2022+ anyone stuffed a ~35 in the spare tire holder?
Discussion in '3rd Gen Tundras (2022+)' started by randomquickness, Jan 20, 2022.
  1. Jan 20, 2022 at 1:12 PM
    randomquickness
    randomquickness [OP] New Member
    Curious if my 315/70/17 will fit in there since I'm planning to do a rotatable spare.
    DW707 likes this.
  2. Jan 20, 2022 at 1:51 PM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    following
  3. Jan 20, 2022 at 3:54 PM
    jgoliath
    jgoliath Northeast Rust Fighter
    2022 Tundra, SR5 Offroad, Lunar Rock
    I should have my 34s on Saturday and I will for sure be trying to stuff it under there.
    DW707 likes this.
  4. Feb 6, 2022 at 9:03 PM
    DW707
    DW707 2007 Tundra Driver / Cool dude
    07 Silver Sky DC
    07 Tundra DC. BDS 4.5 inch lift. Icon alloy Rebound 17" rims. 315/70 R17 Sony AX7000.
  5. Feb 7, 2022 at 11:33 PM
    sensei
    sensei master and teacher of nothing
    trd boosted, trd bbk, fox stage 4, corsa, amp, jl/kenwood
    cool, yeah report back please and thanks.
  6. Feb 8, 2022 at 3:59 AM
    jgoliath
  7. Feb 8, 2022 at 12:24 PM
    ThePolak
    ThePolak 2022 Platinum hunt/tow/haul/family ride on order!
    The Land of the Cobra Chicken
  8. Feb 8, 2022 at 4:27 PM
    mass-hole
    mass-hole New Member
    On the Lexus GX/4Runners, people will deflate and ratchet strap the tires to get them into place. Of course you need to carry a compressor with you at all times.
  9. Feb 8, 2022 at 5:04 PM
    KroppDuster
    Here. There. Everywhere.
    Bilstein 5100s
    That's not a terrible idea. However, if you ratchet strap it I can see it "bulging", making the tire wider, and it reducing the departure angle. Am I crazy?
  10. Feb 9, 2022 at 11:10 AM
    sensei
    thanks. i need to go look at the spare size under my platinum. since platinum comes with 20" wheels not sure if the spare is the same. but if the spare is a 20" then i'm looking at 285/60/20 on all corners and the spare. sees like i should be able to get the spare under there without any cutting, etc. thanks.
  11. Apr 4, 2022 at 3:16 PM
    nickjaynes
    nickjaynes New Member
    2022 Tundra SR5
    OK guys I was able to get a 315/70R17 into the spare area. I deflated to 15 PSI (I have onboard air). Not sure if that was necessary, but I did it anyhow. And it fits!
  12. Apr 5, 2022 at 9:09 AM
    Tundra'25
    Tundra'25 Well-Known Member
    Wincent
    Southern California
    Oh sweet!
  13. Apr 5, 2022 at 9:55 AM
    ToyoTundra89
    ToyoTundra89 Member
    Seattle, WA
    2022 Tundra SR5 TRD OR CM 6.5
    Nice set up! I was curious how it looked under there with a near 35" tire. I'm running 35x12.5, but ill be stuffing a 295/70r18 on the steel spare under there. Thanks for posting pictures! Ideally i wanted a full 35, but it won't fit on the 7inch wide steel spare. Should be close enough diameter wise to get me to a tire shop worst case scenario. White letters out look nice! The rules are you must be over 50 years old to run white letter out though lol
    VCheng and Keon like this.
  14. Apr 6, 2022 at 1:58 PM
    nickjaynes
    2022 Tundra SR5
    I will caution that the 315/70R17 on a 0 offset wheel rubs at full lock. The factory wheel offset is 60. So, 0 offset is 2.3 inches further out than stock. Having installed 0 offset, I recommend 35 offset.
  15. Apr 6, 2022 at 3:07 PM
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    I must say I’m digging the white lettering on the tires :thumbsup:
    …about your rubbing situation though I am guessing you don’t have a level/lift?
    Plan to get one?
    There are also a couple of folks running 0 offset but I can’t recall if it’s with 12”+ width as you have, no level/lift and their rubbing situation.
    Truck looks good.
  16. Apr 6, 2022 at 3:24 PM
    wayoflife
    wayoflife Exploring Cascadia and beyond
    Seattle-ish, WA, USA
    '22 1794 6.5' TRD Offroad Blueprint/Cream
    Westcott 3/1 Method 705 18x9 18mm Maxxis RAZR 295/70R18
    53 year old, running white letters out on my white FJ Cruiser, can confirm :)
  17. Apr 8, 2022 at 9:27 AM
    nickjaynes
    2022 Tundra SR5
    I actually do have a lift kit. It's the Westcott Designs kit, which is 3" lift in front, 1" in rear.
    However, I refuse to 'level' it, because I use my truck as a truck and I don't want it to squat. So, I left 1" out of the front. Making it a 2" lift in front, 1" lift in rear. Still rubs.
    I ordered the 35 offset wheels and will be moving these 0 offsets to my FJ Cruiser.
    bigjuice[QUOTED] likes this.
  18. Oct 26, 2022 at 6:08 AM
    mass-hole
    Would anything hold the tire in place besides the chain?
  19. Oct 26, 2022 at 6:15 AM
    mass-hole
    It just looks like a shackle receiver mount.
  20. Oct 26, 2022 at 6:17 AM
    joeboo
    joeboo New Member
    2022 Crew Max TRD
    That makes a little more sense. I did google "hitch bumper" and found something I could use when backing up this boat into a short parking stall.
  21. Oct 26, 2022 at 8:23 AM
    mass-hole
    The bed?
    AGTAB likes this.
  22. Oct 26, 2022 at 9:06 AM
    gr8fasushi
    gr8fasushi 22 Tundra Limited TRD Off Road
    cut her. I plan to do the same to fit my 35's under my bed
  23. Oct 26, 2022 at 9:21 AM
    mass-hole
    I bet if you deflated and used a strap to pull the tire back toward the hitch you could make it work. Fitting the 285/70 under my GX required I go below 15 psi so that the strap could compress the tire enough.
    I totally get not wanting to spend a ridiculous amount of money on a tire carrier though. I didnt either. Im honestly not sure why they cost that much when I can get an 1UP aluminum bike rack for like 1/3 the cost.
  24. Oct 26, 2022 at 9:58 AM
    bigblue14
    bigblue14 New Member
    Craig
    2022 1794 Advanced Package
    TRD lift and AFE airbag arms, 285/65 Cooper AT3s
    285/75/18 under mine right now
  25. Oct 26, 2022 at 10:10 AM
    mass-hole
    No more than if you are wheeling and running at 12 psi with 2000 lbs sitting on the tire. The strap barely squishes the tire. Just enough to buy you the 1/4" or whatever that you need to squeeze it in.
  26. Oct 26, 2022 at 11:13 AM
    KroppDuster
    Bilstein 5100s
    I've got a fully inflated 295/70/18 Cooper M/T tire under there right now. Been there since I upgraded tires about 6 months ago. Never been an issue.
  27. Apr 16, 2024 at 11:12 AM
    randomquickness
    hey y'all, been off the boards for a while. I did end up mounting mine and it did NOT sit flush without some modification. This is what I did:
    https://youtu.be/nSqWRqyZbQo
    tundznoff likes this.
  28. Sep 18, 2024 at 3:44 PM
    machd08
    machd08 New Member
    CLARENCE
    Sumter, South Carolina
    2025 Land Cruiser/Land Cruiser
    Your tire size is 34.4", I just tried to get a 295/65/20 35.1" in there and would fit between the pan bar and hitch, unless I am doing something wrong.
