Amazon and try using Techstream for 48 hours. Pretty much everything else I considered using Techstream for I was able to accomplish with the Carista app and an OBDII dongle.
  5. Feb 5, 2024 at 3:09 PM
    jctmundra
    Northern VT
    Ugh, I should have read closer as I missed professional was required for techstream diagnostics portion. My concern was if a J2534 by itself was sufficient or there was toyota specific IP accompanying the unit when purchased form toyota which has been answered.
    Too bad the HPTuners MVPI interfaces do not pass though J2534.
  6. Feb 5, 2024 at 3:48 PM
    KroppDuster
    Bilstein 5100s
    It is somewhat hit & miss. Best case is to read through the Amazon reviews for the cheaper cables. A lot of them will say whether or not they work with legit Techstream and, in many cases, which versions they work with. However, you can afford to cable several times with the Amazon cables at ~$25-$40 each before you start approaching the $500 of the Mongoose. :rofl:
  7. Feb 5, 2024 at 7:18 PM
    jctmundra
    Northern VT
    Can go with the cheaper, yet reading the HPT forum, ECM's get bricked when communication suddenly drops/corrupted. Hopefully, you get better parts with the higher priced units.
    Rcflyersd likes this.
  8. Feb 11, 2024 at 6:04 PM
    unbeso
    unbeso New Member
    If you dm me I have the master collection of manual my buddy gave me the pdf version
  9. Feb 11, 2024 at 6:49 PM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    Hoody likes this.
  10. Sep 29, 2024 at 6:11 AM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
  11. Oct 9, 2024 at 2:24 PM
    TwiZtedBiker
    TwiZtedBiker New Member
    2024 limited TRD Off-road
  12. Oct 9, 2024 at 4:50 PM
    22whatwedo
    The Open Road
    Not yet, I am still grappling with having to download instead an honest to God real book manual.
  13. Oct 9, 2024 at 9:29 PM
    chrisgibbs707
    chrisgibbs707 New Member
    Socal
    2022 Tundra SR5 4x4
    It’s legit. Crazy how in depth it is, but I’m used to dirtbike repair manuals. It’s not one giant pdf, though. It’s an html that hyperlinks to other html’s with all the info, but contains procedures, torque specs, necessary tools.
  14. Oct 24, 2024 at 9:39 AM
    kamaaina1
    kamaaina1 New Member
    2024 Tundra TRD PRO
    Appears 2024 Tundra Haynes/Chilton print versions are still not available.
  15. Oct 26, 2024 at 4:38 AM
    L-P-G
    L-P-G New Member
    2024 Platinum
    As an ex-mechanic, at the shop we used to use Mitchell-1 and All-Data. They provide you with all the same docs, TSBs, recalls, etc, as the OEMs. They work directly with OEMs to get all the information and make it available for professional repair shops. The version for shops is expensive because it includes all makes and models, but they both have a DIY subscription for weekend warriors, they main difference between the pro and DIY is that DIY you pay a yearly ($40-$60) fee per vehicle you include in your sub.
    I'm no longer wrenching but I keep subs DIY subs into both for when I need to work on my vehicles or I want to look at TSBs.
    https://eautorepair.net/ - Mitchell 1
    https://www.alldata.com/diy-us/en - AllData
    I use both because Mitchell 1 has superior interactive wiring diagrams and search functions, but their navigation menu sucks. AllData has great navigation menus but lacks in wiring diagrams.
  16. Oct 26, 2024 at 7:04 AM
    22whatwedo
    The Open Road
    I went in there and they do not appear to have 3rd Gen Tundra PDF’s yet
  17. Oct 26, 2024 at 7:08 AM
    22whatwedo
    The Open Road
    They don’t appear to have anything past 2014 for a Tundra
  18. Oct 26, 2024 at 7:43 AM
    pursuit2550
    pursuit2550 New Member
    Yup, I have the one that came with my supercharger. It works just fine for normal stuff. I wouldn't go programming the ECM with the cracked software but all other things, it works perfect.
  19. Jul 4, 2025 at 10:50 AM
    Bambistew
    Bambistew New Member
    I use workshopmanuals.com for all my repair manual needs. I’ve got a 2022 TRD Off-Road too, and like you, I struggled to find anything reliable with proper torque specs and step-by-step instructions. YouTube is hit or miss, and most forums only cover the basics. The workshop manuals I downloaded from workshopmanuals.com has been a game changer—covers everything from wiring diagrams to advanced diagnostics.
  20. Jul 4, 2025 at 11:13 AM
    jctmundra
    Northern VT
    Link to 22+ tundra ?
  21. Jul 4, 2025 at 11:45 AM
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '25 Limited TRD-OR
    You have a 2011, 2021, and 2022 Tundra?
  22. Jul 4, 2025 at 12:09 PM
    60centenergy
    60centenergy Mods Member
    Zack
    GVL
    ‘24 Lunar Rock SR5 TRD Sport
    It’s not ideal but I got a 2 day subscription to TIS and downloaded all I thought I would need. There’s no way you could download it all though. Way too much info.
    I just picked a weekend I had nothing going on and could focus, exercised my mouse click fingers, got some snacks then went to town downloading what I could lol
    22whatwedo likes this.
  23. Jul 4, 2025 at 12:18 PM
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    I want to do the same. Find all torque specs in there ?
    60centenergy[QUOTED] likes this.
  24. Jul 4, 2025 at 12:26 PM
    60centenergy
    Zack
    GVL
    Yes, torque specs for all maintenance procedures. It’s very detailed.
    Only thing that sucks is there are hyperlinks to different sections within a section that it may reference. It works when clicking in TIS but once downloaded that hyperlink will break. As long as you have all the sections you need you can just manually pull up the referenced section.
    Mallcrl likes this.
  25. Jul 4, 2025 at 12:37 PM
    60centenergy
    Zack
    GVL
    Now, if someone or a group of us got together and linked ALL the sections together and made one massive pdf file… I mean, that would be “chefs kiss”.
  26. Jul 4, 2025 at 1:43 PM
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '25 Limited TRD-OR
    This is the way...
