Trailer hitch pin not long enough
Discussion in 'Towing & Hauling' started by grnwdjsn, Aug 6, 2024.
  1. Aug 6, 2024 at 4:51 AM
    grnwdjsn
    grnwdjsn [OP] New Member
    2023 Tundra Limited TRD Offroad
    Has anyone else had an issue with their hitch receiver being too wide for a standard 3" pin? I have tried 4 different locking hitch pins and none of them will lock because my receiver is about 1/4" too wide. It is some double wall construction. I found a 4" pin at HF but it does not lock? What gives?
  2. Aug 6, 2024 at 6:01 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    Tow rating over 10k lbs so Toyota had to go to heavier hitch so it is thicker wall, but to keep from going to a class V 2.5" hitch its basically a class 4.5 hitch now because class 4 are only rated to 10k. Look for Hitch pins that are for class V (class 5) hitch and you might have better luck. Class V is a 2.5 in receiver so should be plenty long. I don't use locking hitch pins, but I do admit my typical pin just barely allows me to get the retainer clip in it once its inserted.
  3. Aug 6, 2024 at 6:31 AM
    Retired...finally
    I tried to locate a pin like mine but couldn't. It's a bent pin with two holes opposite the bend. One for the standard hair pin clip and another larger hole for a padlock. I purchased keyed alike American padlocks at Ace and lock my trailer coupler, the generator, fishing poles on the back and my hitch pin. I've had this pin for many years and don't remember where I bought it.
    I've always been afraid the locking pins available today aren't high enough quality to prevent them being frozen on the pin or hammered off.
  4. Aug 6, 2024 at 10:16 AM
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    2020 Tundra Limited on 35's
  5. Aug 6, 2024 at 7:49 PM
    Soflo
    Soflo New Member
    Tom
    Miami, FL
    2022 Tundra TRD off road
    What’s wrong with stock?
    teab and Prostar 190 like this.
  6. Aug 6, 2024 at 11:22 PM
    blenton
    blenton New Member
    Kind of... Gen 2 tundras were rated for over 10k towing on specific models. Per Toyota correspondence with a member on another forum, that hitch was also rated above Class IV but not Class V, just like the Gen 3 hitch. That said, they redesigned the entire truck so they may well have built more beef in to the hitch. Interesting to hear that standard 3" hitch pins don't fit.
  7. Aug 7, 2024 at 4:38 AM
    Northbound Train
    Northbound Train Masshole
    Glenn
    Western MA
    Black 2016 SR5 Double Cab 4x4 5.7
    5/8 x 4.5” grade 8 bolt with a nylock nut.
    Long enough, strong enough and can’t be removed without tools.
  8. Aug 7, 2024 at 4:46 AM
  9. Aug 11, 2024 at 6:41 AM
    opfor
    opfor New Member
    2024 Hybrid Limited TRD Off Road
  10. Aug 11, 2024 at 6:53 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    And doesn’t rattle!
    Retired...finally likes this.
  11. Sep 24, 2024 at 6:38 AM
    GAMark
    GAMark New Member
  12. Sep 24, 2024 at 6:54 AM
    teab
    Ty
    Denver
    Its got the strength of chinesium....when a rating isn't listed that means it isn't rated....probably be strong enough till it isn't.
