Toyota Tundra starts and dies
Discussion in '2nd Gen Tundras (2007-2013)' started by Marius Cotori, Sep 15, 2024.
  1. Sep 15, 2024 at 9:36 AM
    Marius Cotori
    Marius Cotori [OP] New Member
    Hi!
    I have read a bunch of threads, but didn’t seem to find an exact one, codes related.
    Anyways, my 2012 Toyota Tundra 4.6, gave up at a stop sign. It starts, idles rough for about 1-2, maybe 3 seconds and dies. I can get a rough rev too, but after releasing acceleration, I can’t give it a second one (it stalls). I am reading codes P0102, P0113, P0123, and P2135. Does anybody know an issue that would cause MAF and Throttle position sensor codes together? I tried running it on my brother’s 2014 Tundra 5.7 MAF, didn’t fix the issue.
    I’m assuming the throttle body gave up? is the sensor replaceable?
    Again, at start up it sounds great, as soon as it drops to idle, it falls under 500rpm, sounds weird and dies.
    I also believe it entered limp mode, bunch of lights incuding 4-hi.
    Please if you have any advice before I bring it to the dealer
    Thank you!
  2. Sep 16, 2024 at 1:20 PM
    Orions Dad
    Orions Dad New Member
    2007 Tundra 4.7L
    Check the crank sensor
  3. Sep 16, 2024 at 1:27 PM
    250000yota
    250000yota New Member
    Russ
    Berthoud, CO
    White 2015 SR5 Crewmax
    S&B intake, Dirty Deeds 8", Airlift airbags with Daystar contact cups, LED's everywhere including Diode Dynamics stealth front LED bar, Baja Design Squadron II's on CBI ditch light brackets, completed Diode Dynamics interior LED's. Full RCI skids with cat guards and sliders, Transfer flow 46 gallon tank. Radflo 2.5 IFP coilovers, Coachbuilder shackles, TRD rear sway bar. 295/70R18 Nitto RG's. Dobinson snorkel, softopper.
    Check the ETCS fuse, and also check for cracks, breaks, or holes in the intake tube between the throttle body and the mass air flow sensor.
    tyr0981 likes this.
  4. Sep 16, 2024 at 2:33 PM
    tyr0981
    tyr0981 New Member
    07 TRD Tundra 5.7
    Head unit, sub's , components, front / back camera's, too many lights to mention, dual battery, winch / bumper, TRS projector headlights, roof nest hard-shell, integrated backup spot lights, vault, all aluminum radiator / water pump, tailgate storage, plenty of dents and scratches
    Took the words out of my hand!
