06 tundra ac front wires
Discussion in '1st Gen Tundras (2000-2006)' started by Capttundra307, Sep 22, 2024.
  1. Sep 22, 2024 at 6:27 PM
    Capttundra307
    Capttundra307 [OP] New Member
    I’m rebuilding a 2006 Toyota Tundra AC front clip. I can’t find were these 2 wires go ? They are around the headlight on both sides.
    one is Yellow w Yellow clip, the other is black w grey clip. many help appreciated.
  2. Sep 22, 2024 at 9:08 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Pretty sure all yellow clips are airbag sensors on a Toyota. The front should have two, one on each side of the truck (Between the headlight and the radiator)
  3. Sep 22, 2024 at 11:01 PM
    Capttundra307
    I had to replace the radiator support would the airbag sensors have been attached to the support?
  4. Sep 22, 2024 at 11:13 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Won’t know till the morning I can check but I think your second plug is for the horn blue circle (one on each side)
    red circle is the airbag
    the passenger side of the truck mirrors the driver side - 2 horns and 2 airbag sensors
  5. Sep 23, 2024 at 4:52 AM
    Yellow plugs are typically indicative of SRS (safety restrain system).
  6. Sep 26, 2024 at 4:58 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    The yellow A11 Airbag Sensor is indeed located adjacent or attached to radiator support. I would also consider if you haven't already, clean that Airbag connector that appears to have corrosion.
    Being an 06 AC, the grey connector, it's location and it's Pink/Violet conductors, should be your A6 LH side ABS speed sensor.
    Side comment....our horns only use 1 conductor connectors. It receives it's GND when bolted to the body.
    shifty` likes this.
