Torque App PID for 22 Tundra; Trans Temp
Discussion in '3rd Gen Tundras (2022+)' started by TiluDrop, Apr 16, 2022.
  1. Aug 19, 2024 at 2:04 PM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    I also have torque pro. Which PID did you use? Thanks.
  2. Aug 19, 2024 at 3:10 PM
    JayDee
    JayDee New Member
    I don't know the PID number. I just selected the sensor named "Transmission Temp".
  3. Aug 19, 2024 at 3:32 PM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    Awesome. I’ll try that. Thanks.
  4. Sep 15, 2024 at 12:14 PM
    Pstan
    Pstan New Member
    Did that work for you ARB 1977?
    And....what app are you trying to use, and what hardware to plug into the port?
    thanks. Stan
  5. Sep 15, 2024 at 2:09 PM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    I messed up I have the fusion app, not torque pro. I may download it. I have a kiwi 3 adapter. Thanks for checking.
  6. Sep 15, 2024 at 3:56 PM
    JayDee
    JayDee New Member
    Torque Pro only runs on Android phones or tablets. It work's well with my 5+ year old generic OBDII adapter. I've been looking for an App that works well on an iPhone and just downloaded FushionOBD and it's not nearly as full featured as TorquePro. I had to buy another OBDII adapter to work with iPhone as this phone only supports devices with Bluetooth 4 or greater, my old adapter is only Bluetooth 2.0.
    Unfortunately the new cheap OBDII adapter that supports Bluetooth 4.0 that I just bought off eBay looses it's connection to the phone after about 15 seconds.
    Fusion OBD doesn't list the Transmission Temp so you'll need to know the PID to display it (which I don't). I do like that Fusion OBD will allow you to display values under CarPlay on the Trucks head unit but it's limited to lines of text. It only displays the cool looking gauges on the phone.
    I thought about getting one of those plug-in Android adapters that allow you to run any Android app on the truck head unit (even with an iPhone for Internet). Then I could run TorquePro on the truck's head unit and display all of the cool gauges as well. I've seen people doing this on a Ford Lightning. I would still need to get a reliable Bluetooth 4.0 OBDII adapter, however.
  7. Sep 16, 2024 at 2:27 AM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    I had torque Pro years ago. Now that I think of it I had an android at the time.
  8. Sep 16, 2024 at 7:38 AM
    Tundraman479
    Tundraman479 New Member
    2024 Tundra Crewmax TRD Sport Lunar Rock
    TRD Pro Suspension 275/60r20 Wildpeaks
    I have been using an app called Car Scanner on my iPhone and it shows most of the readings I used to be able to see on my 2nd gen tundra.
    I can see trans temp and what gear the trucks in. You can also see boost but it isn’t zeroed it starts at atmospheric pressure.
  9. Sep 16, 2024 at 7:49 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    can you see PID details for the trans temp?
  10. Sep 17, 2024 at 6:38 AM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
  11. Sep 18, 2024 at 1:55 PM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    No. Sure wish I could find it so I could manually enter it in other Apps like OBD Fusion. I’ve been asking everywhere for over a year with no luck. Even talked to the app programmers.
  12. Sep 23, 2024 at 7:15 AM
    GAMark
    GAMark New Member
    What are you displaying the gauges on?
  13. Sep 23, 2024 at 10:31 AM
    PNW Tundra Mike
    Southern Cal
    My setups (only used during travel)
    These pics using Car Scanner iPhone App.
    Tundraman479 likes this.
  14. Sep 23, 2024 at 10:49 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
  15. Sep 23, 2024 at 7:43 PM
    Tundraman479
    The bottom blue one.
  16. Sep 24, 2024 at 1:38 AM
    JayDee
    JayDee New Member
  17. Sep 24, 2024 at 5:21 AM
    Johnsonman
    Austin
    Sequoia
    Ah did not catch that detail - thanks.
  18. Sep 24, 2024 at 10:06 AM
    CORam
    CORam New Member
    I display them on my cell phone which I have sitting in a mount that is attached to my windshield. The phone sits to the left of my steering wheel. I'll try to remember to get a picture of the setup.
  19. Sep 24, 2024 at 10:20 AM
    Johnsonman
    Austin
    Sequoia
    I use an old phone for Torque so I don't get distracted switching things around on the day to day phone. Magnetic mounts for each and in each car make is fun to use. Same setup works on all my vehicles for consistency and ease of use.
  20. Sep 24, 2024 at 10:35 AM
    #50
    CORam
    CORam New Member
    That's a good idea!
