Low Oil Pressure Reading At Idle
Discussion in 'General Tundra Discussion' started by 2015SR5, Sep 21, 2024.
  1. Sep 21, 2024 at 11:58 AM
    2015SR5
    2015SR5 [OP] New Member
    2015 Black Tundra SR5
    Hello, When my 2015 Tundra is at idle the oil pressure gauge needle sits on L is that normal for these at start up when they are cold? Or do I have some major problems? Thank you
  2. Sep 21, 2024 at 11:59 AM
    AZBoatHauler
    So.Arizona
    Where do you live? Running thicker oil will help bump the pressure.
  3. Sep 21, 2024 at 12:02 PM
    2015SR5
    Currently in Nevada, the truck has been sitting for a couple years I just got it running today, on top of the low oil pressure reading I’m hearing some clanking, could those be the lifters just needing to re-pump themselves?
  4. Sep 21, 2024 at 12:13 PM
    AZBoatHauler
    So.Arizona
    No check engine light? Assuming no light - I’d put some fresh gas in it - get it warm - drive it hard - then dump the oil for 5-30.
  5. Sep 21, 2024 at 12:15 PM
    2015SR5
    No check engine light on atm, when I increase the rpm’s gradually to 2000 that’s when the oil pressure needle will move. But thank you
  6. Sep 23, 2024 at 6:18 AM
    smokint
    smokint New Member
    2017 1794 2002 Tacoma
    Not normal.
    Dipstick level normal? Then change oil/filter
    Still low, could be bad oil pump or sensor
    How many miles?
    2015SR5[QUOTED][OP] likes this.
  7. Sep 23, 2024 at 6:51 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Replace oil is the first thing to do in such situations.
    If the lifters are empty you can't drive it hard. Well, you can, but one time only. There's a procedure how to refill them gently, it takes 30-40 minutes.
    2015SR5[OP] likes this.
  8. Sep 23, 2024 at 6:52 AM
    2015SR5
    Dipstick is showing half a quart overfilled, gonna change the oil then throw a pressure gauge on it, 142k miles.
  9. Sep 23, 2024 at 7:17 AM
    Retired...finally
    Nevada? You'll need to start that truck and get it down to operating temps. It's overheating just sitting there.
  10. Sep 23, 2024 at 7:22 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    snivilous[QUOTED] likes this.
  11. Sep 23, 2024 at 8:02 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Wow totally wrong. I even researched beforehand and thought I found evidence it was shim and bucket.
  12. Sep 23, 2024 at 8:05 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    It can be replaced with aftermarket solid tappets, in performance application.
  13. Sep 23, 2024 at 8:08 AM
    snivilous
    SW UT
    I've just never seen a lifter in a modern Toyota engine, granted that's only a handful I've torn down but all of them were bucket and shim.
  14. Sep 23, 2024 at 8:14 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Yeah, 3UR was designed already outdated ;) No way on Earth any engine makes 1M miles w/o lash adjustment.
  15. Sep 23, 2024 at 8:17 AM
    snivilous
    SW UT
    Wasn't the first million mile Tundra a 4.7 though? And it uses bucket on shim, unless I'm retarded about that too :rofl:
  16. Sep 23, 2024 at 8:24 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Yeah, 2UZ was the first M miles Tundra. My 35 lbs of Toyota 2011 workshop manuals have only 1UR and 3UR. Wikipedia says "bucket tappets" for 2UZ.
  17. Sep 23, 2024 at 8:28 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Oil filter could be just gunked up, change oil and filter and check again?
  18. Sep 23, 2024 at 8:33 AM
    Bergmen
    Bergmen New Member
    Ukiah, California
    On the 5.7, the rocker pivots are hydraulically compensated, no adjustment.
    On the 4.7, shim under bucket requiring camshaft removal to adjust clearances to spec. My 2006 with 4.7 had 225,000 miles on it and never needed adjustment (thankfully).
    Cross section of 5.7 cylinder head:
    smokint, snivilous[QUOTED] and vtl like this.
