Ode to FGT; a refresh story
Discussion in '1st Gen Tundras (2000-2006)' started by KNABORES, Jun 20, 2024.
  1. Sep 9, 2024 at 4:34 PM
    #181
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Big boy
    KNABORES[QUOTED][OP] likes this.
  2. Sep 13, 2024 at 3:12 PM
    #182
    KNABORES [OP] Sarcasm incoming
    Tires are on and alignment done. Drives great. Only rubs on my loose passenger front wheel liner. Zip tie should fix that. Spacers are still on at this point. Might keep them.
    IMG_1416.jpg IMG_1409.jpg IMG_1411.jpg IMG_1410.jpg IMG_1415.jpg IMG_1413.jpg
  3. Sep 16, 2024 at 4:08 PM
    #183
    Today’s shenanigans, camper shell roof rack install. Parts finally arrived after 2 shipment attempts to include all the parts.
  4. Sep 16, 2024 at 4:12 PM
    #184
    Bars mocked up
  5. Sep 16, 2024 at 4:34 PM
    #185
    Dunzo. Not too hard of a job. Everything looks better with a nice rack.
  6. Sep 16, 2024 at 4:38 PM
    #186
    Slap some wings on it and go for a flight!
  7. Sep 20, 2024 at 12:44 PM
    #187
    IMG_1471.jpg Truck towed great today. 90 miles, relatively flat. OD off, lots of tongue weight as I filled the 55 gallon fresh water tank.
    Trans temp monitoring showed the trans has ice in its veins.
  8. Sep 20, 2024 at 3:02 PM
    #188
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    I'm impressed. That's a much bigger trailer than I would expect to see one of these trucks tow and I'd have fully expected the trans temp to be ~200°F.
    Weagle likes this.
  9. Sep 20, 2024 at 3:34 PM
    #189
    Much smaller than the trailer I used to tow with this truck
    Weagle likes this.
  10. Sep 20, 2024 at 3:35 PM
    #190
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    o_O
    Pics?
  11. Sep 20, 2024 at 5:18 PM
    #191
    Fobroader, The Black Mamba and Weagle like this.
  12. Sep 20, 2024 at 5:42 PM
    #192
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    How much bigger is it than the other? Hard to tell
  13. Sep 20, 2024 at 6:42 PM
    #193
    New one is 21ft box and 4300#
    Other one in the pic is 28ft box and 7200#
    Weagle and FrenchToasty like this.
  14. Sep 20, 2024 at 7:55 PM
    #194
    Burgmane
    Burgmane New Member
    Apollo Beach, FL
    2005 Limited DC 4WD
    Do you have a trans cooler or any aftermarket stuff to help with temp? Have you done drain and fills on ATF or running factory fluid?
  15. Sep 20, 2024 at 11:51 PM
    #195
    I’ve drained and filled twice since I’ve owned it (every 80k or so it seems). Factory trans cooler and radiator cooler.
  16. Sep 22, 2024 at 2:00 PM
    #196
    Tire update:
    these things are great so far. Towed the camper down to alligator / dove hunt this weekend. 90miles or so of highway and 2 lane road. Truck was rock solid and rode fine for LTs. Definitely not harsh. Off road was great as well. Drove up steep levees and across plowed fields with deep ruts, gravel roads, sand, but no deep mud. Traction was A+. Never needed 4wd and never slipped a tire. Happy with them so far.
  17. Oct 3, 2024 at 8:58 AM
    #197
    Back at the alignment shop. Pulling right, steering wheel slightly off center. Hate having to hold the wheel left to keep it out of the ditch
    BroHon likes this.
  18. Oct 3, 2024 at 10:30 AM
    #198
    Hopefully they don't tell you it's time for new cam bolts.
  19. Oct 3, 2024 at 1:25 PM
    #199
    “Radial tire pull” and some alignment tweaks. Swapped the FR and FL tires.
  20. Oct 4, 2024 at 6:18 PM
    #200
    New alignment feels better so far. Does not pull to the right for sure. May be a little bit “wandery” though. I’ll drive it some more and see how it goes.
    bmf4069, des2mtn and FrenchToasty like this.
  21. Oct 4, 2024 at 6:37 PM
    #201
    Wandery at hwy speed can often be fixed with more caster. How are the rack bushings?
  22. Oct 4, 2024 at 6:47 PM
    #202
    Brand fuckin new poly
  23. Oct 4, 2024 at 7:13 PM
    #203
    Got your alignment numbers?
  24. Oct 4, 2024 at 7:18 PM
    #204
    Didn’t get the new ones. Had the originals above.
  25. Oct 5, 2024 at 1:46 PM
    #205
    Replaced door checks today. Not too bad, a little finicky with getting the new ones in and the check re-installed, but did both sides in less than 45mins.
    Doors hold very solid now. No slamming on my calves when I turn around.
    Requires door card removal. 3 Phillips screws and 2 torx. Lift and unplug.
    Then unbolting the check from the door frame and the door and weaseling it out through the inside door shell. Then you drill out the spot welds and separate the plate from the cup that holds the friction pads.
    Then it’s just a matter of swapping the new pads for the old ones. Be sure to note the orientation while removing the old ones.
    and voila, your door now holds itself at half and full mast when open with authority. I’m going to look the video up again and get the appropriate lube for it and should be good for awhile. Normally the door would slam shut on this incline
    Weagle, DarkMint, BroHon and 3 others like this.
  26. Oct 10, 2024 at 8:47 AM
    #206
    Needed a way to secure the bikes in the bed when we are also towing the camper. Decided to make a removable mounting board with fork mounts for the bikes. Measured and cut the board, fitted the mounts and sanded and finished in bedliner. Used a some large self tapping screws to secure, will swap out for riv-nuts in the future to make it easier to remove.
  27. Oct 10, 2024 at 7:46 PM
    #207
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    I appreciate a custom fixture on a reasonable budget. Reminds me of my fishing pole rack. Well done
  28. Oct 10, 2024 at 7:57 PM
    #208
    about $55
    Fobroader likes this.
  29. Oct 10, 2024 at 8:11 PM
    #209
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    My T100 had something similar to these two thingies on the front of the bed rail. I never knew what they were for. I had planned to remove them eventually. But I sold the T100 6 months later and bought the other tundra.
  30. Oct 15, 2024 at 9:24 AM
    #210
    Today this is a yes. I've lubed between the leafs at the end pads with some PB and it went away. Not sure it's a great log term solution though. What would be the preferred lube for these?
    Weagle likes this.
