Dash lights not working
Discussion in '1st Gen Tundras (2000-2006)' started by 02toy, Sep 17, 2024.
  1. Sep 17, 2024 at 10:16 PM
    02toy
    02toy [OP] New Member
    Billy
    2002 Toyota Tundra 4.7
    Hello, I have a 2002 Toyota tundra 4.7. The other day I changed out radio and now no dash lights. I’ve checked all fuses and there good. Could it be the dimmer switch? How do I test for power in the instrument cost? Any help would be greatly appreciated
  2. Sep 18, 2024 at 4:56 AM
    Easy suggestion any time you're dealing with an issue. Remove the suspect.
    Do the dash lights return if you unplug the radio, then turn the car on? (be sure to re-plug the harness that goes into the back of the dash bezel).
    Alternate take: Disconnect only the wire you believe to be the dimmer wire, and see if dash lights return.
