  1. Sep 15, 2024 at 9:40 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Installed my Decked system last night in the Pro.... Needed a bit of organization in my life. Yes, you lose some bed depth, but I also gain the ability to reach over the entire length of the bed (easily) and grab anything w/o having to climb up on the sliders, etc....
  2. Sep 15, 2024 at 11:28 PM
    pkeawe809
    pkeawe809 New Member
    PK
    Westside, Oahu
    2018 Super White TRD 4x4 CrewMax
    ~Chrome Delete interior AJT/Tuff skins ~Driver side Grab handle OEM ~Revesol Leather Steering Wheel ~Front Console upgraded to Limited Leather Trim ~Switched Center Instrument panel from silver to black ~Switched black molding trim pieces to Wood grain ~Wood grain Shift Knob ~LED interior lights- meso customs ~Husky X-act Front Driver and Passenger Floor-mats ~Clazzio Seat covers ~Pedal Commander ~Front Windshield heat protection clear film ~VLEDS Footwell LED light kit-driver and passenger sides ~ESP Under Rear Seat storage bins ~4- Door Speakers- JL C1-650 component speakers ~Front Dash Hertz Speakers ~Zapco ST-4X DSP III 100Watt Component Speaker Amp ~Zapco ST-500XM II 500Watt Subwoofer Bass Amp ~1-Rear 10” Subwoofer and Box enclosure ~Sail panel speakers-Hertz tweeters ~Noico 80 mil Sound deadener on all 4 door panels ~Morimoto Headlights-amber DRL ~Diode Dynamics SS3 Pro Foglights ~OEM Tail lights Hot Tails” option A upgrade by Hot Shot Offroad ~Anytime Front and Rear Camera-Trail Grid Pro ~Precision LED lights-rear bed light, lic plate light ~Retrax Pro XR Bed cover ~Auto Rear tailgate lock OEM ~Repaired rust spot and Repainted Roof 7/22 ~De-badged and removed Stickers ~TRD Dual Exhaust w/black chrome tips ~Valhalla Cat Security Shields-Black powder coated ~Black powder coated TRD skid plate ~Red powder coated front Tow Hooks ~Coachbuilder +2 Shackles 1.25” lift ~TRD Pro Grille ~TRD Pro Skid plate ~TRD front/rear Sway Bars ~Bilstein 6112 front shocks ~Bilstein 5160 rear w/resi ~Nitto Ridge Grapplers 35x12.50R17 ~Icon Alloys Rebound Rims 17x8.5 ~Window Tint
    Can I ask where you got the positive terminal cap that is on the SDHQ terminal covering? Just installed my SDHQ terminals this past week and don't like the exposed connection on the positive side. Light looks good by the way!
  3. Sep 16, 2024 at 3:46 AM
    Bdiddy
    Bdiddy New Member
    Where did you get this part? Can you provide the link? Thanks!
    Toyotoholic[QUOTED] likes this.
  4. Sep 16, 2024 at 4:23 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    woods, BeauDacious, 713Tundra and 3 others like this.
  5. Sep 16, 2024 at 5:18 AM
    Bergy24
    Bergy24 New Member
    I've seen that some people had issues when installing these. Didn't work correctly and then when they installed their oem part, it still didn't work. Messed something up when they installed the new part. Did you have any issues at all?
  6. Sep 16, 2024 at 6:16 AM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Nice! Looks awesome. I want to add this to mine. Let us know how you like it.
  7. Sep 16, 2024 at 7:19 AM
    Tripleconpanna
    So far, so good :thumbsup:
    The depth of the drawers is a little shallow, so you'll want to calculate what you're going to be putting in there, etc... I knew this going in, so I'm fine.
    Quality is very good; everything operates smooth and as you'd except.
    The one thing I don't care for is the 'dividers'; they just don't seem to click into place real well, but right now I'm not using them anyhow.
    The boxes they give you are stout.
    PS>>> The instructions have you remove you OE bed tie downs. I'm not sure if this is really necessary (unless the turnbuckles are too small for the diameter of the OE tie down)... I didn't check that, but maybe that's the reason. Anyhow, I ended up removing mine and swapping them w/the ones from the system (cuz I didn't want to get through the install and then find out I had to pull it back out again). Just sucks removing the OE ones once you've sprayed a bedliner in cuz that shit's a mess to cut out and around (x acto knife if the key)...
  8. Sep 16, 2024 at 7:44 AM
    FireFinder44
    FireFinder44 New Member
    Albany, OR
    2019 Super White Tundra TRD Pro
    Mostly stock TRD Pro
    @pkeawe809
    It was on the truck when I bought it. OEM Terminal Cover
    pkeawe809[QUOTED] and bulldog93 like this.
  9. Sep 16, 2024 at 7:57 AM
    FireFinder44
    Albany, OR
    Took some pictures around dusk to see how everything looked, backed the truck out to the end of the driveway before the slope to the street altered where the beams hit the garage door. Many thanks to @memario1214 (whom I assume is the guy who I've been in communication with regarding the light bar purchase and install).
    OEM TRD Pro LED Low Beam only
    OEM TRD Pro LED Low Beam with Rigid LED fog lights
    OEM TRD Pro LED Low Beam with Rigid LED fog lights and Diode Dynamics Stage Series 42in LED light bar. Outboard amber wide lenses, inboard white driving lenses.
    OEM TRD Pro LED High Beam and Diode Dynamics Stage Series 42in LED light bar.
    Diode Dynamics Stage Series 42in LED light bar only.
  10. Sep 16, 2024 at 7:58 AM
    Xcumminsguy
    Xcumminsguy New Member
    NY
    2021 Tundra TRD Pro Crew Max
    Stock, with a few cosmetic mods.
    My truck came with these as well. I don’t know if I would have spent the 1500.00+, but I do like them, especially with no under seat storage in the cab like I had with my old Dodge. Plenty sturdy and seem to be capable of holding a fair amount of weight as well. You’ve got to reach in a bit to access items in the front of the drawers, but I believe they addressed that with the latest system generation. Bed depth is reduced quite a bit, which has got me searching for a swing out spare tire carrier. My oem sized tire/rim just fits beneath the tonneau. I don’t care to store the spare beneath the bed.
  11. Sep 16, 2024 at 10:20 AM
    Gainer
    Gainer New Member
    Columbus, OH
    2018 SR w/8' Bed
    Leveling kit, TRD wheels, remote start, Hellwig helper springs, TRD Rear sway bar. TRD Rear shocks, Dirty Deed 10" exhaust, S&B Cold Air intake
    Installed new rear shocks and 1" lift blocks. My 3" extension made me think I stripped one of the U-Bolts when I was torquing it to 100 ft/lbs.
    I was happy and mad at the same time... Glad the bolt didn't strip, mad that the extension was ruined.
    Now the Tundra doesn't look like it has a case of the Carolina Squat. The topper and 47 Gallons of fuel made my leveling kit not so level.
    I have a set of assembled 6112's in route from Hotshot Offroad that should be here Thursday.
  12. Sep 16, 2024 at 10:49 AM
    Sleeper16plat
    Sleeper16plat New Member
    Near Vancouver
    2016 Silver Platinum
    TRD Rear Sway Bar Bilstein 6112/5160 Pop Lock, Kenwood MX 1057 XR, Pioneer amp/speakers/subs, Tech12Volt dual sub box
    Pulled our boat out of the lake and towed it home .
  13. Sep 16, 2024 at 2:42 PM
    broketundraowner
    broketundraowner Double Cab Trouble
    Indiana
    6" Pro-Comp Lift, 35" x 20 Nittos, 20x10 Fuel wheels, Go Rhino Bed Bars
    Replaced the rear shocks! I have had a horrible squeak noise coming from the rear over any size bump for the past few months and it was driving me crazy! I figured out it was the right rear shock as it had oil coming out of the shaft and when I removed the mounting bolt the noise was gone. The truck had a 6" Pro Comp lift on it when I purchased it with 28,000 miles and it only now has 33,000...so not sure at what milage the original owner had the lift put on. After removing the bad shock, it not only was leaking oil but it would not move at all! The piston inside must be seized or broken and that is why it was making a terrible noise over any bump. Obviously not impressed with the quality of Pro Comp shocks so I bought some Rough Country N3 shocks and they were easy to install, noise it gone, and ride quality is awesome! IMG_0311.jpg IMG_0312.jpg IMG_0313.jpg IMG_0308.jpg
  14. Sep 16, 2024 at 3:25 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    None.
    You just have to make sure you buy the right one.
    I always remove the key when unplugging and installing stuff anyways, just as a safe measure.
  15. Sep 16, 2024 at 3:59 PM
    Rabidllamas
    Rabidllamas New Member
    Phil
    WA
    2019 Cement Crewmax TRD OffRoad
    My build- https://www.tundras.com/threads/rabbidllamas-old-man-build.80802/
    Just as a FYI, I am at 19 months since installing and they are working great.
    woods, Bergy24, BR73 and 2 others like this.
  16. Sep 16, 2024 at 4:08 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    What’s the height from the top of the bed rail cap to the top of the Decked?
  17. Sep 16, 2024 at 4:52 PM
    Tripleconpanna
    I'll get that for you later this evening...
  18. Sep 16, 2024 at 8:33 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Great to hear!
  19. Sep 16, 2024 at 8:35 PM
    Tripleconpanna
    Ok, looks to be just a click/notch/hash over 10" :thumbsup:
  20. Sep 16, 2024 at 9:11 PM
    RainMan_PNW
    Casey
    Clark County, WA
    :monocle:
  21. Sep 17, 2024 at 3:19 AM
    Lassie
    Lassie New Member
    HKM
    TAMPA, FL
    This Deck system is water tight? Thanks!
  22. Sep 17, 2024 at 3:22 AM
    Lassie
    Lassie New Member
    HKM
    TAMPA, FL
    Is there a way to make green Cruise Control indicator light brighter? My previous gen 2 and current gen 2.5, both lights are so dim. I can't see during the day if the light is on or off.
  23. Sep 17, 2024 at 3:58 AM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    You can make sure your cluster lights are turned all the way up, but since it's part of the main display I doubt there's any way to make just that light brighter.
    bulldog93 and RobertD like this.
  24. Sep 17, 2024 at 6:27 AM
    Tripleconpanna
    According to decked, the drawers are.... :notsure:
    The system has 2 gaskets running along the center vert (which is the support channel that sits between the 2 drawers) and the drawers have gaskets that sit on the top of the lip of the drawer 'face' (where the handle is)...
    They've been in for a couple of days, and we've had no rain yet... So, I can't confirm at this point. I do live in the PNW, so once the fall hits I'll be able to advise.
    I also have an ArmourFlex tonneau over the system, so that will provide some deflection as well.
    Outside of the drawer supports on the left and right (if you look under the deck w/o the drawers installed you'll see the center and outside support structures) will definitely NOT be water proof, particularly along the sides of the bed and at the bulkhead.
    Lassie[QUOTED] and bulldog93 like this.
  25. Sep 17, 2024 at 9:00 AM
    ETXGuy1836
    ETXGuy1836 New Member
    2021 Gray Tundra SR5
    How do you like that Dasaita head unit? I've been looking at an upgrade for the stock unit.
    ZPhilip, BR73[QUOTED] and koditten like this.
  26. Sep 17, 2024 at 9:21 AM
    Sleeper16plat
    Near Vancouver
    :popcorn:
    BR73 likes this.
  27. Sep 17, 2024 at 9:35 AM
    koditten
    Kirk
    Midland of the Mitten
    I think any aftermarket head unit will be an upgrade. My JBL premium is premium crap!
    BR73, TOYOTARIG and bulldog93 like this.
  28. Sep 17, 2024 at 9:43 AM
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    2020 Tundra Limited on 35's
    Hit a mileage milestone yesterday as I pulled into my driveway.
    EDIT:
    The pic is sized to where you can't really see the dash. LOL
  29. Sep 17, 2024 at 10:01 AM
    rheosibal
    rheosibal New Member
    2.5 Platinum OEM+
    My decked is waterproof (Legacy, V1). I have a shell now, but routinely power wash inside the cap without any water intrusion into the drawers or the ammo boxes
  30. Sep 17, 2024 at 10:27 AM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    With the size of those blocks, I'd def recommend some durobumps !
