2005 Toyota Tundra 4.7 2wd
Discussion in 'New Member Introductions' started by Bertemkay, Sep 18, 2024.
  1. Sep 18, 2024 at 7:54 AM
    Bertemkay
    Bertemkay [OP] New Member
    2005 Toyota Tundra 4.7. 2wd
    Replacement engine did not come with brain box and fuse box. So we had 4 leads from one truck and other had 6 leads. How do we finish the job to get truck rumning
  2. Sep 18, 2024 at 7:58 AM
    Gonna need a lot more info to help you. Where did the donor engine come from? Same cab, year and drivetrain as yours?
  3. Sep 18, 2024 at 8:00 AM
    Bertemkay
    What is the cost of A brain box and fuse box?
  4. Sep 18, 2024 at 8:01 AM
    Depends on the engine / truck configuration
  5. Sep 18, 2024 at 8:16 AM
    Bertemkay
    2door and year 2005 Toyota Tundra 4.7 donor and mine 2005 Toyota Tundra 4 dr 4.7
  6. Sep 18, 2024 at 8:34 AM
    If the two engines are from the same year truck, you should be able to use your wiring harness on the new engine. May have to swap the sensors and what not from your old engine to the new if the harnesses don’t match up.
  7. Sep 18, 2024 at 8:54 AM
    Bertemkay
    My engine has 6 plugins and donor engine has 4 plugins. Donor engine has 4 plugins. It has less accessories. Mine is 6 plug-ins with more accessories. What accessories will I lose if I can’t plug 6 in
  8. Sep 18, 2024 at 9:02 AM
    Bertemkay
    Is there an adaptor to go from 6 to 4 plug-ins to Brain and fuse box
  9. Sep 18, 2024 at 9:25 AM
    If you don’t understand what the plugins do, I would start by figuring that out. The motors are the same between the two. Check the EWD.
  10. Sep 18, 2024 at 2:34 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  11. Sep 19, 2024 at 4:25 AM
    Welcome from NY.
