AVS Westcott install tips
Discussion in 'Suspension' started by NCyota, Sep 18, 2024.
  1. Sep 18, 2024 at 4:49 PM
    NCyota
    NCyota [OP] New Member
    I recently installed my Westcott Desgins kit on my 22’ Platinum with AVS. One of the main hurtles I had to overcome was the bolt out of the top of the strut with a Wire that runs through it. Breaking it loose with a wrench did not work, it would spin the whole strut inside. I determined I needed an impact, so I took an old 19mm (12 point) socket I had laying around and cut a slot in the side to accommodate the wire. It worked perfectly. Hope this helps someone out , I spent A WHILE trying to get it off. I’ll attach a photo below.
    Tundrastruck91 likes this.
  2. Sep 19, 2024 at 6:44 AM
    crikeymike
    crikeymike ExitOffroad.com
    Jacksonville Beach, FL
    Do you have a photo of the top stud where the wire goes on? There has to be a way to hold the strut shaft while loosening the nut.
    NCyota[OP] likes this.
  3. Sep 19, 2024 at 7:00 AM
    NCyota
    The shaft is spinning inside of a plastic boot. Both at this point are inside of your partially compressed coil. I even attempted to squeeze the plastic boot to hold the strut shaft, unsuccessfully.
