Map lights, and footwear lights fuse?
Discussion in 'General Tundra Discussion' started by F1SH NH, Sep 21, 2024.
  1. Sep 21, 2024 at 12:41 PM
    F1SH NH
    F1SH NH [OP] New Member
    Dave
    Canadian Sandstorm Crewmax
    Anyone know right offhand what fuse these lamps are on? Neither work and I'm getting sick being upside down with a meter! Lol
  2. Sep 21, 2024 at 12:54 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    What year is your truck?
    On my 2014 it is the dome fuse in the underhood fuse box.
    Screenshot_2024-09-21_145556_5c8bb9d798a8517a3cec8a18c59763f91cad733a.pngScreenshot_2024-09-21_145650_63250d7983eba164a7457d12bff74ff9b414d543.png
  3. Sep 21, 2024 at 12:59 PM
    F1SH NH
    Dave
    The truck is a '18. The under hood fuses check out. My dome lights do work.
  4. Sep 21, 2024 at 1:18 PM
    F1SH NH
    Dave
    Here are my in-cab options.
  5. Sep 21, 2024 at 1:49 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    They are all on the same circuit..
    Roof console (Map lights), foot light, and room (Dome) lamp..
    If one works, they all should work..:confused:
    Do the mirror vanity lights work?
    Did you recently install LED bulbs in the map lights?
    Some of them have to be installed with the correct polarity.
    And unless you have after-market, I think there is only one tiny little footwell light on the driver's side.
  6. Sep 21, 2024 at 2:04 PM
    F1SH NH
    Dave
    I just bought truck. The previous owner I think tried to do the led conversion. Think I'm gonna try to reverse polarity on lights that don't work.
    Cargo light Also does not work and was reinstalled (housing) incorrectly. Any idea how in the heck to remove that so I can get back where it belongs? Lol
    Took 4 screws out only to reveal a half installed housing and no clue how to free it up.
  7. Sep 22, 2024 at 9:17 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    The cargo light is removed from the inside.
    You'd need to get back behind the headliner.
    It is a PITA..
    Make sure the cargo light switch is on 'ON or DOOR'.
    As far as if the previous owner jacked with the maps lights, those leads are very small and fragile.
    They are easily bent out of place.
    You can try to look up into them and see if the contacts match up with the bulbs.
    Don't remove the metal reflectors, you'll never get them back in correctly.
    It may be easier to remove the roof console and align your bulb contacts.
    Just remove the 4 torx screws and you can pull the console down.
    https://youtu.be/dGc1EVqZMB8?si=f-EUmAiae1vYXvod
    This may or may not help.
    https://youtu.be/0aLndVMB4aU?si=ZTGqGZuCwPKa5bxc
    NewImprovedRon likes this.
