Park / Neutral Shifter Switch Wiring
Discussion in '2.5 Gen Tundras (2014-2021)' started by brandostundra, Sep 15, 2024.
  1. Sep 15, 2024 at 5:10 PM
    brandostundra
    brandostundra [OP] New Member
    I am still considering running a kill switch on my 2016 Tundra and weighing options.
    I read that an easy location to tap into would be one of the wires on the shifter (park/neutral switch) .
    Where if the hidden on/off switch was activated , and someone went to turn the key , the relay wouldnt get signal to turn on because that wire was interupted (switch) , so no power to the starter because it thinks its not in park or neutral.
    Out of curiosity, I opened the top of my console exposing the shifter, but didnt see any wires coming or going to it. So my question is , is there a small wire harness on or under the shifter somewhere? or is it under the truck on the side of the transmission ? and any idea on wire color?
    2016 Tundra 5.7 4x4 Limited with floor shifter
