Possible to Change "Doors Don't Lock Unless Closed" Functionality?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Aphelion79, Jun 25, 2024.
  1. Jun 25, 2024 at 7:03 PM
    Aphelion79
    Aphelion79 [OP] New Member
    2020 Midnight Black Tundra SR5
    None (yet!)
    Just asking what the subject says... If a door is open and you try to lock the doors, the truck let's out a loud beep but DOESN'T LOCK THE DOORS. You have to wait until the door is closed and manually attempt to lock it again.
    Conversely our 2004 Subaru Forester just double beeps to notify you the car isn't secure but as soon as the door closes it honors your prior intent, locks, and beeps again to let you know you're good. I'd like the Tundra to do the same if possible?
  2. Jun 26, 2024 at 3:02 PM
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    Not sure how to change the setting you mention but my 20 locks with the doors open. If I hit the lock on the key fob with a door open the locks will lock and then the truck will beep once when I shut the door
  3. Jun 26, 2024 at 3:32 PM
    Aphelion79
    None (yet!)
    Do you have push to start?
  4. Jun 26, 2024 at 3:50 PM
    Clemsonman14
    No I do not
  5. Jun 26, 2024 at 3:57 PM
    Aphelion79
    None (yet!)
    Well, it works like I expect it to with the old-school key version. When I try to lock my door with the key fob it just yells at me for about a 5-second straight BEEEEEEEEEEEEEP and doesn't lock the doors... There has to be a way with the keyless version I have.
    Clemsonman14[QUOTED] likes this.
  6. Jun 26, 2024 at 4:05 PM
    JohnWhicker
    JohnWhicker New Member
    Mine does the same and is a 21. On my 13 I can actually lock it with the door open and just close the door after.
  7. Jun 27, 2024 at 7:15 AM
    Aphelion79
    None (yet!)
    Tried looking through the vehicle settings and didn't see anything. Maybe it's possible with a tech stream edit?
  8. Jun 27, 2024 at 8:04 AM
    Bergmen
    Bergmen New Member
    Ukiah, California
    My 2018 locks all doors with the driver side door open, no problem. Locks, unlocks without complaint. I did not try the key but will to see if that works also.
    Edit: Checked with key, works the same. Doors lock and then immediately unlock if tried with the engine running, no beeps.
  9. Jun 27, 2024 at 1:11 PM
    Henry1jg
    Henry1jg 2021 TRD Sport
    MI
    Have you looked up the stuff the carista module can do on YouTube? This may be one of the settings you can adjust on there
  10. Jun 27, 2024 at 4:38 PM
    Aphelion79
    None (yet!)
    Sounds like you need a key to start it? I have push to start... Gotta be something with the keyless
  11. Jun 27, 2024 at 4:39 PM
    Aphelion79
    None (yet!)
    No I'll Google! Thanks
    Henry1jg[QUOTED] likes this.
  12. Jun 27, 2024 at 7:36 PM
    Bergmen
    Bergmen New Member
    Ukiah, California
    Yes, I do need a key to start it. That may be the difference.
  13. Jun 27, 2024 at 8:04 PM
    JohnWhicker
    I have TIS but no time to look into this. Other bigger project in ten pipeline. When I find the time I will do it an report back
  14. Jun 27, 2024 at 8:09 PM
    biebs96
    PA
    Maybe you have a bad door lock actuator?
    I noticed mine wouldn’t lock randomly a few months ago, even after repeated attempts.
    After multiple scenarios, I was able to find out one the cab doors did not always lock. This caused the vehicle to stay “unlocked” and not function as it should (turning off interior lights, flashing of security light)
    Hope this helps
  15. Jun 28, 2024 at 9:03 AM
    Aphelion79
    None (yet!)
    It should be in there! Looks like Carista does have an option, see screenshot:
  16. Sep 22, 2024 at 9:06 PM
    Aphelion79
    None (yet!)
    Update
    Got the carista and returned it.
    Didn't ACTUALLY have the option for my truck. (With push button start.)
