How much ATF lost with radiator replacement?
Discussion in '1st Gen Tundras (2000-2006)' started by mobicola, Mar 31, 2020.
  1. Mar 31, 2020 at 4:44 PM
    mobicola
    mobicola [OP] New Member
    2006 Tundra Double Cab XSP
    I had a new radiator installed in my 06 double cab 4.7 a couple weeks ago. Since there is no dipstick should I go through the trouble of taking it to a shop to have the level check and refill procedure done??
  2. Mar 31, 2020 at 5:25 PM
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    On my 06 double cab,i had a transmission cooler. I don’t think my trans lines went through the radiator.
    i would double check for you but i sold the truck last week
  3. Mar 31, 2020 at 6:07 PM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Lift, Rims, Bigger Tires, Nerf Bars, Black Out Emblems
    The transmission fluid does go through the radiator and yes if you're positive the shop that did the radiator replacement didn't top off the transmission fluid you need to get it done. You lose enough to make a difference and to make it worthwhile as far as I'm concerned.
    ColoradoTJ and FrenchToasty like this.
  4. Mar 31, 2020 at 7:38 PM
    mobicola
    I know for sure the ATF level was not checked after radiator replacement. From what I understand the transmission has to be at a certain temp range and the level is then checked from underneath and that was not done.
  5. Mar 31, 2020 at 11:32 PM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    They probably plugged the lines when they removed them from the radiator just to prevent dripping everywhere and on everyone. You also have to consider the fluid in the old heat exchanger as well. Long story short, I think about 8-12oz total will leak and/or be removed with a radiator swap. A fluid check is prudent in my opinion.
    tvpierce and speedtre like this.
  6. Apr 1, 2020 at 10:16 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    When I did mine, I used hose pinch off pliers so really none was lost. Wouldn't hurt to have it double checked though.
    Filthyphil likes this.
  7. Apr 1, 2020 at 10:19 AM
    Not only check it, now would be a great time to do a drain+fill on the transmission if it hasn't been done in a while.
  8. Sep 25, 2024 at 6:31 PM
    Katherine549
    Katherine549 New Member
    2005 Toyota Tundra 2x2
    So if I pinched it off as well and only lost....less than a teaspoon of fluid...probably more like 1/2 tsp fluid...would I still need to replace that or is it fine? If I do, which it being such a small amt...I could probably just do it at home, correct? Thanks in advance.
  9. Sep 25, 2024 at 6:34 PM
    Your transmission is sealed. If you're 100% positive it's only a thimble or so of fluid, I can't imagine it'll make a huge difference. But there is a process to follow with the sealed trans on the '05-'06 as Faye shows in this video.
    w666 likes this.
  10. Sep 26, 2024 at 6:04 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    I have a 2006 Double Cab (different radiator than the Access Cab, don't know what you have). When I swapped my radiator, I also pinched my cooler lines. I certainly lost more fluid than a thimble's worth. Don't know how much I lost though... So I took the opportunity to add more fluid, then check the fluid level (and remove the excess fluid). I followed Faye's video that Shifty linked above, everything worked out great. You should probably do the same.
    w666, shifty` and FrenchToasty like this.
