Loosen nut to do alignment on a 2014 Tundra.
Discussion in 'Suspension' started by JayKay, Sep 15, 2024.
  1. Sep 15, 2024 at 4:24 PM
    JayKay
    JayKay [OP] New Member
    Hi everyone,
    I can NOT loosen this nut to do an alignment on my 2014 Tundra. I got it loose to where the nut will turn the whole tie rod but can’t get it to loosen to be able to turn the nut on the tie rod thread. Is there any tricks to get the nut to turn on the tie rod threads? It’s like the nut is welded to the threads from over the years of it not being loosened. Thanks in advance!
  2. Sep 15, 2024 at 5:04 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
  3. Sep 15, 2024 at 5:07 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    MAPP torch.
  4. Sep 15, 2024 at 5:27 PM
    JayKay
    Will try to torch it next Sunday. Thanks for the torch tip!
  5. Sep 15, 2024 at 5:34 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Did you try soaking it overnight with penetrant?
  6. Sep 15, 2024 at 5:36 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    heat that bitch up and squirt a little atf on it
    Ginsterkev likes this.
  7. Sep 15, 2024 at 5:57 PM
    timsp8
    NY
    Penetrating oil and vice grips for the part that isn’t supposed to turn.
  8. Sep 16, 2024 at 5:34 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Doesn't work. Metals meld into each other, only heat can break it.
  9. Sep 20, 2024 at 5:52 PM
    JayKay
    So I tried to heat it today and it will NOT budge. When I put my adjustable wrench on the tie-rod and rest it against something solid, I hammered the nut but it would just turn the whole tie-rod because the wrench wouldn’t hold it in place. I heated it for like 30 seconds to 1 minute max. Should I heat it a lot longer until the nut turns red?
