  1. Sep 16, 2024 at 4:23 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    woods, BeauDacious, 713Tundra and 3 others like this.
  2. Sep 16, 2024 at 5:18 AM
    Bergy24
    Bergy24 New Member
    I've seen that some people had issues when installing these. Didn't work correctly and then when they installed their oem part, it still didn't work. Messed something up when they installed the new part. Did you have any issues at all?
  3. Sep 16, 2024 at 6:16 AM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Nice! Looks awesome. I want to add this to mine. Let us know how you like it.
  4. Sep 16, 2024 at 7:19 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    So far, so good :thumbsup:
    The depth of the drawers is a little shallow, so you'll want to calculate what you're going to be putting in there, etc... I knew this going in, so I'm fine.
    Quality is very good; everything operates smooth and as you'd except.
    The one thing I don't care for is the 'dividers'; they just don't seem to click into place real well, but right now I'm not using them anyhow.
    The boxes they give you are stout.
    PS>>> The instructions have you remove you OE bed tie downs. I'm not sure if this is really necessary (unless the turnbuckles are too small for the diameter of the OE tie down)... I didn't check that, but maybe that's the reason. Anyhow, I ended up removing mine and swapping them w/the ones from the system (cuz I didn't want to get through the install and then find out I had to pull it back out again). Just sucks removing the OE ones once you've sprayed a bedliner in cuz that shit's a mess to cut out and around (x acto knife if the key)...
  5. Sep 16, 2024 at 7:44 AM
    FireFinder44
    FireFinder44 New Member
    Albany, OR
    2019 Super White Tundra TRD Pro
    Mostly stock TRD Pro
    @pkeawe809
    It was on the truck when I bought it. OEM Terminal Cover
    pkeawe809[QUOTED] and bulldog93 like this.
  6. Sep 16, 2024 at 7:57 AM
    FireFinder44
    Albany, OR
    Took some pictures around dusk to see how everything looked, backed the truck out to the end of the driveway before the slope to the street altered where the beams hit the garage door. Many thanks to @memario1214 (whom I assume is the guy who I've been in communication with regarding the light bar purchase and install).
    OEM TRD Pro LED Low Beam only
    OEM TRD Pro LED Low Beam with Rigid LED fog lights
    OEM TRD Pro LED Low Beam with Rigid LED fog lights and Diode Dynamics Stage Series 42in LED light bar. Outboard amber wide lenses, inboard white driving lenses.
    OEM TRD Pro LED High Beam and Diode Dynamics Stage Series 42in LED light bar.
    Diode Dynamics Stage Series 42in LED light bar only.
  7. Sep 16, 2024 at 7:58 AM
    Xcumminsguy
    Xcumminsguy New Member
    NY
    2021 Tundra TRD Pro Crew Max
    Stock, with a few cosmetic mods.
    My truck came with these as well. I don’t know if I would have spent the 1500.00+, but I do like them, especially with no under seat storage in the cab like I had with my old Dodge. Plenty sturdy and seem to be capable of holding a fair amount of weight as well. You’ve got to reach in a bit to access items in the front of the drawers, but I believe they addressed that with the latest system generation. Bed depth is reduced quite a bit, which has got me searching for a swing out spare tire carrier. My oem sized tire/rim just fits beneath the tonneau. I don’t care to store the spare beneath the bed.
  8. Sep 16, 2024 at 10:20 AM
    Gainer
    Gainer New Member
    Columbus, OH
    2018 SR w/8' Bed
    Leveling kit, TRD wheels, remote start, Hellwig helper springs, TRD Rear sway bar. TRD Rear shocks, Dirty Deed 10" exhaust, S&B Cold Air intake
    Installed new rear shocks and 1" lift blocks. My 3" extension made me think I stripped one of the U-Bolts when I was torquing it to 100 ft/lbs.
    I was happy and mad at the same time... Glad the bolt didn't strip, mad that the extension was ruined.
    Now the Tundra doesn't look like it has a case of the Carolina Squat. The topper and 47 Gallons of fuel made my leveling kit not so level.
    I have a set of assembled 6112's in route from Hotshot Offroad that should be here Thursday.
  9. Sep 16, 2024 at 10:49 AM
    Sleeper16plat
    Sleeper16plat New Member
    Near Vancouver
    2016 Silver Platinum
    TRD Rear Sway Bar Bilstein 6112/5160 Pop Lock, Kenwood MX 1057 XR, Pioneer amp/speakers/subs, Tech12Volt dual sub box
    Pulled our boat out of the lake and towed it home .
  10. Sep 16, 2024 at 2:42 PM
    broketundraowner
    broketundraowner Double Cab Trouble
    Indiana
    6" Pro-Comp Lift, 35" x 20 Nittos, 20x10 Fuel wheels, Go Rhino Bed Bars
    Replaced the rear shocks! I have had a horrible squeak noise coming from the rear over any size bump for the past few months and it was driving me crazy! I figured out it was the right rear shock as it had oil coming out of the shaft and when I removed the mounting bolt the noise was gone. The truck had a 6" Pro Comp lift on it when I purchased it with 28,000 miles and it only now has 33,000...so not sure at what milage the original owner had the lift put on. After removing the bad shock, it not only was leaking oil but it would not move at all! The piston inside must be seized or broken and that is why it was making a terrible noise over any bump. Obviously not impressed with the quality of Pro Comp shocks so I bought some Rough Country N3 shocks and they were easy to install, noise it gone, and ride quality is awesome! IMG_0311.jpg IMG_0312.jpg IMG_0313.jpg IMG_0308.jpg
  11. Sep 16, 2024 at 3:25 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    None.
    You just have to make sure you buy the right one.
    I always remove the key when unplugging and installing stuff anyways, just as a safe measure.
  12. Sep 16, 2024 at 3:59 PM
    Rabidllamas
    Rabidllamas New Member
    Phil
    WA
    2019 Cement Crewmax TRD OffRoad
    My build- https://www.tundras.com/threads/rabbidllamas-old-man-build.80802/
    Just as a FYI, I am at 19 months since installing and they are working great.
    woods, Bergy24, BR73 and 2 others like this.
  13. Sep 16, 2024 at 4:08 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    What’s the height from the top of the bed rail cap to the top of the Decked?
  14. Sep 16, 2024 at 4:52 PM
    Tripleconpanna
    I'll get that for you later this evening...
  15. Sep 16, 2024 at 8:33 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Great to hear!
  16. Sep 16, 2024 at 8:35 PM
    Tripleconpanna
    Ok, looks to be just a click/notch/hash over 10" :thumbsup:
  17. Sep 16, 2024 at 9:11 PM
    RainMan_PNW
    Casey
    Clark County, WA
    :monocle:
  18. Sep 17, 2024 at 3:19 AM
    Lassie
    Lassie New Member
    HKM
    TAMPA, FL
    This Deck system is water tight? Thanks!
  19. Sep 17, 2024 at 3:22 AM
    Lassie
    Lassie New Member
    HKM
    TAMPA, FL
    Is there a way to make green Cruise Control indicator light brighter? My previous gen 2 and current gen 2.5, both lights are so dim. I can't see during the day if the light is on or off.
  20. Sep 17, 2024 at 3:58 AM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    You can make sure your cluster lights are turned all the way up, but since it's part of the main display I doubt there's any way to make just that light brighter.
    bulldog93 and RobertD like this.
  21. Sep 17, 2024 at 6:27 AM
    Tripleconpanna
    According to decked, the drawers are.... :notsure:
    The system has 2 gaskets running along the center vert (which is the support channel that sits between the 2 drawers) and the drawers have gaskets that sit on the top of the lip of the drawer 'face' (where the handle is)...
    They've been in for a couple of days, and we've had no rain yet... So, I can't confirm at this point. I do live in the PNW, so once the fall hits I'll be able to advise.
    I also have an ArmourFlex tonneau over the system, so that will provide some deflection as well.
    Outside of the drawer supports on the left and right (if you look under the deck w/o the drawers installed you'll see the center and outside support structures) will definitely NOT be water proof, particularly along the sides of the bed and at the bulkhead.
    Lassie[QUOTED] and bulldog93 like this.
  22. Sep 17, 2024 at 9:00 AM
    ETXGuy1836
    ETXGuy1836 New Member
    2021 Gray Tundra SR5
    How do you like that Dasaita head unit? I've been looking at an upgrade for the stock unit.
    ZPhilip, BR73[QUOTED] and koditten like this.
  23. Sep 17, 2024 at 9:21 AM
    Sleeper16plat
    Near Vancouver
    :popcorn:
    BR73 likes this.
  24. Sep 17, 2024 at 9:35 AM
    koditten
    Kirk
    Midland of the Mitten
    I think any aftermarket head unit will be an upgrade. My JBL premium is premium crap!
  25. Sep 17, 2024 at 9:43 AM
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    2020 Tundra Limited on 35's
    Hit a mileage milestone yesterday as I pulled into my driveway.
    EDIT:
    The pic is sized to where you can't really see the dash. LOL
  26. Sep 17, 2024 at 10:01 AM
    rheosibal
    rheosibal New Member
    2.5 Platinum OEM+
    My decked is waterproof (Legacy, V1). I have a shell now, but routinely power wash inside the cap without any water intrusion into the drawers or the ammo boxes
  27. Sep 17, 2024 at 10:27 AM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    With the size of those blocks, I'd def recommend some durobumps !
  28. Sep 17, 2024 at 11:32 AM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    Same.
    CaptRussia253[QUOTED] likes this.
  29. Sep 17, 2024 at 12:52 PM
    jeffw6236
    jeffw6236 New Member
    Jeff
    San Antonio
    2019 MGM CrewMax 4x4
    We’ve got a 2017 4Runner on its 3rd battery and am on my 2nd battery in the Tundra. It’s about 3 yrs old so it has reached old age. Pure dumb luck that all of these crapped out in my driveway. So got a little insurance.
  30. Sep 17, 2024 at 1:05 PM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles +2 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI High flying steering wheel TRD shifter knob LED lights inside/outside Morimoto 3rd brake light
    I like it but there are some things to look for on the install and use.
    1.There are 2 different wire harnesses but only one has the correct plugs depending on the year model of your truck.Mine is a 2020 SR5 . Several YouTube videos out there to help
    2.Connect the Dasaita harness to the OEM harness first then to the head unit
    3.Make sure the canbus is connected to the harness you are using
    4.If you plan on using any of the apps go ahead and plug in the sim card cable with holder for a SIM card
    5.Plug in the external mic and find a location to your liking to place it
    6.After installation and you start setting up the unit make sure to raise the volumes in the factory settings for the mic and radio
    7.Make sure to use US2 for the geographic location.My radio wouldn't work on US1in factory settings
    8.I located the GPS antenna and 4G antenna under the dash and it works fine
    The unit looks OEM and it takes a little time to get things figured out but it's worth it so far PXL_20240901_013547856.jpg
