  1. Sep 27, 2024 at 6:58 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    THE '40.
  2. Sep 27, 2024 at 6:59 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    wholly shit.
  3. Sep 27, 2024 at 7:16 PM
    Is there an online site where we can pool money to dare you to drive through it with your Tundra? :D
    bmf4069, Sirfive, BroHon and 2 others like this.
  4. Sep 27, 2024 at 7:21 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    Those $100 scamazon snorkel kits are now lookin a bit more enticing
    bmf4069, 455h0le_dachshund and BroHon like this.
  5. Sep 27, 2024 at 7:23 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    Just put a Lock-n-Lube grease coupler on my grease gun and wow. Absolutely incredible. Driveline greasin' tomorrow.
  6. Sep 27, 2024 at 7:24 PM
    BroHon
    BroHon What day is it?
    Bro
    Final Outpost/Bitch Mitten
    '00 SR5 AC V8 4x4
    Iron oxide weight reduction
    Holy F that's brutal.... man those poor people. :eek::(
    Mater likes this.
  7. Sep 27, 2024 at 7:26 PM
    We use them at work on air handlers, they are pretty awesome. I also made them get us the LnL grease gun too, no spring thingy. They are a tad less messy, but still need to be burped every now and then.
    I’m a little anal at work about greasing, my partner gets it. I clean the zerk before……. And after greasing. The next time you come for service, it looks nice and clean, not a huge dirty mess
  8. Sep 27, 2024 at 7:31 PM
    Azblue
    The Dirty T ( ^_^)_且
    Ah, you do realize how that sentence comes across to somebody like me with the mind of a 14 year old and has been having a few beers.
  9. Sep 27, 2024 at 7:32 PM
    It’s 730, only a few?
    bmf4069, Mater and Azblue[QUOTED] like this.
  10. Sep 27, 2024 at 7:32 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    You'd be mad if you saw some of the bearings in our AHUs. Look like they haven't ever been wiped off.
  11. Sep 27, 2024 at 7:36 PM
    I’ll change a bearing if I have to, but I really don’t want to. So if I can somehow prevent that, I will.
    Also some of the units are big, but not a lot of access, so your laying all over shit trying to get a belt on or change a pulley, it makes the experience a little less shitty when it’s kinda clean
    bmf4069 and Mater like this.
  12. Sep 27, 2024 at 7:43 PM
    JakeJake
    2000 Tundra AC 4X4
    Thats my approach around the shop. Take the 10 minutes to set up the work area/cut station/whatever and always clean off any oil/grease on new steel before working with it. That oil from the mill is almost as bad as anti seize.
    bmf4069 and FrenchToasty[QUOTED] like this.
  13. Sep 27, 2024 at 7:44 PM
    I’ve got one on the shop bench but haven’t used it . It’s so bulky I felt like I couldn’t lock onto a few of the driveline zerks. I should probably give it a try. I like my super old school tip that latches really easy.
  14. Sep 27, 2024 at 7:52 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    Most of our shit is like 30 years old and hasn't had anything other than filters, grease, and belts done. I had to use a leaf blower to clean out the outdoor air intake on one the other day looked like it was wearing a sweater.
  15. Sep 27, 2024 at 7:53 PM
    Post a pic of them side x side to see if the diameter is different? I want to think the LnL is a little skinnier……..
    shifty`[QUOTED] likes this.
  16. Sep 27, 2024 at 7:53 PM
    JakeJake
    2000 Tundra AC 4X4
    Hopefully it fits all the zerks, because it's one of those how did I ever live without this type things.
    I had this one on the bench acclimatizing to the shop for a couple of months. I was talking to a buddy on the phone, installed it, and greased a few zerks on the forklift with one gloved hand and nary a drop of wasted grease. Generally this is a three hand job and I end up covered in the mess.
    I'll report in tomorrow how it does with the driveline zerks.
    Edit 2:
    This may be the first "Made in South Africa" thing I've ever seen.
  17. Sep 27, 2024 at 8:00 PM
    We’ve got some 6’ tall blowers from like 1956 that have a 2” shaft that sits in a weird oil bath……. (Buffalo blowers, if you want to CIO(check it out))
    When I first started, they’re like it doesn’t work……. Motor is same age and passed megger test. Bert and Ernie before us put a bigger pulley on the drive end, so it was over amping. It took us a few tries to get the right 3 groove pulley, but she is still crankin!!!!
    Festerw[QUOTED] likes this.
  18. Sep 27, 2024 at 8:09 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    I came across this relic the other day. There were maybe half a dozen or so when I started 17 years ago, pretty sure this is the last one. They were made about 10 minutes down the road, the outlet it's plugged into has a built in 15 amp screw in fuse.
  19. Sep 27, 2024 at 8:14 PM
    JakeJake
    2000 Tundra AC 4X4
  20. Sep 27, 2024 at 8:21 PM
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    I love driving. Especially alone. My record is Los Angleles, CA to College Station, TX. 27 hours. 8 people in a 1990 suburban.
  21. Sep 27, 2024 at 8:48 PM
    we have probably 30+ of these throughout our buildings, some in women’s restrooms, sometimes you’ll find a huge duce in one. IMG_6781.jpg
    bmf4069, JakeJake[QUOTED] and Azblue like this.
  22. Sep 27, 2024 at 8:55 PM
    But it’s a urinal. :monocle:
    Where’s the logic?
    455h0le_dachshund and Azblue like this.
  23. Sep 27, 2024 at 8:58 PM
    Look at all that real estate
  24. Sep 27, 2024 at 8:59 PM
    Seems like a lot to straddle, but okay.
  25. Sep 27, 2024 at 9:01 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Agreed. Have one at the shop.
    I got one of those fancy no spring thingy guns at home that I haven't put a tube into yet. Pistol grip with selectable high volume or high pressure. Looks neat.
  26. Sep 27, 2024 at 9:04 PM
    daveeasa
    I love long drives as well. Done the SD to PDX haul a few times solo. It’s long but it’s a good accomplishment to knock it out in one pull.
    I would love to get a 7-12 passenger vehicle and be the driver for a family road trip. But that doesn’t seem like it’s in the cards anymore.
    I usually binge a series of podcasts to keep my brain alert. I do cramp up a little though and the constant coffee and sugar isn’t all that nice on the gut.
  27. Sep 27, 2024 at 9:06 PM
    Yep that’s the one, with a bunch of orange “rear end” plugs?
    They just sent me a catalog, the coupler and the gun are all I’m really interested in
  28. Sep 27, 2024 at 9:09 PM
    I don’t know the logic, I’m just stating what I’ve seen…… kids do some stupid shit…….
  29. Sep 27, 2024 at 9:12 PM
    Can’t be worse than the co-ed bathrooms at Zoo-Mass (U-Mass) separated by a flimsy wall you can look over.
    Sirfive and FrenchToasty[QUOTED] like this.
  30. Sep 27, 2024 at 9:32 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Well shit. I'm gonna be spending some time in downtown houston, so i was shopping for a bmx bike to cruise around on, pickup lunch for grandma, see the sights...whatnot. I'm not searching for a sachs madass, i just dont want to have to walk everywhere, and CL dumps this on me. How am i supposed to buy anything else?
    https://houston.craigslist.org/bik/d/pearland-high-wheel-bicycle/7788187403.html
    bmf4069, BroHon, Superdave1.0 and 3 others like this.
