Time for a new timing belt?
Discussion in '1st Gen Tundras (2000-2006)' started by Gray06, Sep 21, 2024.
  1. Sep 21, 2024 at 7:36 PM
    Gray06
    Gray06 [OP] New Member
    Gray 2006 Tundra limited
    Timing belt on my new to me 2006 tundra double cab 4.7 pictured below, I bought the truck knowing that it would probably need it and was going to schedule it for a month out or so but I’m guessing this is probably a don’t drive unless you have to scenario?
    Truck has 195k and I think this might be the original.
  2. Sep 21, 2024 at 7:42 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Your instincts are probably correct, that's pretty bad. Not worth the risk driving it if you don't have to IMO.
    Weagle likes this.
  3. Sep 21, 2024 at 8:09 PM
    I would try not to even start it if you can avoid it.
  4. Sep 21, 2024 at 10:03 PM
    gizardlizard
    gizardlizard New Member
    Madison,WI
    2017 TRD pro Tundra
    6” lift, 35 inch tires, chrome delete, ridiculous stereo
    Change the water pump, idlers and tensioner while you’re in there.
    Weagle likes this.
  5. Sep 22, 2024 at 5:44 AM
    What part of the US are you from there? We’ve seen other Tundras here with similar mileage and age that looked a hell of a lot better.
    G_unit3000 likes this.
  6. Sep 22, 2024 at 5:50 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    One crank away from a new engine lol.
    Weagle and G_unit3000 like this.
  7. Sep 22, 2024 at 8:03 AM
    This ^^
    Hey, if you like playing dice with death, go ahead, start it up. Holy shit man. That's one of the worst I've seen.
  8. Sep 22, 2024 at 8:12 AM
    Mr Badwrench
    Mr Badwrench New Member
    That is pretty worn. You should replace that as soon as possible.
    I've seen some pictures of bad ones, that might be the worst.
  9. Sep 22, 2024 at 8:12 AM
    Gray06
    Wisconsin
  10. Sep 22, 2024 at 8:13 AM
    Gray06
    She did 60mi yesterday and 35 the day before and has another 30 to my mechanic so I guess I’ll pray on the truck.
    G_unit3000 and Leo's first like this.
  11. Sep 22, 2024 at 8:19 AM
    Mr Badwrench
    There have been people who have snapped timing belts on the 4.7 without destroying the engine, but those situations are few and far between.
  12. Sep 22, 2024 at 8:21 AM
    Gray06
    Yeah, and I think those were all pre VVT-I 4.7 engines
  13. Sep 22, 2024 at 9:09 AM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    Other options...I have AAA. $100/year. If it were me, I'd have it towed to the shop. That thing might go another few thousand miles, or just break under it's own tension with the truck not even running tomorrow.
    I got AAA when my Tacoma left me stranded on the side of the road for the first time in its life, at around 270,000 miles. $600 tow bill. Of course I haven't personally needed it since then, but I was riding with a friend who needed a 150 mile tow and I saved him $600.
    Out here it's just too common to be a couple hundred miles from home on a regular basis. Tow costs are high. $100 a year is worth it to me, and I'd be making use of it if my belt looked like yours.
    Leo's first likes this.
  14. Sep 22, 2024 at 9:23 AM
    bfunke
    bfunke Tundra Curmudgeon
    I would suggest new OEM only LBJs at same time or shortly thereafter the TB replacement.
  15. Sep 22, 2024 at 1:12 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    ^ all of the above.
    Yikes. That's not a chance I'd take. Does your insurance cover towing?
  16. Sep 23, 2024 at 8:08 AM
    ATBAV8
    ATBAV8 Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
    I would seriously consider towing it. For real.
    Weagle, dbittle and G_unit3000 like this.
  17. Sep 25, 2024 at 6:33 PM
    woodamsc
    woodamsc New Member
    New Hampshire
    2003 Tundra v8 4.7l 4wd sr5
    How do you assess the condition of a timing belt? You say it's the worse you've seen, what's a good one look like and what are the differences? To my untrained eye it looks like...a belt
  18. Sep 25, 2024 at 6:40 PM
    Belt should be smooth and crack-free/wrinkle-free, but not overly shiny. It should have writing intact on it at various points on the belt for Left/Right/cam, and the text should be reasonably legible. If either is untrue, or the belt is frayed at the edges, replace the belt with genuine Aisin brand kit, but don't buy it off fleabay/scAmazon or any other store that can't legitimately validate its supply chain and/or won't be held accountable if you buy a counterfeit part.
    Bad on left. Those cracks are not normal, neither is the sheen. Fresh new belt on right.
  19. Sep 25, 2024 at 6:41 PM
    Forum has been changed recently to reduce picture quality pretty significantly (or I hit a limit, not sure which), so here's a closer pic of good belt.
    G_unit3000 and FrenchToasty like this.
  20. Sep 25, 2024 at 6:42 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    It should have no cracks, not be very shiny (sign of wear) and be somewhat flexible.
    As it ages and wears it goes from a matte finish to shiny and becomes harder/less flexible. Cracks are a giant warning sign.
    G_unit3000, FrenchToasty and shifty` like this.
  21. Sep 25, 2024 at 7:00 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Mitsuboshi is the belt brand provided in the aisin kits.
    But yes, get the whole Aisin kit with water pump, idlers & tensioner.
  22. Sep 25, 2024 at 7:01 PM
    Yup, meant 'kit' not belt twice. Thanks for catching it, edited.
  23. Sep 25, 2024 at 7:12 PM
    TILLY
    Massachusetts
    When I was a Tech many moons ago, the rule of thumb was to change them when they started to crack on the inside between the cogs. Seeing cracks on the outside should be a flashing neon sign that its way overdue.
  24. Sep 25, 2024 at 7:57 PM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    I am not moving my Tundra unless I pull or push it until I get that timing belt replaced.
    I'm not risking another engine start. Previous owner didn't change the belt, no idea if the first owner ever changed it, naturally neither one of them kept a maintenance logbook, and mine has 201,000 miles.
    Once this week of rain is over (thank you God for sending us the rain!) and the ground firms up again, mine is getting rollbacked to a dealership for a belt change.
    I'd play it safe if I were you.
  25. Sep 26, 2024 at 5:06 AM
    woodamsc
    woodamsc New Member
    New Hampshire
    Wow thanks for the pics, yeah I see it now. I thought those cracks were the rubber teeth on the other side
  26. Sep 26, 2024 at 8:06 AM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    I just replaced mine at 100,000 miles. It had no cracks or obvious signs of wear.
    If you can see signs of wear or cracking IMO you are well past the time for replacement. Yours is scary bad
  27. Sep 30, 2024 at 12:12 PM
    Gray06
    shifty` likes this.
