Help Needed with this!
Discussion in '3rd Gen Tundras (2022+)' started by TundraRyan68, Sep 18, 2024.
  1. Sep 18, 2024 at 3:19 PM
    TundraRyan68
    TundraRyan68 [OP] New Member
    Hello. I ended up pruchasing a TRD pro grille for my 2022 tundra. Have a good idea how to remove the old grille and install this one but wiring is my kryptonite lol. Can never figure it out. This grille comes with the main 18inch light bar and 3 amber lights. The light bar has the 2 positive/negative wires and the amber lights and 3 connections all connected to a white/black/yellow ends. How would i go about wiring this to my fog light switch?
    Reaper1911 likes this.
  2. Sep 18, 2024 at 3:22 PM
    TundraRyan68
    Would prefer wiring this to the fog lights rather than installing its own switch
  3. Sep 18, 2024 at 3:43 PM
    SoCal_Erik
    SoCal_Erik New Member
    2023 SR5 Sport 4x4
    Lots of videos on YouTube. Shouldn’t be hard to find.
  4. Sep 18, 2024 at 3:44 PM
    TundraRyan68
    Seen lots of videos but not any that show how to wire this setup. Hence why i posted in here
  5. Sep 18, 2024 at 5:05 PM
    Savagesawyer
    Savagesawyer New Member
    Beaverton, OR
  6. Sep 18, 2024 at 5:17 PM
    TundraRyan68
    Thanks for this! Really appreciate it. Do i need any connections for the markers into the fuse box?
    SoCal_Erik likes this.
  7. Sep 18, 2024 at 5:21 PM
    TundraRyan68
    Nevermind. Had to google what an add-a-fuse was. I will definitely go with this setup. Thanks again!
    Savagesawyer likes this.
  8. Sep 18, 2024 at 6:39 PM
    Savagesawyer
    Beaverton, OR
    No problem!
  9. Sep 21, 2024 at 7:00 PM
    TundraRyan68
    Ok got the new grille in and used an add-a-fuse for the lights. Seemed to be working fine until I started the truck and all my collison warning lights came on and the check engine light. Anyone know what I did wrong? Everything I disconnected during the grille install was reconnected
  10. Sep 21, 2024 at 7:13 PM
    Savagesawyer
    Beaverton, OR
    you used this space?
  11. Sep 21, 2024 at 7:25 PM
    TundraRyan68
    I tested that spot with a test light and it had constant power with the keys off. Found a video that said it should be tied into the ING fuse on the driver side panel. Disconnected it, disconnected the battery and it has cleared everything. Not sure what happened
  12. Sep 22, 2024 at 8:24 PM
    TundraRyan68
    Maybe there was an issue with my test light. Is this the space everyone uses for their grille lights?
  13. Sep 22, 2024 at 9:19 PM
    Savagesawyer
    Beaverton, OR
    Yah, and it’s recommended by all companies that sell kits and wiring harnesses.
  14. Sep 27, 2024 at 5:43 PM
    TundraRyan68
    Thanks again for your help. That was definitely the right location
