I totaled my 2024 Sequoia Installing Front aFe Tow Hooks
Discussion in 'Sequoia 3rd Gen (2023+)' started by MySequoia3rdGen, Sep 21, 2024.
  1. Sep 21, 2024 at 7:52 AM
    MySequoia3rdGen
    MySequoia3rdGen [OP] New Member
    Cesar
    2024 Sequoia
    Hi all,
    Crazy, so I carry Kayaks on the roof rack on my new 2-month-old 3rd Gen Sequoia. Since there are no front attachments for the front rope of my Kayaks on the Sequoia, I decided to install aFE front tow hooks instead of attaching the rope to the bumper, which could break the plastic.
    I did the right front without issues. On the left front, however, removing one of the bolts coming out was a bit harder. When I was putting the bolt back in, there was a bit of resistance, but the bolt was screwing with the wrench. I didn't use any power tools, just my right arm. then suddenly I heard a "SNAP" with the bolt halfway in.
    I took it to the dealer, and the tac-welding that had attached the nut to the frame broke.
    be careful INSTALLING FRONT TOW HOOKS - the tac-welding of the nut on the frame could break like it did mine without a proper fix besides replacing the frame or cutting into the frame.
    Unfortunately, my 2 month old 2024 Sequoia is now considered totaled because the cost of frame replacement with labor outweighs it's value.
    Really Toyota? I was able to total my car from a failed tac-weld on a nut frame? Really? nuts
    *** update- I'm considering a class action lawsuit against Toyota as there are multiple people affected and the repair is not existent. Contact me if you want to be part of it.
    dondino, woods and bulldog93 like this.
  2. Sep 21, 2024 at 7:56 AM
    Fobroader
    Fobroader New Member
    Alberta
    2020 Platinum
    Thats insane....I would cut a hole, enough for a wrench, and use a normal nut. Thats crazy, write off for a broken .03 nut
    AZBoatHauler and Black@Blue19 like this.
  3. Sep 21, 2024 at 7:58 AM
    BIGUGLY
    BIGUGLY I the SheepDog. I have the capacity for Violence.
    Paul
    2018 Limited
    Post some pics, if it's a tac welded bolt some welder can fix that right up, unless there going to give you a new tree to take home.
  4. Sep 21, 2024 at 8:11 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
  5. Sep 21, 2024 at 8:14 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    How does a tac welded nut total a sequoia?
    AZBoatHauler and Fobroader like this.
  6. Sep 21, 2024 at 8:18 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Screw it.
    Let insurance total it. Buy it from the insurance.
    Enjoy it forever.
  7. Sep 21, 2024 at 8:23 AM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Post some pictures. That sounds odd. It takes all of 5 minutes to grind that spot on the frame and weld a new nut on.
    Edit: Realized this is on a 3rd gen with the boxed frame. I can see how that would be a lot more difficult. Odd to total it out though.
    MySequoia3rdGen[OP] likes this.
  8. Sep 21, 2024 at 8:36 AM
    MySequoia3rdGen
    Cesar
    2024 Sequoia
    I deleted the video I uploaded as it had my license plate on it.
    300BLK likes this.
  9. Sep 21, 2024 at 8:44 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    That is insane. I know this has already been said, but it definitely bears repeating.
  10. Sep 21, 2024 at 8:53 AM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Beat me to it!! There is no way that I would take a hit like that unless you overplayed that much because of dealer mark up. I would see about buying it back and cut into the frame re weld the piece/s and weld it shut again.
    OR!!!!!! Argue about getting morning money and then don’t look back, that would be enough to leave Toyota behind Good luck.
    UnFrickenBelieveable!!!!!
    Fobroader[QUOTED] likes this.
  11. Sep 21, 2024 at 8:55 AM
    Oh my. Such bullshit. I have seen so many of these tach welded nuts break over the years.
    I have drilled small holes around the bolt in the frame, used the bolt to center the nut around the drill holes and tach weld the nut. Weld splatter will most likely ruin the bolt unless you have a small portion of weld blanket. No big deal.
    Wanna know why everyone pays super high insurance rates? This is why (not directed at you OP...more so Toyota for being big pusscakes).
  12. Sep 21, 2024 at 8:57 AM
    Windsor
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Wait. You agreed let them total your vehicle because of a broken nut that doesn't hold anything? That's kind of stupid.
    Black@Blue19 likes this.
  13. Sep 21, 2024 at 9:01 AM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    front swaybar
  14. Sep 21, 2024 at 9:07 AM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
  15. Sep 21, 2024 at 9:19 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yeah that truck is done. Might as well just send it to the crusher.
    vtl, PermaFrostTRD, Mater and 6 others like this.
  16. Sep 21, 2024 at 9:24 AM
    centex
    centex New Member
    I could see it being costly to swap a frame out but more than the value of the car? Also, like others said, cut, weld, done. No way I’m totaling anything for that.
    Fobroader likes this.
  17. Sep 21, 2024 at 9:46 AM
    pursuit2550
    pursuit2550 New Member
    I see there is a plastic cover on the frame. That can come out and probably, might be hard or impossible, but could find a way to grab the nut.
    joonbug and Fobroader like this.
  18. Sep 21, 2024 at 10:00 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    If you can get it out, you can get one in.
  19. Sep 21, 2024 at 10:02 AM
    pursuit2550
    Sucks for him though since the bolt is still attached to the nut. I broke my front sway bar end link welded nuts. Luckily, There is room to grab it. Still a shit design. those nuts need to be completely welded and not some shit spot weld.
    joonbug[QUOTED] likes this.
  20. Sep 21, 2024 at 10:08 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Agreed. My pic is from the shitty bump stop welded nut. Pain in the ass to fix but it cost less than $62,000. :D
  21. Sep 21, 2024 at 10:10 AM
    pursuit2550
    Now that you say that. I cant imagine a nut costing $62k in a Toyota. I dont think even a nut on the space shuttle cost that much.
  22. Sep 21, 2024 at 10:14 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    There’s only 2 nuts in this world that’s worth $62k to me.
  23. Sep 21, 2024 at 10:16 AM
    AZBoatHauler
    So.Arizona
    2024.
  24. Sep 21, 2024 at 10:17 AM
    AZBoatHauler
    So.Arizona
    This.
    OldGuy03 likes this.
  25. Sep 21, 2024 at 10:18 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    I’m really trying not to be rude here, but the fact you filed a claim is beyond me.
    No visual evidence, but with how loose that bolt sounds I can’t help but wonder if it’s cross threaded.
    blenton, joonbug and Tunrod like this.
  26. Sep 21, 2024 at 10:23 AM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    Yup
  27. Sep 21, 2024 at 10:37 AM
    shawn474
    MoCo, Maryland
    There has to be a way to cut that bolt and fish out the other end from a frame hole in close proximity. I have used nuts that have a stick (bendable metal that is welded to the side of the nut) on the end of it and can fish it through frame holes. In my wife’s 1990 wrangler I used one of the those once you start the three you can put downward pressure while you tighten it and it will seat against the frame. There really is no need to weld it although it makes it easier to install the bolt.
  28. Sep 21, 2024 at 12:15 PM
    Some fingers are longer than others....:eek:
  29. Sep 21, 2024 at 1:23 PM
    Squatting Pigeon
    Holden
    North Texas
    Since there’s a plastic knockout plug right above where the nut is, I’d say this is totally savable
  30. Sep 21, 2024 at 1:38 PM
    Wade23454
    Wade23454 New Member
    Wade
    2025 TRD Pro
    None
    Had this happen on 4 of 6 bolts on my old nissan frontier. I cut the bolts and fished out the broken nuts from the box frame through the access holes on the side of the frame. The box frame might even be open on the front to stick your whole hand inside to hole the nuts in place with a wrench. I would just take it to a dedicated 4x4 shop they do this kinda stuff all the time.
