Off-road/street princess suspension
Discussion in 'Suspension' started by Dave8699, Sep 20, 2024.
  1. Sep 20, 2024 at 5:20 PM
    Dave8699
    Dave8699 [OP] Trackrat
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    Hello guys so I just joined the 2.5 gen club. I have a 1st gen tweaked up and now want to tweak the 2.5.
    I definitely want to join the 37 club In the future so would like to know for the guys that run 37 what would you do differently?
    What is the best lift for a street warrior to fit 37. Want it to ride smoothly and still go offload if needed.
    I would like to keep a little rake snice I tow. Or have it level and get airbags so I don't have no sag.
    I emailed Coach builder asking for his recommendation but didn't get a response.
    Yes guys I did use the search function and read tons of threads. Just didn't see none that match my usage.
    Coachbuilder1 likes this.
  2. Sep 24, 2024 at 9:55 AM
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    PM headed your way. thanks for posting.
    Dave8699[QUOTED][OP] likes this.
  3. Sep 24, 2024 at 9:56 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    “I wouldn’t do 37s again” - @BiggHertz, probably
  4. Sep 24, 2024 at 10:03 AM
    AZBoatHauler
    So.Arizona
    I almost tagged him - if you want 37s and functionality off road you need to get real comfy with a grinder.
    I rub all my fender liners when flexed out on 35s.
    BillyB and TRDFerguson[QUOTED] like this.
  5. Sep 24, 2024 at 10:05 AM
    AZBoatHauler
    So.Arizona
    @STravis - what size tires did you get to before cutting the fenders?
  6. Sep 24, 2024 at 10:10 AM
    Dave8699
    NJ
    It's will bearly see off road, just like the look of 37s but if not a good idea I guess I'll do 35s. Just read alot of guys that regret not going 37s.
  7. Sep 24, 2024 at 10:13 AM
    Everything you want doesn’t go together. 37s, soft ride, off road, on road, towing, rake. You have to pick the most important ones to you, and do that. Otherwise it won’t be good at any of them.
  8. Sep 24, 2024 at 10:24 AM
    Dave8699
    NJ
    Totally understand and agree, on my 1st gen I'm running Bilstein 5100 with JBA UCA and icon AAL with air bags.
    I'm looking for something better for the 2nd gen. Technically it will never see off road just like the look so that can be low on the list. Has to ride smooth not Cadillac smooth.
    As for the rake has to be level or a slight rake for towing. Thinking level with bags or something better.
  9. Sep 24, 2024 at 10:27 AM
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    Like others have said, it's going to be choppy-choppy with 37's. I'm on 315/70-18 (35.6x12.4). Cab mount chop done, bumper trimmed up real good. Still rub a bit on the pinch weld. Also will rub in the rear when flexed real good. 37's would be worse, I'm sure.
    AZBoatHauler and TRDFerguson like this.
  10. Sep 24, 2024 at 10:28 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    If you drive fast enough over rough terrain you can self-clearance your fender liners...
  11. Sep 24, 2024 at 10:29 AM
    BillyB
    BillyB New Member
    Billy
    AZ
    I need to pick up the pace, I guess!
  12. Sep 24, 2024 at 10:31 AM
    AZBoatHauler
    So.Arizona
    Jason recommends 80MPH through the cinders.
    BillyB[QUOTED] and TRDFerguson like this.
  13. Sep 24, 2024 at 10:33 AM
    BillyB
    BillyB New Member
    Billy
    AZ
    I think I'm going to need a shock upgrade before T2S!
  14. Sep 24, 2024 at 10:52 AM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    good sir, triple digits were reached going to and from the GFF course..
  15. Sep 24, 2024 at 10:53 AM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    https://www.tundras.com/threads/dirty-seven-club.40397/
    TRDFerguson likes this.
  16. Sep 24, 2024 at 10:54 AM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    partially accurate. many many exhibits of why not...
    TRDFerguson[QUOTED] likes this.
  17. Sep 24, 2024 at 10:59 AM
    bflooks
    bflooks New Member
    Metrowest MA
    You've got even more searching to do, and I'm sorry for sharing that. Smooth is way to personalized of a descriptor. More firm than stock or do you like the stock ride quality? Rake is probably the easiest part of the discussion, but how you get there is going to be on you to search more about, again.
    Too much to address in detail for the front, but if you like the factory ride, go with a spacer lift up front or upgrade to something adjustable for a different experience. For the rear, you get to search new springs vs RAS vs Bags (with cradles!). If they don't give the desired rake, then consider upgraded shackles. IMO, factory rake (~2.5") becomes much less noticeable the more lift and bigger tire you have. Lots of threads showing lifts/tire sizes and lots of threads on the specific rear solutions for towing.
    Tires... that's 1/2 of this forum all in itself.
  18. Sep 24, 2024 at 11:02 AM
    STravis
    STravis SOB Fabrication Vendor
    Travis
    Ruidoso, NM
    17 TRD Pro CM, 08 Supercharged Single Cab
    I ran 37x12.50's with just a cmc and just barely cut the bottom corner of the fender by the cab mount underneath and had no issues. When I went up to 39x12.50 I had to relocate the body mount and cut 1.5" out of the fender if I remember right.
  19. Sep 24, 2024 at 11:04 AM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Ahem
  20. Sep 24, 2024 at 11:23 AM
    Dave8699
    NJ
    Yes sir, I'm searching everyday, snice its a different monster then my 1st gen. I don't mind a little more firm then stock. As long as I'm not jumping all over the place down the road. As for the rake yes that is easier to slove I could get new leaf pack or RAS. Was looking at the 8112/8100 but have to do a little more searching. Also will be calling Coach builder and see what's his recommendation.
    I have no problem chopping up to make something fit as long as it's worth while.
    BillyB likes this.
  21. Sep 24, 2024 at 11:44 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Look at this guy keeping his receipts...
  22. Sep 24, 2024 at 12:27 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Hey @Dave8699 I can throw together a novel here for recommendations, but I encourage you to give me a buzz when you get a chance. I'll hit you with about 20 questions on how you plan to use the truck, and can make recommendations from there. You can also fire away with questions of your own. The 8112/8100 is a solid and very popular setup, and you can't go wrong there. Happy to help.
    Colton @ Hotshot Offroad
    406-936-0206
    BillyB, Mater, BiggHertz and 3 others like this.
